RTOS: What should be the cache-able option for shared memory for IPC
Other Parts Discussed in Thread: OMAPL138, SYSBIOS
Tool/software: TI-RTOS
Hi there, I have installed IPC 3.46.00.02 and have run the ex02_messageq example on OMAPL138 and with Linux on ARM.
I don't understand the cache option added in the DSP.cfg file :
var Cache = xdc.useModule('ti.sysbios.family.c64p.Cache');
/* Set 0xc4000000 -> 0xc4ffffff to be non-cached for shared memory IPC */
Cache.MAR192_223 = 0x00000010;
I guess, the comment is wrong to start with. Here we are disabling the 0xc3000000 rather than 0xc4000000.
Could you explain what is the idea about this cache option? should IPC memory not be cache-able ?
Attached the full dsp.cfg file for your reference.
Thanks.2337.Dsp.cfg
  • Hi there,
    In the ex02 example the configuration for messageQ uses HeapBuf and then register it to heapID 0. Is there a way to add that this heap is cache enabled?
    Lines from dsp.cfg file:
    /* create a heap for MessageQ messages */
    var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
    var params = new HeapBuf.Params;
    params.align = 8;
    params.blockSize = 512;
    params.numBlocks = 256;
    var msgHeap = HeapBuf.create(params);
    var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
    MessageQ.registerHeapMeta(msgHeap, 0);
  • Hi there,
    is there any way to run this ex02 example with Cache enabled for the heap memory.
    I've notified the RTOS team. Their feedback will be posted directly here.
    Yordan
  • Check the MAR bit description here:
    www.ti.com/.../sprufk5a.pdf
    MAR192 corresponds to bit 0 and MAR196 corresponds to bit 4 which is set to 1 in the configuration.
    Interpretation of that setting can be found in the SYBIOS documentation:
    software-dl.ti.com/.../Cache.html
    If you don`t prefer using the .cfg for this setting then you can use the APIs provided here:
    Rahul
  • Hi Rahul,
    so the comment in the ex02 example configuration is wrong.
    It says
    //Cache.MAR192_223 = 0x00000010;
    However, its enabled 0xc4000000 -> 0xc4ffffff and the rest is disabled.
    How can use the ex02 example with following settings:
    Cache.MAR192_223 = 0x00000018;
    The entry point of the design is 0xc3000000
  • Hi Mitesh,
    I think you are correct, Cache.MAR192_223 = 0x00000010 sets 0xc4000000 -> 0xc4fffff to be cacheable. I will confirm this with the team.
    Cache.MAR192_223 = 0x00000018 will set 0xc3000000 -> 0xc4ffffff to be cached.
    You can find more information on cache configuration in the cdoc for the ti.sysbios.family.c64p.Cache module. The cdoc can be found in the \bios_6_46_05_55\docs\cdoc\ti\sysbios\family\c64p\Cache.html directory.
    You can also take a look at the following code snippet for reference:
    /* configure external memory cache property
    * C000_0000 - C7FF_FFFF 800_0000 ( 128 MB) Cache.MAR192_223
    * C000_0000 - C1FF_FFFF 200_0000 ( 32 MB) -------- don't care
    * C200_0000 - C202_FFFF 3_0000 ( 192 KB) SR_0, SR-1 no-cache MAR194
    * C203_0000 - C2FF_FFFF FD_0000 ( ~15 MB) -------- no-cache MAR194
    * C300_0000 - C37F_FFFF 80_0000 ( 8 MB) DSP_PROG cache enable MAR195
    * C380_0000 - C3FF_FFFF 80_0000 ( 8 MB) -------- cache enable MAR195
    * C400_0000 - C7FF_FFFF 400_0000 ( 64 MB) -------- don't care
    Cache.MAR192_223 = 0x00000008; /* xxxx xxxx xxxx xxxx xxxx xxxx xxxx 10xx */
    Once you have it configured, you can use ROV to check the state of the cache. Take a look at the following thread for more information:
    e2e.ti.com/.../111081
    Hope this helps. Let us know if you have any questions.
    Sahin
  • Hi Sahin,
    When I run the example with defualt cache settings all seems to work. However, when I change the use cache for the messageQ heap the example ex02 design stops working!!!
    Could you please help me with this.. How can I use the ex02 example with cache enabled. Thanks.
    DO I need to add cache write back functions?
  • Hi there, any update on this issue, please?
  • Hi there,
    In my design I would like to use Cache option for the software running on the DSP. Looking at the example for the IPC it looks like the Cache is disabled for IPC communications.
    Is there a way to use Internal On-Chip memory on OMAPL138 address 0x80000000 SharedRam ?
    I have added following code in the configuration file:
    /* Shared Memory base address and length */
    var SHAREDMEM = 0x80001400;
    var SHAREDMEMSIZE = 0x00020000;
    * Need to define the shared region. The IPC modules use this
    * to make portable pointers. All processors need to add this
    * call with their base address of the shared memory region.
    * If the processor cannot access the memory, do not add it.
    var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
    SharedRegion.setEntryMeta(0,
    { base: SHAREDMEM,
    len: SHAREDMEMSIZE,
    ownerProcId: 0,
    isValid: true,
    createHeap: true,
    cacheEnable: true,
    var HeapMemMP = xdc.useModule('ti.sdo.ipc.heaps.HeapMemMP');
    var paramsMP = new HeapMemMP.Params;
    paramsMP.name = "shr";
    paramsMP.regionId = 0;
    paramsMP.sharedAddr = SHAREDMEM;
    paramsMP.sharedBufSize = SHAREDMEMSIZE;
    var msgHeap1 = HeapMemMP.create(paramsMP);
    How can use this buffer as the Heap for MessageQ?
    Thanks.
  • Hi Mitesh,
    Sorry for the delayed response. In your SharedRegion configuration, you have createHeap set to "true", which instructs IPC to automatically create a HeapMemMP instance that is the size of the entire shared region. With this configuration, you do not need to create another HeapMemMP instance as you do in your cfg file.
    If you want to create a HeapMemMP instance using just a subset of the shared region, then set createHeap to "false" and create the HeapMemMP instance as you do. Just note, the size of the HeapMemMP needs to be less than the SharedRegion.
    Also, any IPC instance created within the SharedRegion will inherit the cache settings of the SharedRegion. So since you set cacheEnable to "true", the HeapMemMP instance created will also be cache-enabled. (refer to http://www.ti.com/lit/ug/sprugo6e/sprugo6e.pdf#page=62)
    I hope this helps. Please let us know if you have any other questions.
    Sahin
  • Hi Sahin,
    Thanks for coming back.
    I have changed the createHeap settings to false and creating heap using the HeapMemMP but the design fails to compile.
    Error: HeapMemMP does not support static instances.
    Can I do the following:
    var SHAREDMEM = 0xc0000000;//0x80001400;
    { base: SHAREDMEM,
    len: SHAREDMEMSIZE,
    ownerProcId: 0,
    isValid: true,
    createHeap: false,//true,
    cacheEnable: true,
    params.align = 8;
    //params.sectionName = "testHeap";
    //Program.sectMap["testHeap"] = "SharedMem"; //"DDR";
    But not sure how will msgHeap would be allocated from SharedMem.
    Could you please, explain, Thanks.
  • Hi Sahin, I tried the folowing as you suggested.
    But still getting error even to compile the design.
    Added in C code:
    HeapBufMP_Params heapParams;
    HeapBufMP_Handle heapHandle;
    HeapBufMP_Params_init(&heapParams);
    heapParams.regionId = 1;
    heapHandle = HeapBufMP_create(&heapParams, &eb);
    MessageQ_registerHeap(heapHandle, 1);
    One more thing, I am not 100% sure is would I be able to use the sharedRam for IPC between DSP and ARM/Linux core?
  • This is the error, I get from CCS:
    undefined first referenced
    symbol in file
    ti_sdo_ipc_heaps_HeapBufMP_Params__init__S ./main.obj
    ti_sdo_ipc_heaps_HeapBufMP_create ./main.obj
    error #10234-D: unresolved symbols remain
  • Hi Sahin,
    Right, so as per you previous reply,
    I have left the SharedRegion configuration, createHeap to "true" and removed the extra HeapMemMP instance from the cfg file.
    I have then added
    MessageQ_registerHeap(SharedRegion_getHeap(1), 1);
    in C code. I believe, we need to add this so that messageQ are allocated from this SharedRegion . Does this makes sense?
    ROV View of SharedRegion: id 1:
    ,1,0x80001400,0x800033ff,0x2000,0,false,true,8,0,0x0,SharedRAM
    Got the following Error in CCS:
    3 Resource entries at 0xc3110000
    [t=0x0a2aac5f] ti.sdo.ipc.MessageQ: ERROR: line 191: assertion failure: A_heapIdInvalid: heapId is invalid
    ti.sdo.ipc.MessageQ: line 191: assertion failure: A_heapIdInvalid: heapId is invalid
    xdc.runtime.Error.raise: terminating execution
    In the C code: I have used the following:
    And the CFG:
    var SHAREDMEMSIZE = 0x00002000;
    SharedRegion.setEntryMeta(1,
    { base: SHAREDMEM,
    len: SHAREDMEMSIZE,
    ownerProcId: 0,
    isValid: true,
    createHeap: true,
    cacheEnable: false,
    cacheLineSize: 0,
    Also try the following in C code:
    MessageQ_registerHeap(SharedRegion_getHeap(SharedRegion_getIdByName("SharedRAM")), 1);
    no luck.
  • Hi Sahin,
    I have called messageQ_registerHeap in C code before the MessageQ_alloc.
    About having SR0 for IPC, can I do the following:
    var SHAREDMEM = 0xc3200000;//0x80001400;
    /*var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
    { base: SHAREDMEM,
    len: SHAREDMEMSIZE,
    ownerProcId: 0,
    isValid: true,
    createHeap: true,
    cacheEnable: false,
    cacheLineSize: 0,
    //var SHAREDMEM1 = 0xc200000;//0x80001400;
    //var SHAREDMEMSIZE1 = 0x00020000;
    { base: SHAREDMEM1,
    len: SHAREDMEMSIZE1,
    ownerProcId: 0,
    isValid: true,
    createHeap: true,
    cacheEnable: false,
    cacheLineSize: 0,
    //MessageQ.registerHeapMeta(IPCHeap, 0);
    /* Setup MessageQ transport */
    var VirtioSetup = xdc.useModule('ti.ipc.transports.TransportRpmsgSetup');
    MessageQ.SetupTransportProxy = VirtioSetup;
    /* Setup NameServer remote proxy */
    var NameServer = xdc.useModule("ti.sdo.utils.NameServer");
    var NsRemote = xdc.useModule("ti.ipc.namesrv.NameServerRemoteRpmsg");
    NameServer.SetupProxy = NsRemote;
    /* Enable Memory Translation module that operates on the BIOS Resource Table */
    var Resource = xdc.useModule('ti.ipc.remoteproc.Resource');
    Resource.loadSegment = "DDR";
    /* Use SysMin because trace buffer address is required for Linux/QNX
    * trace debug driver, plus provides better performance.
    var System = xdc.useModule('xdc.runtime.System');
    var SysMin = xdc.useModule('xdc.runtime.SysMin');
    System.SupportProxy = SysMin;
    SysMin.bufSize = 0x8000;
    Program.sectMap[".tracebuf"] = "DDR";
    Program.sectMap[".errorbuf"] = "DDR";
    /* Override the default resource table with my own */
    Resource.customTable = true;
    And In C Code:
    MessageQ_registerHeap(SharedRegion_getHeap(SharedRegion_getIdByName("SharedRAM1")), 1);
    Not sure if the heapID should be 0 or 1.
    Where will the messageQ_alloc will allocate memory from?? would it be 0xc20000000?
    And would I be able to use this to communicate with remoteproc in Linux??
    Thanks.
  • Hi Mitesh,
    The configuration looks ok. The heapID depends on which heap you want to allocate messageQ from (refer to downloads.ti.com/.../_message_q_8h.html
    downloads.ti.com/.../_shared_region_8h.html )
    messageQ_alloc will allocate memory from the heap specified with the heapID.
    Did you run into any errors when running this configuration? If so, what were they?
    Also, did you already refer to the src and cfg files in ex02_messageQ? I think that example does what you are trying to do here.
    Sahin
  • Happy New Year Sahin, thanks for your reply.
    I have gone through the C code of the Messageq_ex02 example. However, when I just make one change
    1)
    to
    And the example stops working...
    Could you help me to get this working, please.
  • Hello Mitesh,
    Happy New Year!
    The line
    sets 0xc3000000 -> 0xc3ffffff to be cached. I believe the Vring buffers are placed in this region by default. Vring buffer regions need to be marked as uncached so make sure that you are placing them outside the cached region.
    Sahin
  • Hi Sahin, thanks for your reply.
    I did try that in the past but I was not able to boot Linux.
    Here are the changes I had done:
     * Changed Resource table address for VRINGS to 0xc2000000
     * Changed DSP app to run from 0xc3000000
     * Made 0xc3000000 Cache-able
     * In DTS file changed CMA region to be 0xc2000000 of lenth 0x02000000
    But the linux was not able to boot!/...
    Would you be able to create a new ex02 example with cache enabled for the DSP app and VRING in non-cache region for me, please?
    Thanks.
  • Or please let us know. How can we keep the VRING in the same region 0xc3000000 but run the DSP app in cache region may be 0xc4000000.
