Other Parts Discussed in Thread: BQ51013B, CC3200MOD, CC3200
Hi all,
I'm developing a low power Iot device, and I'd like to power it using wireless power (no wired power supply). I found the BQ51051B as possible solution but I need some claryfication on its use and in general about the wireless charge tecnology. My scenario is the following:
1) Device near the wireless power transmitter: the wireless power receiver inside the device should give power to the device and at the same time recharge the battery device.
2) Device far the wireless power transmitter: the device is powered only by the inside battery.
In the schematics I found, the BQ51051B is used to recharge only the battery but not to power other circuits, where I can found a correct schematics ? should be BQ51051B able to give an VOut pin when I can switch power between battery power and wireless power source?
Thanks!
Riccardo
