I have designed wireless receiver with BQ51050B (ref taken is bq51050BEVM-764) and want to charge 220mAh Li-Ion battery with 10mm Diameter receiver coil part (760308101208-wurth).
I am using Wireless Transmitter pad - AEP-5000WP model from adamelements.
I experimented the test with receiver coil centre aligned on Transmitter pad with gap < 3.4mm. (with Cs = 47nF 50V & Cp = 2.2pF 50V)
But, not getting proper communication between Tx & Rx coils and so Transmitter is not initiating charging of Battery.
Kindly suggest for the same.
