Hi
We are building wearable device and planned to use wireless charging circuitry. I have placed few passive components and LED controller chip on bottom of the PCB where the wireless coil will also come.
1)Can we place the passive or active components near to wireless coil? if yes how much will be the min clearance between them.?
2)Can we place wireless charging receiver coil sticking directly to the bottom of the PCB ? If no, then what is the suitable placement for the wireless Rx coil?
3)I read forum and got to know about shielding of wireless RX coil is required ,if we are going to stick the coil to the PCB.What kind of shielding is required ?
4)I have used BQ51003YFPR wireless RX Qi chip and would like to get support from TI for the selection of Wireless RX as I need diameter of Wireless RX coil around 17-18mm and height should be low profile within 0.6-0.8mm.
Looking forward for your positive response!!!
Dinesh Katkar
