• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Wireless Power » Wireless Power Forum » transmitter coil form factor
Share
Wireless Power
  • Forum
  • Files
Options
  • Subscribe via RSS
This question is answered
Andrew Sauter70629
Posted by Andrew Sauter70629
on Jul 20 2012 12:31 PM
Prodigy150 points
We would like to make a smaller transmitter coil are there any options with TI's ICs, even if efficiency is decreased?
Could we use the 760308201 as transmitter?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Vladimir Muratov
    Posted by Vladimir Muratov
    on Jul 25 2012 18:12 PM
    Verified Answer
    Verified by Vladimir Muratov
    Prodigy630 points
    Hello Andrew,
    Yes, you can use this coil with the transmitter controllers from TI.  You will need recalculate resonant capacitors and chose lower input voltage.  This will not be Qi certifiable solution.  Please make note of newly released BQ500211 TX controller.
    If you have further questions, please contact me directly.
    Vladimir Muratov
     vladimir_muratov@ti.com
    603.222.8664
    Report Abuse
    • Reply
  • Julian King
    Posted by Julian King
    on Jul 27 2012 07:47 AM
    Verified Answer
    Prodigy60 points
    Hi Vladimir
    I have tried similar the setup as Andrew's with Wurth 760308201 as transmit coil on bq500210 EVM. I replaced capacitors to tune new coil (10uH) to 100KHz. I am using same coil on receiver (bq51013 EVM) and find that it works, but intermittantly and I see significant current occasionally on transmitter with no load on receiver and I have blown up two receiver boards. The Receiver modulation looks very poor and I wonder if this is part of problem. Do I need to change the value of the modultaion capacitors (22nF) on the receiver to match the higher capacitance on the transmitter. How do I calculate new  voltage to use with new transmitter coil.
    Julian
    Report Abuse
    • Reply
  • Vladimir Muratov
    on Jul 27 2012 08:00 AM
    Prodigy630 points
    Julian,
    Did you lower the input voltage for BQ500210 EVM?  The 760308201 coil has only 15 turns while the original TX coil has 20.  The voltage on the receiver side can be too high tripping OVP if you tune TX resoancne to 100kHz.  Alternatively to lowering input volatge you may try tuning TX to lower frequency 80...90kHz.  You may try this two hints before altering anything on the RX side.
    Let us know which way worked best for you.
    BQ500210 bqTESLA EVM BQ51013 recognition
    Report Abuse
    • Reply
  • Julian King
    on Jul 27 2012 08:36 AM
    Prodigy60 points
    Vladimir,
    No I'm running it at 19V, but monitoring the receiver regulator output and this has kept below 15V, but still two receivers have failed, how resilient is the OVP? I'll try your two suggestions. In the meantime do you think the modulation would be affected by the transmitter coil design, as it does behave as if the communications are not reliable. i.e it will establish a good power transfer, but then drop out after a minute or so. I'm thinking that I need to modulate the receiver load more now that I have less coupling between the coils.
    Thanks for your help.
    Julian
    Report Abuse
    • Reply
  • Vladimir Muratov
    on Jul 27 2012 09:09 AM
    Verified Answer
    Prodigy630 points
    The OVP will safe the RX chip in case of accidents but not in the case of permanent over powering.  If you palnning using smaller TX coil it makes sense also reduce size of the RX coil otherwise coupling is definitely reduced.  You may tru using the Wurth coil on both sides. Once more be carreful not overpowering the RX.  The BQTESLA kit is designed in the way that secondary side input voltage is never dangerously high.
    Increasing COMM capacitors has it's limits too.  This is a resoant system and too many changes lead getting out of resoance and the system not working.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
