I am designing a wireless charger to charge a Li-ion battery, with a 1A charging current.
i would like to use Bq51050B for the receiver side, i need to know if the system will work if i use Bq0211 as the transmitter ( as i only see Bq50210 transmitter mentioned in the Bq51050b datasheet). my only problem with Bq50210 is that my charger should work with 12v-24 v input , is their any solution or recommendations for that?
your help is highly appreciated.
