RTOS/TDA2: encode link whether to support two instances
Part Number: TDA2
Other Parts Discussed in Thread: DM385
Tool/software: TI-RTOS
I use two channlel one is h264,the ohter is MJPEG.
the encoude input is 30 FPS, but the output is 15. (It should be 30);
Please help me to check this issue! how to config the parameter to complete that the output is 30FPS.
the test result as below:
[HOST] [IPU2 ] 43.881199 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 43.881321 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 43.881473 s: --------------------------------------------------
[HOST] [IPU2 ] 43.881595 s: 0 | 30.17 0. 0 0. 0 15. 8
[HOST] [IPU2 ] 43.881839 s: 1 | 30.17 0. 0 0. 0 15. 8
the parameter is:
case '0': /* MJPEG */
pLinkChPrm->format = SYSTEM_IVIDEO_MJPEG;
pLinkChPrm->profile = 0;
pLinkChPrm->dataLayout = VENC_FIELD_SEPARATED;
pLinkChPrm->fieldMergeEncodeEnable = TRUE;
pLinkChPrm->enableAnalyticinfo = 0;
pLinkChPrm->enableWaterMarking = 0;
pLinkChPrm->maxBitRate = 0;
pLinkChPrm->encodingPreset = 0;
pLinkChPrm->rateControlPreset = 0;
pLinkChPrm->enableHighSpeed = 0;
pLinkChPrm->enableSVCExtensionFlag = 0;
pLinkChPrm->numTemporalLayer = 0;
pLinkChPrm->overrideInputScanFormat= 0;
pLinkChPrm->fieldPicEncode = 0;
pLinkDynPrm->intraFrameInterval = 0;
pLinkDynPrm->targetBitRate = (10 * 1000 * 1000);
pLinkDynPrm->interFrameInterval = 0;
pLinkDynPrm->mvAccuracy = 0;
pLinkDynPrm->inputFrameRate = 30;
pLinkDynPrm->rcAlg = 0;
pLinkDynPrm->qpMin = 0;
pLinkDynPrm->qpMax = 0;
pLinkDynPrm->qpInit = -1;
pLinkDynPrm->vbrDuration = 0;
pLinkDynPrm->vbrSensitivity = 0;
break;
case '1': /* H264 */
pLinkChPrm->format = SYSTEM_IVIDEO_H264HP;
pLinkChPrm->profile = 100;
pLinkChPrm->maxBitRate = -1;
pLinkChPrm->encodingPreset = SYSTEM_XDM_MED_SPEED_HIGH_QUALITY;
/* Set to SYSTEM_XDM_USER_DEFINED if SEI/meta data needs to be enabled */
/* pLinkChPrm->encodingPreset = SYSTEM_XDM_USER_DEFINED; */
pLinkChPrm->rateControlPreset = SYSTEM_IVIDEO_LOW_DELAY;
pLinkChPrm->enableHighSpeed = FALSE;
pLinkChPrm->enableSVCExtensionFlag = FALSE;
pLinkChPrm->IDRFrameInterval = 1;
pLinkDynPrm->intraFrameInterval = 30;
pLinkDynPrm->interFrameInterval = 1;
pLinkDynPrm->mvAccuracy = SYSTEM_IVIDENC2_MOTIONVECTOR_QUARTERPEL;
pLinkDynPrm->qpMax = 51;
pLinkDynPrm->qpInit = 25;
pLinkDynPrm->vbrDuration = 8;
pLinkDynPrm->maxPicSizeRatioI = 640;
break;
  • my issue is how to config encode link output 30FPS.
    when I set pLinkDynPrm->inputFrameRate = 60 , the output is 7.5, why ?
    Are you using enc/dec anywhere else also?
    IVA has some capability for encoding and it can not encode more than that.
    Can you please press p after running your usecase for 1 min and share that log.
    Anuj
  • Hi, Anuj
    The log as below:
    [HOST] [IPU2 ] 214.711065 s: CPU [DSP1 ] Statistics,
    [HOST] [IPU2 ] 214.711157 s: *************************
    [HOST] [IPU2 ] 214.711218 s:
    [HOST] [IPU2 ] 214.711279 s: LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 0.0%
    [HOST] [IPU2 ] 214.711401 s:
    [HOST] [IPU2 ] 214.711462 s: LOAD: TSK: MISC : 0.2%
    [HOST] [IPU2 ] 214.711553 s:
    [HOST] [IPU2 ] 214.711614 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
    [HOST] [IPU2 ] 214.711706 s:
    [HOST] [IPU2 ] 214.711736 s: SYSTEM: Sempahores Objects, 456 of 1050 free
    [HOST] [IPU2 ] 214.711828 s: SYSTEM: Task Objects , 91 of 100 free
    [HOST] [IPU2 ] 214.711950 s: SYSTEM: Clock Objects , 99 of 100 free
    [HOST] [IPU2 ] 214.712072 s: SYSTEM: Hwi Objects , 100 of 100 free
    [HOST] [IPU2 ] 214.712163 s:
    [HOST] [IPU2 ] 214.712194 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [HOST] [IPU2 ] 214.712346 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 521576 B (509 KB)
    [HOST] [IPU2 ] 214.712529 s:
    [HOST] [IPU2 ] 214.712560 s:
    [HOST] [IPU2 ] 214.712621 s: CPU [IPU2 ] Statistics,
    [HOST] [IPU2 ] 214.712682 s: *************************
    [HOST] [IPU2 ] 214.712743 s:
    [HOST] [IPU2 ] 214.712804 s: LOAD: CPU: 41.0% HWI: 8.8%, SWI:6.7%, Low Power: 0.0%
    [HOST] [IPU2 ] 214.712956 s:
    [HOST] [IPU2 ] 214.713017 s: LOAD: TSK: DUP0 : 1.0%
    [HOST] [IPU2 ] 214.713109 s: LOAD: TSK: DUP1 : 0.3%
    [HOST] [IPU2 ] 214.713231 s: LOAD: TSK: IPC_OUT_0 : 3.4%
    [HOST] [IPU2 ] 214.713322 s: LOAD: TSK: MERGE0 : 0.4%
    [HOST] [IPU2 ] 214.713444 s: LOAD: TSK: SYNC0 : 1.6%
    [HOST] [IPU2 ] 214.713536 s: LOAD: TSK: SYNC1 : 0.6%
    [HOST] [IPU2 ] 214.713627 s: LOAD: TSK: DISPLAY0 : 1.4%
    [HOST] [IPU2 ] 214.713749 s: LOAD: TSK: ENC0 : 1.3%
    [HOST] [IPU2 ] 214.713841 s: LOAD: TSK: CAPTURE : 2.3%
    [HOST] [IPU2 ] 214.714115 s: LOAD: TSK: VPE0 : 6.4%
    [HOST] [IPU2 ] 214.714207 s: LOAD: TSK: ALGORITHM0 : 1.2%
    [HOST] [IPU2 ] 214.714329 s: LOAD: TSK: GrpxSrc0 : 2.8%
    [HOST] [IPU2 ] 214.714420 s: LOAD: TSK: STAT_COLL : 2.5%
    [HOST] [IPU2 ] 214.714512 s: LOAD: TSK: ENC_PROCESS_TSK_0 : 2.3%
    [HOST] [IPU2 ] 214.714634 s: LOAD: TSK: MISC : -2.0%
    [HOST] [IPU2 ] 214.714725 s:
    [HOST] [IPU2 ] 214.714756 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
    [HOST] [IPU2 ] 214.714847 s:
    [HOST] [IPU2 ] 214.714908 s: SYSTEM: Sempahores Objects, 174 of 1050 free
    [HOST] [IPU2 ] 214.715030 s: SYSTEM: Task Objects , 17 of 100 free
    [HOST] [IPU2 ] 214.715122 s: SYSTEM: Clock Objects , 95 of 100 free
    [HOST] [IPU2 ] 214.715213 s: SYSTEM: Hwi Objects , 94 of 100 free
    [HOST] [IPU2 ] 214.715305 s:
    [HOST] [IPU2 ] 214.715335 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 250024 B (244 KB)
    [HOST] [IPU2 ] 214.715488 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [HOST] [IPU2 ] 214.717470 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 163736576 B (156 MB)
    [HOST] [IPU2 ] 214.717714 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047040 B (0 MB), Free size = 1037824 B (0 MB)
    [HOST] [IPU2 ] 214.717958 s:
    [HOST] [HOST ] 214.769474 s: chNum is 0
    [HOST] [HOST ] 214.836759 s: chNum is 0
    [HOST] [HOST ] 214.903586 s: chNum is 0
    [HOST] [HOST ] 214.903647 s: CBB_REC: 91 sec
    [HOST] [HOST ] 214.969499 s: chNum is 0
    [HOST] [HOST ] 215.036997 s: chNum is 0
    [HOST] [HOST ] 215.103672 s: chNum is 0
    [HOST] [HOST ] 215.169828 s: chNum is 0
    [HOST] [HOST ] 215.236625 s: chNum is 0
    [HOST] [HOST ] 215.303666 s: chNum is 0
    [HOST] [HOST ] 215.370554 s: chNum is 0
    [HOST] [HOST ] 215.436771 s: chNum is 0
    [HOST] [HOST ] 215.503599 s: chNum is 0
    [HOST] [HOST ] 215.570853 s: chNum is 0
    [HOST] [HOST ] 215.637589 s: chNum is 0
    0[HOST] [HOST ] 215.703806 s: chNum is 0
    [HOST] [IPU2 ] 215.722015 s:
    [HOST] [IPU2 ] 215.722106 s: Statistics Collector,
    [HOST] [IPU2 ] 215.722167 s:
    [HOST] [IPU2 ] 215.722198 s: STATISTIC Avg Data Peak Data
    [HOST] [IPU2 ] 215.722290 s: COLLECTOR MB/s MB/s
    [HOST] [IPU2 ] 215.722381 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.722473 s: SCI_EMIF1 RD+WR | 0.000000 0.000000
    [HOST] [IPU2 ] 215.722564 s: SCI_EMIF1 RD ONLY | 0.000000 0.000000
    [HOST] [IPU2 ] 215.722686 s: SCI_EMIF1 WR ONLY | 0.000000 0.000000
    [HOST] [IPU2 ] 215.722778 s: SCI_MA_MPU_P1 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.722869 s: SCI_MA_MPU_P2 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723022 s: SCI_DSS | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723144 s: SCI_IPU1 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723266 s: SCI_VIP1_P1 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723357 s: SCI_VIP1_P2 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723479 s: SCI_VPE_P1 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723571 s: SCI_VPE_P2 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723662 s: SCI_DSP1_MDMA | 0.000000 0.000000
    [HOST] [IPU2 ] 215.723784 s: SCI_DSP1_EDMA | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724089 s: SCI_EDMA_TC0_RD | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724211 s: SCI_EDMA_TC0_WR | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724303 s: SCI_EDMA_TC1_RD | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724425 s: SCI_EDMA_TC1_WR | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724516 s: CAL | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724638 s: SCI_IVA | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724760 s: SCI_GPU_P1 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.724852 s: SCI_GPU_P2 | 0.000000 0.000000
    [HOST] [IPU2 ] 215.725004 s: SCI_GMAC_SW | 0.000000 0.000000
    [HOST] [HOST ] 215.770542 s: chNum is 0
    [HOST] [IPU2 ] 215.830232 s:
    [HOST] [IPU2 ] 215.830323 s:
    [HOST] [IPU2 ] 215.835082 s: CAPTURE: VIP1 Slice1 PortB FRAME MODE
    [HOST] [IPU2 ] 215.835204 s:
    [HOST] [IPU2 ] 215.835265 s: [ CAPTURE ] Link Statistics,
    [HOST] [IPU2 ] 215.835326 s: ******************************
    [HOST] [IPU2 ] 215.835387 s:
    [HOST] [IPU2 ] 215.835448 s: Elapsed time = 173205 msec
    [HOST] [IPU2 ] 215.835539 s:
    [HOST] [IPU2 ] 215.835570 s: New data Recv = 239.79 fps
    [HOST] [IPU2 ] 215.835661 s: Get Full Buf Cb = 97.12 fps
    [HOST] [IPU2 ] 215.835753 s: Put Empty Buf Cb = 95.30 fps
    [HOST] [IPU2 ] 215.835844 s: Driver/Notify Cb = 239.79 fps
    [HOST] [IPU2 ] 215.835936 s:
    [HOST] [IPU2 ] 215.835997 s: Input Statistics,
    [HOST] [IPU2 ] 215.836058 s:
    [HOST] [IPU2 ] 215.836119 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.836210 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.836302 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.836393 s: 0 | 44.95 0. 0 0. 0 44.95
    [HOST] [IPU2 ] 215.836515 s: 1 | 44.95 0. 0 0. 0 44.95
    [HOST] [IPU2 ] 215.836668 s: 2 | 44.95 0. 0 0. 0 44.95
    [HOST] [IPU2 ] 215.836820 s: 3 | 44.95 0. 0 0. 0 44.95
    [HOST] [IPU2 ] 215.836973 s:
    [HOST] [IPU2 ] 215.837034 s: Output Statistics,
    [HOST] [IPU2 ] 215.837095 s:
    [HOST] [IPU2 ] 215.837125 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.837217 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.837308 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.837400 s: 0 | 0 44.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.837522 s: 1 | 0 44.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.837644 s: 2 | 0 44.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.837796 s: 3 | 0 44.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.837979 s:
    [HOST] [IPU2 ] 215.838040 s: [VIP1 Slice1 PortB] Statistics
    [HOST] [IPU2 ] 215.838132 s: ==============================
    [HOST] [IPU2 ] 215.838193 s: Number of request queued : 32923
    [HOST] [IPU2 ] 215.838345 s: Number of request dequeued: 24161
    [HOST] [IPU2 ] 215.838437 s: Overflow Count : 0
    [HOST] [IPU2 ] 215.838498 s:
    [HOST] [IPU2 ] 215.838559 s: CH | Q DQ Total Top Bot Total Top Bot Min/Max Min/Max Dropped Repeat Fid Desc
    [HOST] [IPU2 ] 215.838681 s: (I/S/CH) | Count Count Fields Fields Fields FPS FPS FPS Width Height Frames Frames Repeat Error
    [HOST] [IPU2 ] 215.838833 s: ---------------------------------------------------------------------------------------------------------------------------
    [HOST] [IPU2 ] 215.839199 s: 03.0.00 | 8236 8233 10977 5489 5488 59 29 29 720/720 240/240 2744 0 1 0
    [HOST] [IPU2 ] 215.839504 s: 03.0.01 | 8235 8233 10977 5489 5488 59 29 29 720/720 240/240 2744 0 1 0
    [HOST] [IPU2 ] 215.839809 s: 03.0.02 | 8236 8233 10977 5489 5488 59 29 29 720/720 240/240 2744 0 1 0
    [HOST] [IPU2 ] 215.840175 s: 03.0.03 | 8236 8233 10977 5489 5488 59 29 29 720/720 240/240 2744 0 1 0
    [HOST] [IPU2 ] 215.840297 s:
    [HOST] [IPU2 ] 215.844445 s:
    [HOST] [IPU2 ] 215.844537 s: [ VPE ] Link Statistics,
    [HOST] [IPU2 ] 215.844598 s: ******************************
    [HOST] [IPU2 ] 215.844659 s:
    [HOST] [IPU2 ] 215.844689 s: Elapsed time = 173204 msec
    [HOST] [IPU2 ] 215.844781 s:
    [HOST] [IPU2 ] 215.844811 s: New data Recv = 97.12 fps
    [HOST] [IPU2 ] 215.844903 s: Get Full Buf Cb = 62.6 fps
    [HOST] [IPU2 ] 215.845025 s: Put Empty Buf Cb = 114.95 fps
    [HOST] [IPU2 ] 215.845116 s: Driver/Notify Cb = 62.6 fps
    [HOST] [IPU2 ] 215.845177 s:
    [HOST] [IPU2 ] 215.845238 s: Input Statistics,
    [HOST] [IPU2 ] 215.845299 s:
    [HOST] [IPU2 ] 215.845330 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.845421 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.845513 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.845574 s: 0 | 44.95 14.98 0. 0 29.96
    [HOST] [IPU2 ] 215.845726 s: 1 | 44.95 14.99 0. 0 29.95
    [HOST] [IPU2 ] 215.845879 s: 2 | 44.95 14.98 0. 0 29.96
    [HOST] [IPU2 ] 215.846031 s: 3 | 44.95 14.98 0. 0 29.96
    [HOST] [IPU2 ] 215.846184 s:
    [HOST] [IPU2 ] 215.846214 s: Output Statistics,
    [HOST] [IPU2 ] 215.846275 s:
    [HOST] [IPU2 ] 215.846306 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.846397 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.846458 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.846550 s: 0 | 0 29.96 0. 0 0. 0
    [HOST] [IPU2 ] 215.846672 s: 1 | 0 29.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.846794 s: 2 | 0 29.96 0. 0 0. 0
    [HOST] [IPU2 ] 215.846946 s: 3 | 0 29.96 0. 0 0. 0
    [HOST] [IPU2 ] 215.847099 s:
    [HOST] [IPU2 ] 215.847160 s: [ VPE ] LATENCY,
    [HOST] [IPU2 ] 215.847190 s: ********************
    [HOST] [IPU2 ] 215.847251 s: Local Link Latency : Avg = 4159 us, Min = 1708 us, Max = 10035 us,
    [HOST] [IPU2 ] 215.847404 s: Source to Link Latency : Avg = 5724 us, Min = 1860 us, Max = 14183 us,
    [HOST] [IPU2 ] 215.847526 s:
    [HOST] [IPU2 ] 215.855243 s:
    [HOST] [IPU2 ] 215.855304 s: [ SYNC_LINK_0 ] Link Statistics,
    [HOST] [IPU2 ] 215.855365 s: ******************************
    [HOST] [IPU2 ] 215.855426 s:
    [HOST] [IPU2 ] 215.855487 s: Elapsed time = 173205 msec
    [HOST] [IPU2 ] 215.855548 s:
    [HOST] [IPU2 ] 215.855578 s: New data Recv = 91.96 fps
    [HOST] [IPU2 ] 215.855670 s: Get Full Buf Cb = 29.95 fps
    [HOST] [IPU2 ] 215.855761 s: Put Empty Buf Cb = 29.95 fps
    [HOST] [IPU2 ] 215.855822 s: Driver/Notify Cb = 30.30 fps
    [HOST] [IPU2 ] 215.855944 s:
    [HOST] [IPU2 ] 215.856005 s: Input Statistics,
    [HOST] [IPU2 ] 215.856066 s:
    [HOST] [IPU2 ] 215.856097 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.856188 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.856249 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.856341 s: 0 | 29.96 0. 1 0. 0 29.95
    [HOST] [IPU2 ] 215.856493 s: 1 | 29.95 0. 0 0. 0 29.95
    [HOST] [IPU2 ] 215.856615 s: 2 | 29.96 0. 1 0. 0 29.95
    [HOST] [IPU2 ] 215.856768 s: 3 | 29.96 0. 1 0. 0 29.95
    [HOST] [IPU2 ] 215.856920 s:
    [HOST] [IPU2 ] 215.856981 s: Output Statistics,
    [HOST] [IPU2 ] 215.857042 s:
    [HOST] [IPU2 ] 215.857073 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.857134 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.857378 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.857469 s: 0 | 0 29.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.857622 s:
    [HOST] [IPU2 ] 215.857683 s: [ SYNC_LINK_0 ] LATENCY,
    [HOST] [IPU2 ] 215.857744 s: ********************
    [HOST] [IPU2 ] 215.857805 s: Local Link Latency : Avg = 4190 us, Min = 61 us, Max = 24675 us,
    [HOST] [IPU2 ] 215.857957 s: Source to Link Latency : Avg = 10578 us, Min = 7213 us, Max = 17485 us,
    [HOST] [IPU2 ] 215.858079 s:
    [HOST] [IPU2 ] 215.875160 s:
    [HOST] [IPU2 ] 215.875221 s: [ ALG_DMA_SWMS ] Link Statistics,
    [HOST] [IPU2 ] 215.875312 s: ******************************
    [HOST] [IPU2 ] 215.875373 s:
    [HOST] [IPU2 ] 215.875404 s: Elapsed time = 173216 msec
    [HOST] [IPU2 ] 215.875495 s:
    [HOST] [IPU2 ] 215.875556 s: New data Recv = 29.95 fps
    [HOST] [IPU2 ] 215.875617 s:
    [HOST] [IPU2 ] 215.877142 s: Input Statistics,
    [HOST] [IPU2 ] 215.877203 s:
    [HOST] [IPU2 ] 215.877264 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.877356 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.877417 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.877508 s: 0 | 29.95 0. 0 0. 0 29.95
    [HOST] [IPU2 ] 215.877661 s:
    [HOST] [IPU2 ] 215.877691 s: Output Statistics,
    [HOST] [IPU2 ] 215.877752 s:
    [HOST] [IPU2 ] 215.877783 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.877874 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.877996 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.878088 s: 0 | 0 29.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.878240 s:
    [HOST] [IPU2 ] 215.878271 s: [ ALG_DMA_SWMS ] LATENCY,
    [HOST] [IPU2 ] 215.878332 s: ********************
    [HOST] [IPU2 ] 215.878393 s:
    [HOST] [IPU2 ] 215.886140 s:
    [HOST] [IPU2 ] 215.886201 s: [ SYNC_LINK_1 ] Link Statistics,
    [HOST] [IPU2 ] 215.886262 s: ******************************
    [HOST] [IPU2 ] 215.886323 s:
    [HOST] [IPU2 ] 215.886353 s: Elapsed time = 173217 msec
    [HOST] [IPU2 ] 215.886445 s:
    [HOST] [IPU2 ] 215.886475 s: New data Recv = 60.1 fps
    [HOST] [IPU2 ] 215.886567 s: Get Full Buf Cb = 59.90 fps
    [HOST] [IPU2 ] 215.886658 s: Put Empty Buf Cb = 14.98 fps
    [HOST] [IPU2 ] 215.886719 s: Driver/Notify Cb = 30.30 fps
    [HOST] [IPU2 ] 215.886811 s:
    [HOST] [IPU2 ] 215.886841 s: Input Statistics,
    [HOST] [IPU2 ] 215.886933 s:
    [HOST] [IPU2 ] 215.886994 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.887085 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.887146 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.887238 s: 0 | 29.95 0. 0 0. 0 29.95
    [HOST] [IPU2 ] 215.887390 s:
    [HOST] [IPU2 ] 215.887421 s: Output Statistics,
    [HOST] [IPU2 ] 215.887482 s:
    [HOST] [IPU2 ] 215.887512 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.887604 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.887665 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.887756 s: 0 | 0 29.95 0. 0 0. 0
    [HOST] [IPU2 ] 215.887909 s:
    [HOST] [IPU2 ] 215.887970 s: [ SYNC_LINK_1 ] LATENCY,
    [HOST] [IPU2 ] 215.888031 s: ********************
    [HOST] [IPU2 ] 215.888092 s: Local Link Latency : Avg = 50 us, Min = 30 us, Max = 518 us,
    [HOST] [IPU2 ] 215.888214 s: Source to Link Latency : Avg = 13045 us, Min = 9173 us, Max = 34322 us,
    [HOST] [IPU2 ] 215.888336 s:
    [HOST] [IPU2 ] 215.896449 s:
    [HOST] [IPU2 ] 215.896541 s: [ ENCODE ] Link Statistics,
    [HOST] [IPU2 ] 215.896602 s: ******************************
    [HOST] [IPU2 ] 215.896663 s:
    [HOST] [IPU2 ] 215.896724 s: Elapsed time = 173214 msec
    [HOST] [IPU2 ] 215.896785 s:
    [HOST] [IPU2 ] 215.896846 s: New data Recv = 29.95 fps
    [HOST] [IPU2 ] 215.896998 s: Release data Recv = 29.95 fps
    [HOST] [IPU2 ] 215.897059 s: Get Full Buf Cb = 89.85 fps
    [HOST] [IPU2 ] 215.897151 s: Put Empty Buf Cb = 59.92 fps
    [HOST] [IPU2 ] 215.897242 s:
    [HOST] [IPU2 ] 215.897273 s: Input Statistics,
    [HOST] [IPU2 ] 215.897334 s:
    [HOST] [IPU2 ] 215.897395 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.897486 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.897578 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.897639 s: 0 | 29.95 0. 0 0. 0 14.97
    [HOST] [IPU2 ] 215.897791 s: 1 | 29.95 0. 0 0. 0 14.97
    [HOST] [IPU2 ] 215.897974 s: ENCODE: Num process reqest count for chId: 0 = 2744
    [HOST] [IPU2 ] 215.898096 s: ENCODE: Num process complete count for chId: 0 = 2744
    [HOST] [IPU2 ] 215.898188 s: ENCODE: Num process reqest count for chId: 1 = 2744
    [HOST] [IPU2 ] 215.898279 s: ENCODE: Num process complete count for chId: 1 = 2744
    [HOST] [IPU2 ] 215.898401 s:
    [HOST] [IPU2 ] 215.898432 s: [ ENCODE ] LATENCY,
    [HOST] [IPU2 ] 215.898493 s: ********************
    [HOST] [IPU2 ] 215.898554 s: Local Link Latency : Avg = 12404 us, Min = 9425 us, Max = 40963 us,
    [HOST] [IPU2 ] 215.898706 s: Source to Link Latency : Avg = 24631 us, Min = 19345 us, Max = 77975 us,
    [HOST] [IPU2 ] 215.898828 s:
    [HOST] [IPU2 ] 215.898889 s: HDVICP-ID: 0
    [HOST] [IPU2 ] 215.899103 s: All percentage figures are based of totalElapsedTime
    [HOST] [IPU2 ] 215.899225 s:
    [HOST] [IPU2 ] totalAcquire2Wait :1 %
    [HOST] [IPU2 ] totalWait2Isr :18 %
    [HOST] [IPU2 ] totalIsr2Done :0 %
    [HOST] [IPU2 ] totalWait2Done :19 %
    [HOST] [IPU2 ] totalDone2Release :0 %
    [HOST] [IPU2 ] totalAcquire2Release :22 %
    [HOST] [IPU2 ] totalRelease2AcquireDelay :77 %
    [HOST] [IPU2 ] totalElapsedTime in msec : 183119
    [HOST] [IPU2 ] numAccessCnt: 5488
    [HOST] [IPU2 ] 215.899560 s: IVA-FPS : 29
    [HOST] [IPU2 ] 215.899621 s: Average time spent per frame in microsec: 6006
    [HOST] [IPU2 ] 215.899713 s:
    [HOST] [IPU2 ] 215.904105 s:
    [HOST] [IPU2 ] 215.904166 s: [ IPC_OUT_0 ] Link Statistics,
    [HOST] [IPU2 ] 215.904227 s: ******************************
    [HOST] [IPU2 ] 215.904288 s:
    [HOST] [IPU2 ] 215.904349 s: Elapsed time = 173212 msec
    [HOST] [IPU2 ] 215.904410 s:
    [HOST] [IPU2 ] 215.904471 s: New data Recv = 29.95 fps
    [HOST] [IPU2 ] 215.904532 s: Release data Recv = 30.0 fps
    [HOST] [IPU2 ] 215.904623 s: Driver/Notify Cb = 129.95 fps
    [HOST] [IPU2 ] 215.904684 s:
    [HOST] [IPU2 ] 215.904745 s: Input Statistics,
    [HOST] [IPU2 ] 215.904806 s:
    [HOST] [IPU2 ] 215.904837 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.904959 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.905050 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.905142 s: 0 | 14.98 0. 0 0. 0 14.98
    [HOST] [IPU2 ] 215.905264 s: 1 | 14.98 0. 0 0. 0 14.98
    [HOST] [IPU2 ] 215.905416 s:
    [HOST] [IPU2 ] 215.905447 s: Output Statistics,
    [HOST] [IPU2 ] 215.905508 s:
    [HOST] [IPU2 ] 215.905538 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.905630 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.905691 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.905782 s: 0 | 0 14.98 0. 0 0. 0
    [HOST] [IPU2 ] 215.905965 s: 1 | 0 14.98 0. 0 0. 0
    [HOST] [IPU2 ] 215.906087 s:
    [HOST] [IPU2 ] 215.906148 s: [ IPC_OUT_0 ] LATENCY,
    [HOST] [IPU2 ] 215.906209 s: ********************
    [HOST] [IPU2 ] 215.906270 s: Local Link Latency : Avg = 13 us, Min = 0 us, Max = 274 us,
    [HOST] [IPU2 ] 215.906392 s: Source to Link Latency : Avg = 24896 us, Min = 19681 us, Max = 78280 us,
    [HOST] [IPU2 ] 215.906514 s:
    [HOST] [IPU2 ] 215.911883 s:
    [HOST] [IPU2 ] 215.912005 s: [ DISPLAY ] Link Statistics,
    [HOST] [IPU2 ] 215.912066 s: ******************************
    [HOST] [IPU2 ] 215.912127 s:
    [HOST] [IPU2 ] 215.912188 s: Elapsed time = 173208 msec
    [HOST] [IPU2 ] 215.912249 s:
    [HOST] [IPU2 ] 215.912310 s: New data Recv = 62.6 fps
    [HOST] [IPU2 ] 215.912371 s: Driver/Notify Cb = 59.96 fps
    [HOST] [IPU2 ] 215.912462 s:
    [HOST] [IPU2 ] 215.912493 s: Input Statistics,
    [HOST] [IPU2 ] 215.912554 s:
    [HOST] [IPU2 ] 215.912615 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.912676 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.912767 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.912859 s: 0 | 29.96 0. 0 0. 0 29.96
    [HOST] [IPU2 ] 215.913011 s: 1 | 29.96 29.96 0. 0 0. 0
    [HOST] [IPU2 ] 215.913164 s: 2 | 29.96 29.96 0. 0 0. 0
    [HOST] [IPU2 ] 215.913286 s: 3 | 29.96 29.96 0. 0 0. 0
    [HOST] [IPU2 ] 215.913438 s:
    [HOST] [IPU2 ] 215.913499 s: [ DISPLAY ] LATENCY,
    [HOST] [IPU2 ] 215.913560 s: ********************
    [HOST] [IPU2 ] 215.913621 s: Local Link Latency : Avg = 63 us, Min = 30 us, Max = 335 us,
    [HOST] [IPU2 ] 215.913743 s: Source to Link Latency : Avg = 5977 us, Min = 2348 us, Max = 14092 us,
    [HOST] [IPU2 ] 215.913865 s:
    [HOST] [IPU2 ] 215.913957 s:
    [HOST] [IPU2 ] 215.914018 s: [ DISPLAY VID1 ] Additional Statistics,
    [HOST] [IPU2 ] 215.914079 s: ************************************
    [HOST] [IPU2 ] 215.914170 s: Driver Queued = 5492 frames
    [HOST] [IPU2 ] 215.914231 s: Driver De-Queued = 5490 frames
    [HOST] [IPU2 ] 215.914292 s: Driver Displayed = 10983 frames
    [HOST] [IPU2 ] 215.914384 s: Driver Repeated = 5493 frames
    [HOST] [IPU2 ] 215.914445 s:
    [HOST] [IPU2 ] 215.914506 s: ##### DSS DISPC Underflow Count = 0 #####
    [HOST] [IPU2 ] 215.914567 s:
    [HOST] [IPU2 ] 215.929451 s:
    [HOST] [IPU2 ] 215.929512 s: [ DISPLAY ] Link Statistics,
    [HOST] [IPU2 ] 215.929573 s: ******************************
    [HOST] [IPU2 ] 215.929634 s:
    [HOST] [IPU2 ] 215.929695 s: Elapsed time = 173214 msec
    [HOST] [IPU2 ] 215.929756 s:
    [HOST] [IPU2 ] 215.929817 s: Driver/Notify Cb = 59.96 fps
    [HOST] [IPU2 ] 215.929878 s:
    [HOST] [IPU2 ] 215.929970 s: Input Statistics,
    [HOST] [IPU2 ] 215.930031 s:
    [HOST] [IPU2 ] 215.930061 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.930153 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.930244 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.930336 s:
    [HOST] [IPU2 ] 215.930397 s: [ DISPLAY ] LATENCY,
    [HOST] [IPU2 ] 215.930427 s: ********************
    [HOST] [IPU2 ] 215.930519 s:
    [HOST] [IPU2 ] 215.930580 s:
    [HOST] [IPU2 ] 215.930641 s: [ DISPLAY GRPX1 ] Additional Statistics,
    [HOST] [IPU2 ] 215.930702 s: ************************************
    [HOST] [IPU2 ] 215.930763 s: Driver Queued = 1 frames
    [HOST] [IPU2 ] 215.930854 s: Driver De-Queued = 0 frames
    [HOST] [IPU2 ] 215.930946 s: Driver Displayed = 10988 frames
    [HOST] [IPU2 ] 215.931037 s: Driver Repeated = 10988 frames
    [HOST] [IPU2 ] 215.931098 s:
    [HOST] [IPU2 ] 215.931159 s: ##### DSS DISPC Underflow Count = 0 #####
    [HOST] [IPU2 ] 215.931220 s:
    [HOST] [IPU2 ] 215.936710 s:
    [HOST] [IPU2 ] 215.936741 s: [ IPC_IN_0 ] Link Statistics,
    [HOST] [IPU2 ] 215.936832 s: ******************************
    [HOST] [IPU2 ] 215.936893 s:
    [HOST] [IPU2 ] 215.936985 s: Elapsed time = 173212 msec
    [HOST] [IPU2 ] 215.937046 s:
    [HOST] [IPU2 ] 215.937107 s:
    [HOST] [IPU2 ] 215.937137 s: Input Statistics,
    [HOST] [IPU2 ] 215.937198 s:
    [HOST] [IPU2 ] 215.937229 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.937320 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.937412 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.937503 s:
    [HOST] [IPU2 ] 215.937534 s: Output Statistics,
    [HOST] [IPU2 ] 215.937595 s:
    [HOST] [IPU2 ] 215.937656 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.937717 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.937808 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.938052 s:
    [HOST] [IPU2 ] 215.938083 s: [ IPC_IN_0 ] LATENCY,
    [HOST] [IPU2 ] 215.938144 s: ********************
    [HOST] [IPU2 ] 215.938205 s:
    [HOST] [IPU2 ] 215.938266 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ HOST -> IPU2 ] ,
    [HOST] [IPU2 ] 215.938357 s: ***************************************************************
    [HOST] [IPU2 ] 215.942536 s:
    [HOST] [IPU2 ] 215.942597 s: [ DECODE ] Link Statistics,
    [HOST] [IPU2 ] 215.942658 s: ******************************
    [HOST] [IPU2 ] 215.942719 s:
    [HOST] [IPU2 ] 215.942780 s: Elapsed time = 173213 msec
    [HOST] [IPU2 ] 215.942841 s:
    [HOST] [IPU2 ] 215.942902 s:
    [HOST] [IPU2 ] 215.943207 s: Input Statistics,
    [HOST] [IPU2 ] 215.943268 s:
    [HOST] [IPU2 ] 215.943298 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.943390 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.943481 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.943603 s: Num frames inside the codec for chId: 0 = 0
    [HOST] [IPU2 ] 215.943695 s: Num process reqest count for chId: 0 = 0
    [HOST] [IPU2 ] 215.943786 s: Num process complete count for chId: 0 = 0
    [HOST] [IPU2 ] 215.943878 s:
    [HOST] [IPU2 ] 215.943939 s: [ DECODE ] LATENCY,
    [HOST] [IPU2 ] 215.944000 s: ********************
    [HOST] [IPU2 ] 215.944061 s:
    [HOST] [IPU2 ] 215.944122 s: HDVICP-ID: 0
    [HOST] [IPU2 ] 215.944183 s: All percentage figures are based of totalElapsedTime
    [HOST] [IPU2 ] 215.944274 s:
    [HOST] [IPU2 ] 215.944580 s: IVA-FPS : 29
    [HOST] [IPU2 ] 215.944641 s: Average time spent per frame in microsec: 6006
    [HOST] [IPU2 ] 215.944732 s:
    [HOST] [IPU2 ] 215.948331 s:
    [HOST] [IPU2 ] 215.948392 s: [ DISPLAY ] Link Statistics,
    [HOST] [IPU2 ] 215.948453 s: ******************************
    [HOST] [IPU2 ] 215.948514 s:
    [HOST] [IPU2 ] 215.948575 s: Elapsed time = 173212 msec
    [HOST] [IPU2 ] 215.948636 s:
    [HOST] [IPU2 ] 215.948697 s:
    [HOST] [IPU2 ] 215.948728 s: Input Statistics,
    [HOST] [IPU2 ] 215.948789 s:
    [HOST] [IPU2 ] 215.948819 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [IPU2 ] 215.948941 s: | FPS | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.949033 s: --------------------------------------------------
    [HOST] [IPU2 ] 215.949124 s:
    [HOST] [IPU2 ] 215.949185 s: Output Statistics,
    [HOST] [IPU2 ] 215.949246 s:
    [HOST] [IPU2 ] 215.949277 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [IPU2 ] 215.949368 s: | ID | FPS | FPS | FPS
    [HOST] [IPU2 ] 215.949429 s: ---------------------------------------------
    [HOST] [IPU2 ] 215.949643 s:
    [HOST] [IPU2 ] 215.949704 s: [ DISPLAY ] LATENCY,
    [HOST] [IPU2 ] 215.949765 s: ********************
    [HOST] [IPU2 ] 215.949826 s:
    [HOST] [IPU2 ] 215.949887 s:
    [HOST] [IPU2 ] 215.949978 s: [ DISPLAY VID3 ] Additional Statistics,
    [HOST] [IPU2 ] 215.950039 s: ************************************
    [HOST] [IPU2 ] 215.950131 s: Driver Queued = 0 frames
    [HOST] [IPU2 ] 215.950466 s: Driver De-Queued = 0 frames
    [HOST] [IPU2 ] 215.950588 s: Driver Displayed = 0 frames
    [HOST] [IPU2 ] 215.950832 s: Driver Repeated = 0 frames
    [HOST] [IPU2 ] 215.951168 s:
    [HOST] [IPU2 ] 215.951229 s: ##### DSS DISPC Underflow Count = 0 #####
    [HOST] [IPU2 ] 215.951595 s:
    [HOST] [IPU2 ] 215.956139 s: [CAPTURE] Buffer Q Status,
    [HOST] [IPU2 ] 215.956261 s: Empty Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
    [HOST] [IPU2 ] 215.956353 s: Full Q : Elements in Q = 0, Write Idx = 312, Read Idx = 312
    [HOST] [IPU2 ] 215.961660 s: [VPE OUT0] Buffer Q Status,
    [HOST] [IPU2 ] 215.961751 s: Empty Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
    [HOST] [IPU2 ] 215.961843 s: Full Q : Elements in Q = 0, Write Idx = 83, Read Idx = 83
    [HOST] [IPU2 ] 215.962026 s: [VPE OUT1] Buffer Q Status,
    [HOST] [IPU2 ] 215.962087 s: Empty Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
    [HOST] [IPU2 ] 215.962209 s: Full Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
    [HOST] [IPU2 ] 215.997315 s: ENCODE Out BufExt Q Status
    [HOST] [IPU2 ] 216.009973 s: Empty Q 0 -> count 6, wrPtr 120, rdPtr 114
    [HOST] [IPU2 ] 216.010095 s: Full Q -> count 0, wrPtr 112, rdPtr 112
    [HOST] [IPU2 ] 216.029372 s: DECODE OUT BufExt Q Status
    [HOST] [IPU2 ] 216.033001 s: Empty Q 0 -> count 3, wrPtr 3, rdPtr 0
    [HOST] [IPU2 ] 216.033123 s: Full Q -> count 0, wrPtr 0, rdPtr 0
    [HOST] [HOST ] 215.865338 s: chNum is 0
    [HOST] [HOST ] 215.908375 s:
    [HOST] [HOST ] 215.908375 s: [ IPC_IN_0 ] Link Statistics,
    [HOST] [HOST ] 215.908375 s: ******************************
    [HOST] [HOST ] 215.908406 s:
    [HOST] [HOST ] 215.908406 s: Elapsed time = 173214 msec
    [HOST] [HOST ] 215.908406 s: Get Full Buf Cb = 29.95 fps
    [HOST] [HOST ] 215.908406 s: Put Empty Buf Cb = 29.96 fps
    [HOST] [HOST ] 215.908406 s: Driver/Notify Cb = 29.95 fps
    [HOST] [HOST ] 215.908436 s:
    [HOST] [HOST ] 215.908436 s: Input Statistics,
    [HOST] [HOST ] 215.908436 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [HOST ] 215.908436 s: | FPS | FPS | FPS | FPS
    [HOST] [HOST ] 215.908436 s: --------------------------------------------------
    [HOST] [HOST ] 215.908467 s: 0 | 14.98 0. 0 0. 0 14.98
    [HOST] [HOST ] 215.908467 s: 1 | 14.98 0. 0 0. 0 14.98
    [HOST] [HOST ] 215.908467 s: Output Statistics,
    [HOST] [HOST ] 215.908497 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [HOST ] 215.908497 s: | ID | FPS | FPS | FPS
    [HOST] [HOST ] 215.908497 s: ---------------------------------------------
    [HOST] [HOST ] 215.908497 s: 0 | 0 14.98 0. 0 0. 0
    [HOST] [HOST ] 215.908497 s: 1 | 0 14.98 0. 0 0. 0
    [HOST] [HOST ] 215.908528 s:
    [HOST] [HOST ] 215.908528 s: [ IPC_IN_0 ] LATENCY,
    [HOST] [HOST ] 215.908528 s: ********************
    [HOST] [HOST ] 215.908528 s: Local Link Latency : Avg = 6 us, Min = 0 us, Max = 61 us,
    [HOST] [HOST ] 215.908528 s: Source to Link Latency : Avg = 26065 us, Min = 21084 us, Max = 81818 us,
    [HOST] [HOST ] 215.908558 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ IPU2 -> HOST ] ,
    [HOST] [HOST ] 215.908558 s: ***************************************************************
    [HOST] [HOST ] 215.908558 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 1208, Min = 915, Max = 13145
    [HOST] [HOST ] 215.908558 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 1126, Min = 824, Max = 13115
    [HOST] [HOST ] 215.932867 s:
    [HOST] [HOST ] 215.932867 s: [ NULL_SRC ] Link Statistics,
    [HOST] [HOST ] 215.932898 s: ******************************
    [HOST] [HOST ] 215.932898 s: Elapsed time = 173213 msec
    [HOST] [HOST ] 215.932959 s:
    [HOST] [HOST ] 215.932959 s: [ IPC_OUT_0 ] Link Statistics,
    [HOST] [HOST ] 215.932959 s: ******************************
    [HOST] [HOST ] 215.932959 s: Elapsed time = 173213 msec
    [HOST] [HOST ] 215.932989 s:
    [HOST] [HOST ] 215.932989 s: Input Statistics,
    [HOST] [HOST ] 215.932989 s: CH | In Recv | In Drop | In User Drop | In Process
    [HOST] [HOST ] 215.932989 s: | FPS | FPS | FPS | FPS
    [HOST] [HOST ] 215.932989 s: --------------------------------------------------
    [HOST] [HOST ] 215.932989 s: Output Statistics,
    [HOST] [HOST ] 215.933020 s:
    [HOST] [HOST ] 215.933020 s: CH | Out | Out | Out Drop | Out User Drop
    [HOST] [HOST ] 215.933020 s: | ID | FPS | FPS | FPS
    [HOST] [HOST ] 215.933020 s: ---------------------------------------------
    [HOST] [HOST ] 216.011620 s: chNum is 0
    [HOST] [HOST ] 216.033611 s:
    Can you simplify your usecase like below and try.
    Capture -> Dup -> Merge
    Dup -> Merge -> Enc -> Null.
    Anuj
  • Dup->Merge
    Dup->Merge
    I test about this, this only has a Dup->merge ?
    Basically from dup will be having 2 out queue and merge having 2 input queue.
    Anuj
  • I checked about this, It has only a output.
    thanks
  • I have solved about this. thanks.
  • I have solved about this, thanks
  • Can you give others an idea what you have done, please?
    Can you tell me your exact query.
    Anuj
  • Well, in my case it appeared to be pure coincidence. When I added DUP and MERGE links to my system, output frame rate for each channel became about twice lower then initial frame rate. But the key was in "about twice", cause in reality it was not exactly every second frame. The system just reached maximum of its throughput (for the settings used) and kept its maximum at about half frame rate for two channels.
    Sorry for distracting question
    GB
    What is FPS and resolution are you trying to encode.
    Are you trying to encode both stream as H264
    Please done use merge with dup, use it like below
    dup - > merge
    dup -> vpe -> merge.
    Anuj
  • Hi!
    If you don't mind conversation then:
    I'm trying to obtain next configuration (at DM385 machine)
    Camera provides FHD video (1920x1080) at 25fps
    and at the output I need two H.264 encoded channels from this video
    first - at 25 fps, second - at lower fps (lets say 5fps) and correspondingly lower bitrate.
    so far I'm doing that with cam->swosd->dup->merge->encoder, and decimating one channel at encoder.
    Processor, DDR clocks are not at maximum to reduce consumption, that's why system throughput is lower then FHD at 60 fps
    Please post a query on DM385 platform.
    Anuj
