• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Wireless Power » Wireless Power Forum » BQ500110 coil_pwm problems
Share
Wireless Power
  • Forum
  • Files
Options
  • Subscribe via RSS
This question is answered
dean k
Posted by dean k
on Aug 22 2011 01:40 AM
Prodigy150 points
Hello E2E community,
I am currently debugging a design based on the BQ500110-EVM and the BQ51013-EVM.
When I apply power to the BQ500110 and probe the COIL_PWM pin I do see the three 100kHz pulses except they occur every 0.4 sec instead of 0.5 sec (EVM user guide states it should be 0.5 sec). I also notice that sometimes (around 10 - 20% of the time) the BQ500110 will output a 175kHz square wave for about 50 ms instead of the three 100kHz pulses.
Should this be happening? or should I just be seeing the 100kHz pulses until I place my reciever on the transmiting coil? (I dont have an EVM kit to do these tests).
Any feedback or comments would be much appreciated
bqTESLA bq51013 BQ500110 wireless power Wireless charging BQTesla 150 Qi Wireless charger inductive charger WPC Wireless power consortium QI Texas Instruments bq500110EVM
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Vladimir Muratov
    Posted by Vladimir Muratov
    on Aug 22 2011 10:26 AM
    Verified Answer
    Verified by Vladimir Muratov
    Prodigy630 points
    Hello Dean,
    All your observations are correct.
    The 0.4s repetition rate you observing is the right number.  The WPC spec requires detection of the receiving devise in no more than 0.5s.  Considering some processing time needed, the 0.4s ping repetiton rate has been implimented in BQ500110.
    The 175kHz, 50ms square wave is the digital ping sequence.  The digital ping can be issued at any time the analog ping detects something being placed on the charging pad.  Independently of that the digital ping is sent every 5s as a back up to the analog ping.
    Vladimir Muratov
    Texas Instruments
    DC Solutions
    Wireless Power, Tx
    Office:   603.222.8664
    Mobile:  603.858.4776
    bqTesla100LP BQ500110 wireless power Qi Wireless charger inductive charger bq500110EVM
    Report Abuse
    • Reply
  • dean k
    Posted by dean k
    on Aug 23 2011 02:52 AM
    Prodigy150 points
    Hello Vladimir and thank you very much for your informative response.
    Now that i know the BQ500110 seems to be switching the coil correctly, I have moved onto debugging the reviever side/communication channels.
    When I first place my reciever on the transmit coil (there is about 5mm spacer between the coils) I get zero volts at the output of the receiver. when probing the V-RECT pin the voltage is varying about 500mV to 1V during the transmitter analog pings and rises to around 8 - 10V during the digital pings.
    I probe the COMM1 and COMM2 pins on the 51013 receiver and they show a digital signal with 'spaces' as zero volts and 'marks' as a 175 kHz AC voltage (10 Vp-p). when I look at the COMM pins on the receiver I see some pre-amble followed by a header byte, then the message then the checksum as expected.This is shown in the following screen shot where the yellow trace is the COMM1 pin and the purple trace is the VRECT pin.
    Probing the COMM1 and COMM2 pins on the 500110 shows about a 100 mVp-p with a DC offset of around 3.25 volts. Obviously my demodulation circuit is not working correctly. I have based this demodulaiton circuit off the BQ500110-EVM, what kind of signal should I expect to see at the COMM pins of the 500110 using this circuit?
    One other thing I notice is that if I move the coils a tiny bit closer together (using a slightly thinner spacer) the status LED on the BQ500110 tranmitter starts blinking at a 200ms rate indicating a fault. After this the transmitter stops driving the TX coil until I reset the BQ500110.
    If the communication demodulation circuit is not working correctly then why am I getting fault conditions on the transmitter only when I place the receiver on the transmitting coil? (almost seems as if the transmitter is getting a fault communication from the receiver). I've got PMOD disabled and the fault light doesn't blink if i place just an unconnected receiver coil on the TX coil.
    Is there a way to determine the type of fault that is occurring (PLD, SYS, DEV or NVM)?
    Is there any detailed information on the faults that are indicated by the BQ500110 LED status indicators (what exactly are the PLD, SYS, DEV and NVM faults)?
    Sorry about the length of this question, once again any help would be greatly appreciated.
    bqTESLA bqTesla100LP bq51013 BQ500110 bqTesla100LP bqTesla150LP wireless power Wireless charging Qi Wireless charger inductive charger WPC Wireless power consortium QI bq500110EVM
    Report Abuse
    • Reply
  • dean k
    Posted by dean k
    on Aug 24 2011 06:01 AM
    Prodigy150 points
    Just a follow up on the last post I made:
    I fixed the errors I had with my demodulator circuit and the receiver is now communicating with the transmitter. The 500110 is no longer indicating faults when i place the receiver coil closer than about 5mm to the transmit coil.
    The last problem with my BQ500110 circuit is that when I power it up, it doesn't initialize properly and an external reset must be performed to get the BQ500110 to enter standby mode. Is there any particular conditions that must be met while the IC is doing its initial POR/initialization (such as holding the external reset pin low until the initialization is complete)?
    Cheers
    bqTESLA BQ500110 wireless power Wireless charging BQTesla 150 Qi Wireless charger inductive charger WPC Wireless power consortium QI bq500110EVM
    Report Abuse
    • Reply
  • Vladimir Muratov
    on Aug 24 2011 08:39 AM
    Verified Answer
    Prodigy630 points
    Dean,
    I glad you reselve most of the issues.
    Per WPC  maximum guranteed distances between coils is 5mm.  The distance should be measured from coil to coil.  It means that plastic covers in TI bqTesla kit should be included into this 5mm.
    Can you provide the details how you power bq500110 up.  Are you using TI EVM, or this is the board built by you?  What power supply are you using and what is over current set point on it?
    You may like responding me directly.
    Vladimir Muratov
    vladimir_muratov@ti.com
    BQ500110 wireless power Wireless charging Qi Wireless charger inductive charger QI bq500110EVM
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
