Other Parts Discussed in Thread: TMDSICE3359
I am trying to Program & Debug the TMDSICE3359 evaluation board using Code Composer Studio V8 (8.3.0.0000) and Spectrum Digit
al XDS200 JTAG Emulator.
I have selected the "Connection" as Texas Instruments XDS2XX USB Debug Probe and "Board or Device" as ICE_AM3359.
I am getting the following error when pressing Test connection option.
[Start: Texas Instruments XDS2xx USB Debug Probe_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
/home/itsadmin/.ti/ti/0/0/BrdDat/testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 560/2xx-class product.
This utility will load the program 'xds2xxu.out'.
The library build date was 'Nov 20 2018'.
The library build time was '23:42:49'.
The library package version is '8.0.903.2'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-183' (0xffffff49).
The title is 'SC_ERR_CTL_CBL_BREAK_FAR'.
The explanation is:
The controller has detected a cable break far-from itself.
The user must connect the cable/pod to the target.
[End: Texas Instruments XDS2xx USB Debug Probe_0]
[Result]
The explanation is:
and the following error occurred during Launching the saved configuration file
I am using Ubuntu 14.04 64bit OS.
kindly suggest any methods to resolve the issue.
thanks
Mobin P K
