Part Number: TDA3
Hi Sir,
When I use the same edma driver on TDA2xx it is working properly but for TDA3x it is not working. Actually using EDMA copying the data from external SDF to RAM. The base address for EDMA is 0x43300000 in TDA2xx where as in TDA3x also it is same as per the TRM, but when I use this address for TDA3x it is generating the exception.
Due to this it needs to be mapped somewhere else. So i want to know how to map this edma so that it will work properly.
Thanks in Advance!
Sagar K
