PLEASE READ FIRST: Keystone I & II Multicore Forum Usage Guidelines
Guru 81145 points
Welcome to the TI E2E forum. I hope you will find many good answers here and in the TI.com documents and in the TI Wiki Pages (for processor issues). Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics (e2e.ti.com).
Welcome to the Keystone Multicore Forum!
This forum is for issues with keystone devices its peripherals as well as any SDK used on keystone platforms, including:
1. Processor SDK RTOS
2. MCSDK (Multicore Software Development Kit)
3. Desktop Linux SDK
4. MCSDK Video
Please check Learn More About Keystone Multicore Devices for more resources
When asking a question, please include:
Which version of Processor SDK RTOS/MCSDK you are using
Which processor and board platform (EVM & its revision) you are using
If relevant, the version of your components
If relevant, which version of the compiler and Code Composer Studio you are using
If the issue happens with a specific API, please provide the source code used
If the issue happens at run-time, please provide a detailed description of the problem and the expected behavior.
Provide attach relevant Message Log or Kernel/Object View debug info or screen captures of the real time analysis tools.
Thanks and Best Regards,
TI Keystone Forum
Rajasekaran K
Don't forget to click the Verify Answer button if this post answers your question.
Learn More About Keystone Multicore Devices: Resources for Keystone Devices
Please download the latest Processor SDK for Keystone I & II devices(C665x, C667x, K2H, K2E, k2G & K2L).
  • Hi Raj,
    Note:- Ti-k2g-evm it will support bitbake, because i modified build/conf/local.conf -> machine name k2g-evm its getting error.
    ERROR:  OE-core's config sanity checker detected a potential misconfiguration.
        Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
        Following is the list of potential problems / advisories:
        MACHINE=k2g is invalid. Please set a valid MACHINE in your local.conf, environment or other configuration file.
  • Guru 81145 points
    In reply to raghu reddy36:
    Please start a new thread in Keystone /Linux Forum for appropriate response. Thank you.
    Rajasekaran K
