Part Number: BEAGLEBN
I have a BBB and I want to flash the eMMC from Ethernet.
I have modified the hardware, so the AM3358 is configured to boot from Eth. This hardware modification is ok, since the process of eth booting starts correctly.
I also have been following this guide:
My Processor SDK Linux is 05_01_00_11.
I have encountered the above link a little out of date, with respect with my SDK. So, first, I have the following questions:
- "Creating and Gathering the Run-Time Files" section: I have not used the suggested patch: 0001-Change-finduuid-to-use-mmcdev.patch.gz, as I am getting some errors when applying it. It seems that it is an old patch and it may now not make sense. Am I right?
- I get an error when compiling u-boot for 'am335x_boneblack_config'. I have used 'am335x_evm_defconfig' instead. Is this ok?
- Preparing the flasher image --> Create a Network Bootable U-Boot Image: as I have just built u-boot for 'am335x_evm_defconfig' without the patch. I have used the previously generated 'u-boot.img' as 'u-boot-restore.img', and 'spl/u-boot-spl.bin' as 'spl/u-boot-spl-restore.bin'. Is this correct?
Finally, I am using CCS UniFlash 3.4.1.00012. The process of Ethernet booting starts but the eMMC is not flashed
I the serial port console:
- I see 'missing environment variable: pxeuuid' How can I solve this?
- Finally, the last message I see is 'EFI stub: Exiting boot services and installing virtual address map...'. Any clue about why it is not progressing?
I would really appreciate any help on this.
Here is the console output:
CCCCCCCC
U-Boot SPL 2018.01-00444-g96cdbefd5c (Nov 22 2018 - 12:37:04)
Trying to boot from eth device
** Bad device mmc 0 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Error: usb_ether address not set.
cpsw Waiting for PHY auto negotiation to complete... done
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.100.2 (5 ms)
Using cpsw device
TFTP from server 192.168.100.1; our IP address is 192.168.100.2
Filename 'u-boot-restore.img'.
Load address: 0x82000000
Loading: #################################################################
1.6 MiB/s
done
Bytes transferred = 646056 (9dba8 hex)
U-Boot 2018.01-00444-g96cdbefd5c (Nov 22 2018 - 12:37:04 +0100)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net: cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
SD/MMC found on device 1
** Invalid partition 2 **
## Error: "bootcmd_nand0" not defined
starting USB...
USB0: Port not available.
BOOTP broadcast 1
DHCP client bound to address 192.168.100.2 (4 ms)
Using cpsw device
Filename 'zImage'.
3.4 MiB/s
done
Bytes transferred = 6951424 (6a1200 hex)
Retrieving file: pxelinux.cfg/01-c8-df-84-d6-aa-0a
Using cpsw device
Filename 'pxelinux.cfg/01-c8-df-84-d6-aa-0a'.
Load address: 0x80100000
Loading: *
TFTP error: 'File not found or No Access' (1)
Not retrying...
Retrieving file: pxelinux.cfg/C0A86402
Using cpsw device
Filename 'pxelinux.cfg/C0A86402'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A8640'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A864'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A86'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A8'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0A'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C0'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/C'.
Loading: *
Not retrying...
Retrieving file: pxelinux.cfg/default-arm-am33xx
Using cpsw device
Filename 'pxelinux.cfg/default-arm-am33xx'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/default-arm'.
Loading: *
Not retrying...
Using cpsw device
Filename 'pxelinux.cfg/default'.
Loading: *
Not retrying...
Config file not found
starting USB...
BOOTP broadcast 1
Using cpsw device
Filename 'zImage'.
Load address: 0x80000000
3.4 MiB/s
done
## Executing script at 80000000
Wrong image format for "source" command
BOOTP broadcast 1
DHCP client bound to address 192.168.100.2 (9 ms)
Using cpsw device
Filename 'zImage'.
3.1 MiB/s
done
Using cpsw device
Filename 'dtb/am335x-boneblack.dtb'.
Load address: 0x88000000
Loading: ###
1.3 MiB/s
done
Bytes transferred = 36793 (8fb9 hex)
## Starting EFI application at 82000000 ...
Scanning disks on usb...
Scanning disks on mmc...
MMC Device 2 not found
MMC Device 3 not found
Found 6 disks
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
