• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Wireless Power » Wireless Power Forum » long distance between coils?
Share
Wireless Power
  • Forum
  • Files
Options
  • Subscribe via RSS
This question is answered
Ling Wang
Posted by Ling Wang
on Dec 04 2012 19:29 PM
Prodigy20 points
Is it possible to bypass the WPC standard in any design with bq500110 series?
I also find the 5 mm limit is very annoying in most applications. I would like to have it transfer energy in 20-40mm range @ 1%-10% efficiency (10-50mA). From the file attached to this forum it seems physically possible. However, you said the WPC prevents this. Then is it possible to bypass the communication controlling the power output. For our design the energy efficiency is the least concern.
Ling
Report Abuse
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bill Johns
    Posted by Bill Johns
    on Apr 14 2012 11:25 AM
    Verified Answer
    Verified by Bill Johns
    Genius12330 points
    Hi Ling
    The WPC standard can be bypassed if your design is NOT WPC certified and is considered a proprietary design.  In this design your RX will only be used with your TX.
    At a current level of 10-50mA and low efficiency increased distance may be possible.
    The bq500110 (bq500210 may be better) and bq51013 require communications to operate correctly and establish power transfer.
    The first problem that you will encounter is TX having difficulty detecting the RX.  Load placed on the TX coil by RX coil may not be enough for the analog ping to detect the RX.  This is a short pulse the TX sends out every 400mS.  But the TX also sends out a digital ping every 15 sec, which is a long pulse, intended to power up the RX and allows it to respond.  The digital ping has the greatest chance of detecting an RX a long distances. But time for the TX to detect the RX will be longer.
    A larger RX coil will also perform better, you could start testing with the standard bq51013EVM-725 coil, which is 40mm X 30mm.
    Standard EVMs could be used to evaluate the performance with your application.
    Best Regards
    Bill
    Bill Johns,  Applications Engineer
    bqTESLA Wireless Power Products
    Texas Instruments Inc
    Dallas, Texas
    bqTESLA
    Report Abuse
  • Ling Wang
    Posted by Ling Wang
    on Apr 14 2012 23:06 PM
    Prodigy20 points
    Dear Bill,
    Thanks for your quick response. Is it possible to let the power transmission always ON without detect anything? If it is possible, that will be the easiest way to solve this problem.
    Thanks a lot,
    Ling
    Report Abuse
  • Bill Johns
    on Apr 15 2012 21:33 PM
    Genius12330 points
    Hi Ling
    No-This is not possible.
    The transmitter will have to identify a valid receiver is present before power transfer will start.
    During power transfer the transmitter must receive information from the receiver.
     The transmitter will turn off after 1.5sec if it does not receive info from the receiver.
    Bill
    Dallas, Texas
    Report Abuse
  • Kunal Gupta
    Posted by Kunal Gupta
    on Dec 04 2012 02:36 AM
    Verified Answer
    Prodigy30 points
    I am also in need of a high range wireless charger using bq51051b IC. I want to increase the range to 2cm - 5cm , size is not a constraint in Tx but should be <= 6cm in Rx.  So from Qi Specifications of good efficiency, I tried to calculate the diameter of Tx & Rx Coils and I found if I will use 20cm Diameter coil in Tx and 6cm Diameter coil in Rx it can give 2cm range if Q is 100. I got it theoretically but do you think that it can work or any other way to increase the range to  5cm.
     How to calculate energy efficiency any formula or can test only after making it? .
    What are the materials from which I can make the cover which will be in contact of both coils?
    Kunal
    Report Abuse
  • Bill Johns
    Verified Answer
    Genius12330 points
    The bqTESLA products that we support are designed to meet the WPC distance requirement of 5mm.
    To go to 200mm or 500mm may be possible but this is not and application TI will endorse or support.
    Dallas, Texas
    Report Abuse
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
