BQ51050B is quite optimal chip for charging our device ~1A. However 10h charging timer gives faulty battery error and charging stops until device is removed from charging pad. This ruins our burn in test. In this test device is continuously powered and stays on charging pad consuming more than charging end current, so BQ51050B cannot stop charging normally. Is there any trick to overcome this 10h timer from device side?
