What is the correct way to size the capacitor on the RECT pin for bq51013B?
In the datasheet it states, "Depending on the power levels, the value may be 4.7 μF to 22 μF."
In the BQ51013BEVM-764 User's Guide, it recommends C_RECT >= 10 uF, along with high frequency bypass caps.
Is there a table of the power levels and corresponding recommended C_RECT values? Since the end application is size-constrained, the lowest possible capacitance while not compromising the IC / system performance is preferred.
Jonathan
