We are having trouble calculating the amperage passing thru the 2-milli-ohm RSENSE SHUNT resistor using the LM25066A 2016 Datasheet; the CL=GND. what is the proper equation to determine the current ?
thanks,
thanks,
Kevin
Assume you are using PMBus to read. Use the m,b,r coefficients per table 41, pg 39 of the DS with the normal PMBus protocol.
Brian
yes, ohms' law...E/R=I
I am asking for how to calculate the current using the M,B,R equation with the 12-bit READ_IIN number from the LM25066A ?
