In BQ500412, Vsense connection is after the R sense resistor( 40mOhm)
But in BQ500414Q V sense is before R sense resistor!?
Why?
We think that this has effect on the efficiency. Can you help us & tell us which one is correct?
Both will work--Key is to get an accurate measurement of the power section voltage. This value is used for FOD calculations.
Sensing V-in after the sense resistor and at the power section filter cap is best. Measuring at V-in before the sense resistor will work also. But I have seen many customers connect to the input or an area far from the power section.
Will not have any effect on efficiency.
