I'm actually designing an IoT product which include a wireless charging solution following the WPC 1.1 standard. The BQ51050B has the advantage of having an integrated Li-ion charger so I choose this one. My goal is to recharge a Li-ion battery with a "fast charge" current of 1A.
Following your datasheet, application note and EVM (bq51050BEVM-764), I understand and found the different values of the calibration components (Resonant capacitor, max current output resistor, termination resistor ...) but I don't understand one feature: how Ros and RFOD calibrate the FOD mechanism ?
I understood that those resistors must have an particular attention and must be "calibrated" to assure the WPC v1.1 Compatibility. I found your associated tool (Foreign Object Detection (FOD) Calibration/Tuning Tool) and I have some question about it:
1) How the model error curve is established ? What parameters determine this curve and how Vos change this model ?
2) By manipulating Vos (I suppose the voltage in the resistor Ros) to fix the model error, does this value impact on the electrical characteristic of the resistor ?
3) Electrically speaking, how Ros change the offset and RFOD the slope of the Ploss curve ?
Is there a kind of equation about this relationship ?
I guess one of those resistor (RFOD ?) represents components that influence received power (part 6.2 of User Manual) and the voltage (VFOD) must be a part of this equation.
Sorry for those questions but I would like to have at least few informations about FOD mechanism before building the PCB.
The goal of the project is to have a proof of concept so we probably won't need the AVID tool for now. I want to be sure that with the EVM value (Ros = 42.2k and RFOD = 200), I will have a functional device.
Thank you
Nicolas LAW
