I would like to confirm BQ51013BEVM-764.
1. Outline (size) 2. Electric intensity by 3m method
Could you please reply them?
Atsushi Yamauchi
Atsushi Yamauchi
Yamauchi-san,
1. The PCB is 53.34mm on each side. The actual solution size is much smaller.
2. The bq51013B is a receiver, not a transmitter and as such, does not generate an electric field. Can you explain your question further if this is not the correct response?
Dick
Dear Dick-san,
Thank you for your response.
About 1, if you can, could you please the values for length, width and height.
About 2, your answer is correct. I'm sorry for this question.
Atsushi Yamauchi
Yamauchi-san,
For reference, I'm using the EVM shown here: http://www.ti.com/tool/bq51013bevm-764.
The PCB is 53mm in length and 53mm in width. The height (including the optional components) is about 11mm.
The case is 62mm in lenght and 62mm in width. The height is 23mm.
The total height (PCB mounted with some offset into the case is about 31mm.
Dick
