  • Resolved
RTOS/TMS320C6678: How to build Linear Algebra Library DSP example under Windows
Expert 8000 points
Part Number: TMS320C6678
Tool/software: TI-RTOS
Hi Champs,
According to the steps in http://processors.wiki.ti.com/index.php/Processor_SDK_Linear_Algebra_Library#Build_and_Run_Examples,
DSP-only example in dsp folder: running on DSP through CCS and JTAG. Examples include:
  • Matrix multiplication (dgemm)
  • To run these examples, follow the steps listed below:
    • Set environment variable LINALG_DIR to <LINALG_installation_folder>, in addition to the environment variables listed in Rebuilding LINALG.
    • Go to folder <LINALG_installation_folder>/examples/dsponly
    • Type "make TARGET=<device_name>" to build the examples
    • Load the executable (.out file) to CCS and run
The step Type "make TARGET=<device_name>" to build the examples is excuted under linux, how to build the DSP-only example under windows?
Thanks.
Rgds
Shine
    Which TI RTOS version are you using?
    Yordan
     Please make sure you read the forum guidelines first.
  • Shine,
    I checked with the developer on this support and it appears that currently LinALG library and associated components only build in Linux so you will need to setup a Linux host machine for this build.
    Rahul
    Please click the
    This resolved my issue button on this post if the responses on this E2E thread answers your question.
