Other Parts Discussed in Thread: AM5718, PMP, DRA722, DP83848C, TMP102
Tool/software: Linux
We are using PROCESSOR-SDK-AM57X ti-processor-sdk-linux-am57xx-evm-05.02.00.10, using UART1 (ttyO0) and customized am571x-idk. Device trees are modifile as per am571x-idk.
Booting through sd card by creating bootable sd card using this(tisdk-rootfs-image-am57xx-evm.tar.xz) tarball, having a problem with kernal booting it stops at starting kernal ......... for a long time and moves forward then regulator and ldo voltages are disabling. Please find the log below.
Kindlly suggest what's wrong.
U-Boot SPL 2018.01-00558-gca1e85ecb5-dirty (Jan 12 2019 - 14:56:01)
DRA722-GP ES1.0
DRA722-GP ES1.0
Trying to boot from MMC1
no pinctrl state for default mode
U-Boot 2018.01-00558-gca1e85ecb5-dirty (Jan 12 2019 - 14:56:01 +0530)
CPU : DRA722-GP ES1.0
Model: TI AM5718 IDK
Board: AM571x IDRAM: 1 GiB
MMC: prop_name: pinctrl-0 mode: default index: 0
prop_name: pinctrl-6 mode: sdr104 index: 6
prop_name: pinctrl-4 mode: sdr50 index: 4
prop_name: pinctrl-5 mode: ddr50 index: 5
prop_name: pinctrl-3 mode: sdr25 index: 3
prop_name: pinctrl-2 mode: sdr12 index: 2
prop_name: pinctrl-1 mode: hs index: 1
prop_name: pinctrl-2 mode: ddr_1_8v index: 2
OMAP SD/MMC: 0, OMAP SD/MMC: 1
Warning: fastboot.board_rev: unknown board revision
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: Could not get PHY for ethernet@48484000: addr 0
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
WARNING: Could not determine device tree to use
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
1490 bytes read in 4 ms (363.3 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
1 bytes read in 3 ms (0 Bytes/s)
Already setup.
4022784 bytes read in 193 ms (19.9 MiB/s)
92417 bytes read in 20 ms (4.4 MiB/s)
Loading Device Tree to 8ffe6000, end 8ffff900 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79-gbde58ab01e (medha@medha) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #2 SMP PREEMPT Fri Jan 19
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5718 IDK
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] DRA722 ES1.0
[ 0.000000] percpu: Embedded 15 pages/cpu @ef64d000 s31372 r8192 d21876 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 210496
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=23d2adc0-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 644604K/848896K available (8192K kernel code, 347K rwdata, 2564K rodata, 2048K init, 282K bss, 24068K reserved, 180224)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc1056e98 ( 348 kB)
[ 0.000000] .bss : 0xc1058000 - 0xc109ebe0 ( 283 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000353] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000362] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000780] Console: colour dummy device 80x30
[ 0.000798] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000805] This ensures that you still see kernel messages. Please
[ 0.000812] update your kernel commandline.
[ 0.000833] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000848] pid_max: default: 32768 minimum: 301
[ 0.000954] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000967] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001507] CPU: Testing write buffer coherency: ok
[ 0.001543] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001743] /cpus/cpu@0 missing clock-frequency property
[ 0.001757] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039872] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.059876] Hierarchical SRCU implementation.
[ 0.080060] EFI services will not be available.
[ 0.099932] smp: Bringing up secondary CPUs ...
[ 0.099943] smp: Brought up 1 node, 1 CPU
[ 0.099952] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.099959] CPU: All CPU(s) started in HYP mode.
[ 0.099966] CPU: Virtualization extensions available.
[ 0.100399] devtmpfs: initialized
[ 0.117291] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[ 0.120073] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.120275] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.120292] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.124033] pinctrl core: initialized pinctrl subsystem
[ 0.124520] DMI not present or invalid.
[ 0.124766] NET: Registered protocol family 16
[ 0.130834] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.131707] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.323922] cpuidle: using governor ladder
[ 0.323957] cpuidle: using governor menu
[ 0.331782] OMAP GPIO hardware version 0.1
[ 0.356771] No ATAGs?
[ 0.356819] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.356833] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.357193] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.357204] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.357737] OMAP DMA hardware revision 0.0
[ 0.392322] edma 43300000.edma: memcpy is disabled
[ 0.395592] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.402438] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.404119] V3_3D: supplied by VMAIN
[ 0.406744] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.406954] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.407196] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.407444] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.409831] palmas 0-0058: Irq flag is 0x00000000
[ 0.442624] random: fast init done
[ 1.054708] random: crng init done
[ 64.182169] irq 166: nobody cared (try booting with the "irqpoll" option)
[ 64.182185] CPU: 0 PID: 22 Comm: irq/166-tps6591 Not tainted 4.14.79-gbde58ab01e #2
[ 64.182195] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 64.182203] Backtrace:
[ 64.182225] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[ 64.182237] r7:000000a6 r6:20000193 r5:00000000 r4:c1053d10
[ 64.182253] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[ 64.182272] [<c0931298>] (dump_stack) from [<c02820a4>] (__report_bad_irq+0x30/0xd4)
[ 64.182283] r7:000000a6 r6:c1022048 r5:00000000 r4:ef2ec300
[ 64.182297] [<c0282074>] (__report_bad_irq) from [<c0282498>] (note_interrupt+0x270/0x2bc)
[ 64.182309] r9:ef308000 r8:ef008000 r7:000000a6 r6:c1022048 r5:00000000 r4:ef2ec300
[ 64.182322] [<c0282228>] (note_interrupt) from [<c027f6c0>] (handle_irq_event_percpu+0x54/0x60)
[ 64.182333] r10:c02807ac r9:ef308000 r8:ef008000 r7:00000000 r6:c1022048 r5:ef2ec300
[ 64.182341] r4:00000002 r3:00000000
[ 64.182353] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[ 64.182361] r5:ef2ec364 r4:ef2ec300
[ 64.182374] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[ 64.182383] r7:00000000 r6:c1022048 r5:ef2ec364 r4:ef2ec300
[ 64.182396] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[ 64.182405] r7:00000000 r6:00000000 r5:000000a6 r4:c0e64b3c
[ 64.182416] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[ 64.182427] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[ 64.182438] r9:ef308000 r8:fa213000 r7:fa212000 r6:ef309e98 r5:fa21200c r4:c1004000
[ 64.182449] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[ 64.182457] Exception stack(0xef309e98 to 0xef309ee0)
[ 64.182466] 9e80: ef2ec364 00000800
[ 64.182477] 9ea0: ef2ec300 000093e7 ef2ec300 ef2ec364 ef2e9e80 ef2ec314 ef2ec300 ef2e9e80
[ 64.182487] 9ec0: c02807ac ef309ef4 ef309ef8 ef309ee8 c02806cc c094a000 20000013 ffffffff
[ 64.182497] r9:ef308000 r8:ef2ec300 r7:ef309ecc r6:ffffffff r5:20000013 r4:c094a000
[ 64.182511] [<c0949fd8>] (_raw_spin_unlock_irq) from [<c02806cc>] (irq_finalize_oneshot.part.1+0x84/0xe0)
[ 64.182524] [<c0280648>] (irq_finalize_oneshot.part.1) from [<c0280800>] (irq_thread_fn+0x54/0x5c)
[ 64.182533] r7:00000001 r6:00000000 r5:ef2ec300 r4:ef2e9e80
[ 64.182546] [<c02807ac>] (irq_thread_fn) from [<c0280ad0>] (irq_thread+0x14c/0x204)
[ 64.182554] r7:00000001 r6:00000000 r5:ffffe000 r4:ef2e9ea4
[ 64.182568] [<c0280984>] (irq_thread) from [<c0248ba8>] (kthread+0x164/0x16c)
[ 64.182578] r10:ef07d928 r9:c0280984 r8:ef2e9e80 r7:ef308000 r6:00000000 r5:ef2e9ec0
[ 64.182585] r4:ef2e9f00
[ 64.182598] [<c0248a44>] (kthread) from [<c0207d18>] (ret_from_fork+0x14/0x3c)
[ 64.182608] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0248a44
[ 64.182615] r4:ef2e9ec0
[ 64.182622] handlers:
[ 64.182631] [<c027f784>] irq_default_primary_handler threaded [<c06716a8>] regmap_irq_thread
[ 64.182651] Disabling IRQ #166
[ 64.183647] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[ 64.185196] SMPS1: supplied by evm_3v3_sd
[ 64.186901] SMPS2: supplied by evm_3v3_sd
[ 64.188561] SMPS3: supplied by evm_3v3_sd
[ 64.190223] SMPS4: supplied by evm_3v3_sd
[ 64.191741] SMPS5: supplied by evm_3v3_sd
[ 64.192991] SMPS12: supplied by evm_3v3_sd
[ 64.194016] LDO1: supplied by evm_3v3_sd
[ 64.194533] ldo1: Bringing 3000000uV into 3300000-3300000uV
[ 64.203665] LDO2: supplied by evm_3v3_sd
[ 64.213403] LDO3: supplied by evm_3v3_sd
[ 64.223425] LDO4: supplied by evm_3v3_sd
[ 64.233430] LDO5: supplied by evm_3v3_sd
[ 64.244582] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 64.244764] media: Linux media interface: v0.10
[ 64.244803] Linux video capture interface: v2.00
[ 64.244886] pps_core: LinuxPPS API ver. 1 registered
[ 64.244894] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 64.244914] PTP clock support registered
[ 64.244941] EDAC MC: Ver: 3.0.0
[ 64.252886] dmi: Firmware registration failed.
[ 64.253101] omap-mailbox: probe of 4883c000.mailbox failed with error -22
[ 64.253165] omap-mailbox: probe of 4883e000.mailbox failed with error -22
[ 64.253456] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 64.253557] omap-mailbox: probe of 48842000.mailbox failed with error -22
[ 64.253843] Advanced Linux Sound Architecture Driver Initialized.
[ 64.262959] clocksource: Switched to clocksource arch_sys_counter
[ 64.270554] NET: Registered protocol family 2
[ 64.271093] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 64.271157] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 64.271284] TCP: Hash tables configured (established 8192 bind 8192)
[ 64.271352] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 64.271384] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 64.271502] NET: Registered protocol family 1
[ 64.291856] RPC: Registered named UNIX socket transport module.
[ 64.291866] RPC: Registered udp transport module.
[ 64.291874] RPC: Registered tcp transport module.
[ 64.291881] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 64.292758] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 64.292888] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 64.293933] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 64.298094] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 64.308655] NFS: Registering the id_resolver key type
[ 64.308678] Key type id_resolver registered
[ 64.308687] Key type id_legacy registered
[ 64.308724] ntfs: driver 2.1.32 [Flags: R/O].
[ 64.310373] bounce: pool size: 64 pages
[ 64.310419] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 64.310430] io scheduler noop registered
[ 64.310439] io scheduler deadline registered
[ 64.310531] io scheduler cfq registered (default)
[ 64.310540] io scheduler mq-deadline registered
[ 64.310549] io scheduler kyber registered
[ 64.315018] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 64.315166] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[ 64.315239] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[ 64.315251] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 64.330287] vdd_3v3: supplied by ldo1
[ 64.330562] aic_dvdd_fixed: supplied by vdd_3v3
[ 64.373107] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 64.375870] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
[ 65.604768] console [ttyS0] enabled
[ 65.609188] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 44, base_baud = 3000000) is a 8250
[ 65.618815] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 45, base_baud = 3000000) is a 8250
[ 65.628414] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 46, base_baud = 3000000) is a 8250
[ 65.638958] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 65.646094] DSS: OMAP DSS rev 6.1
[ 65.650523] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 65.669912] brd: module loaded
[ 65.678483] loop: module loaded
[ 65.684447] libphy: Fixed MDIO Bus: probed
[ 65.742978] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 65.750672] davinci_mdio 48485000.mdio: detected phy mask fffffdff
[ 65.769471] libphy: 48485000.mdio: probed
[ 65.773558] davinci_mdio 48485000.mdio: phy[9]: device 48485000.mdio:09, driver NS DP83848C 10/100 Mbps PHY
[ 65.784036] cpsw 48484000.ethernet: No slave[1] phy_id, phy-handle, or fixed-link property
[ 65.792361] cpsw 48484000.ethernet: Detected MACID = 5c:f8:21:3d:51:2a
[ 65.799040] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 65.805463] cpsw 48484000.ethernet: ALE Table size 1024
[ 65.810721] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 65.817785] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 65.826211] i2c /dev entries driver
[ 65.830401] IR NEC protocol handler initialized
[ 65.834978] IR RC5(x/sz) protocol handler initialized
[ 65.840050] IR RC6 protocol handler initialized
[ 65.844611] IR JVC protocol handler initialized
[ 65.849158] IR Sony protocol handler initialized
[ 65.853807] IR SANYO protocol handler initialized
[ 65.858529] IR Sharp protocol handler initialized
[ 65.863478] IR MCE Keyboard/mouse protocol handler initialized
[ 65.869335] IR XMP protocol handler initialized
[ 65.876006] tmp102 0-0049: initialized
[ 65.882229] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[ 65.889902] sdhci: Secure Digital Host Controller Interface driver
[ 65.896125] sdhci: Copyright(c) Pierre Ossman
[ 65.900975] sdhci-pltfm: SDHCI platform and OF driver helper
[ 65.907717] ledtrig-cpu: registered to indicate activity on CPUs
[ 65.917547] NET: Registered protocol family 10
[ 65.932753] Segment Routing with IPv6
[ 65.936558] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 65.942941] NET: Registered protocol family 17
[ 65.947648] Key type dns_resolver registered
[ 65.952053] omap_voltage_late_init: Voltage driver support not added
[ 65.958455] Power Management for TI OMAP4+ devices.
[ 65.963608] Registering SWP/SWPB emulation handler
[ 65.980833] dmm 4e000000.dmm: workaround for errata i878 in use
[ 65.988449] dmm 4e000000.dmm: initialized all PAT entries
[ 65.995072] hctosys: unable to open rtc device (rtc0)
[ 66.000718] pbias_mmc_omap5: disabling
[ 66.004552] ALSA device list:
[ 66.007533] No soundcards found.
[ 66.011609] Waiting for root device PARTUUID=23d2adc0-02...
