we are testing our design and the BQ501210 development kit with several receivers.
We've realized that "starting" the charge requires to have the coils too close to each other. However, once it is started the coils can be taken appart and the charge still continues.
In our design we have about 6mm gap which should not be a problem. However, the behaviour seems not to be very stable.
We are afraid that it is due to the FOD and PMOD resistors. Is there any guideline/process to choose these values?
I've read that removing these resistors mean that the design will not be WPC1.2 compliant anymore.
Even if it is not WPC1.2 compliant will the charger still work with WPC 1.1 receivers?
What would be the risk if PMOD and FOD are disabled?
Thanks in advance and kind regards,
LS84
