Part Number: TDA3
I am trying to figure out in the Vision SDK code when Range FFT begins processing the incoming chirp data. Does it process the moment it gets the first returned chirp or does it wait until the entire chirp sequence finishes before it start processing Range FFT?
I saw a plot in the ProcessorSDK_UserGuide.pdf in Section 3.9.1.2 that has angle information. How do you achieve Angular information? Do you perform a third FFT on the chirp data assuming second FFT result in Doppler information?
--Khai
