Part Number: EVMK2H
Tool/software: Linux
I've been trying to boot a Linux Kernel using U-Boot, and have successfully done so.
But for some reason not all of the 4 ARM Cores are being activated in the process (Only CPU0 was activated).
In the log file (see attached), it was written that though the secondary CPUs were being brought up, CPU1, CPU2, CPU3 still failed to boot.
Is there some of config file that must be edited to enable these secondary CPUs in order to run with all 4 ARM Cores?
Thank you!
Creating 1 MTD partitions on "nand0": 0x000000180000-0x000008000000 : "mtd=2" UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: fixable bit-flip detected at PEB 46 UBI: fixable bit-flip detected at PEB 124 UBI: fixable bit-flip detected at PEB 125 UBI: fixable bit-flip detected at PEB 153 UBI: fixable bit-flip detected at PEB 164 UBI: fixable bit-flip detected at PEB 168 UBI: fixable bit-flip detected at PEB 257 UBI: fixable bit-flip detected at PEB 354 UBI: fixable bit-flip detected at PEB 840 UBI: fixable bit-flip detected at PEB 872 UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=2" UBI: MTD device size: 126 MiB UBI: number of good PEBs: 1010 UBI: number of bad PEBs: 2 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 2 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 1010 UBI: number of PEBs reserved for bad PEB handling: 10 UBI: max/mean erase counter: 3/1 UBIFS: mounted UBI device 0, volume 0, name "boot" UBIFS: mounted read-only UBIFS: file system size: 5079040 bytes (4960 KiB, 4 MiB, 40 LEBs) UBIFS: journal size: 1142785 bytes (1116 KiB, 1 MiB, 9 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: LZO UBIFS: reserved for root: 0 bytes (0 KiB) Loading file 'skern-keystone-evm.bin' to addr 0x0c5f0000 with size 45056 (0x0000b000)... Done ## installed monitor, freq [194560000], status 194560000 ## Booting kernel from Legacy Image at 88000000 ... Image Name: Linux Created: 2019-01-18 3:04:48 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3932672 Bytes = 3.8 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK ## Flattened Device Tree blob at 87000000 Booting using the fdt blob at 0x87000000 Loading Kernel Image ... OK OK Using Device Tree in place at 87000000, end 8700c985 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.79-gbde58ab01e (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT Thu Jan 17 07:40:55 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Texas Instruments Keystone 2 Kepler/Hawking EVM [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Switching physical address space to 0x800000000 [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp-common-memory@81f800000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x000000085e800000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 15 pages/cpu @dea1a000 s31308 r8192 d21940 u61440 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 228224 [ 0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.1.100://var/lib/tftpboot/66AK2H/rootfs5.02/extra,v3,tcp rw,rsize=4096,wsize=4096 ip=192. 168.1.101:::::eth0:off [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 860888K/917504K available (8192K kernel code, 293K rwdata, 2568K rodata, 2048K init, 281K bss, 23848K reserved, 32768K cma-reserved, 368640K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB) [ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB) [ 0.000000] .data : 0xc1000000 - 0xc10497d8 ( 294 kB) [ 0.000000] .bss : 0xc104b000 - 0xc10914e0 ( 282 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] arch_timer: cp15 timer(s) running at 194.56MHz (virt). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2cdf1a5923, max_idle_ns: 440795209266 ns [ 0.000004] sched_clock: 56 bits at 194MHz, resolution 5ns, wraps every 4398046511101ns [ 0.000014] Switching to timer-based delay loop, resolution 5ns [ 0.000205] keystone timer clock @194560000 Hz [ 0.000416] Console: colour dummy device 80x30 [ 0.000446] Calibrating delay loop (skipped), value calculated using timer frequency.. 389.12 BogoMIPS (lpj=1945600) [ 0.000460] pid_max: default: 32768 minimum: 301 [ 0.000559] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000569] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001073] CPU: Testing write buffer coherency: ok [ 0.001101] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable [ 0.001307] /cpus/cpu@0 missing clock-frequency property [ 0.001333] /cpus/cpu@1 missing clock-frequency property [ 0.001360] /cpus/cpu@2 missing clock-frequency property [ 0.001387] /cpus/cpu@3 missing clock-frequency property [ 0.001397] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.039990] Setting up static identity map for 0x80200000 - 0x80200138 [ 0.059993] Hierarchical SRCU implementation. [ 0.080154] EFI services will not be available. [ 0.100042] smp: Bringing up secondary CPUs ... [ 0.170143] CPU1: failed to boot: -22 [ 0.240229] CPU2: failed to boot: -22 [ 0.310315] CPU3: failed to boot: -22 [ 0.310367] smp: Brought up 1 node, 1 CPU [ 0.310376] SMP: Total of 1 processors activated (389.12 BogoMIPS). [ 0.310384] CPU: All CPU(s) started in SVC mode. [ 0.310747] devtmpfs: initialized [ 0.316946] random: get_random_u32 called from bucket_table_alloc+0x104/0x22c with crng_init=0 [ 0.320430] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.320643] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.320657] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.321437] pinctrl core: initialized pinctrl subsystem [ 0.321804] DMI not present or invalid. [ 0.322018] NET: Registered protocol family 16 [ 0.331144] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.331780] cpuidle: using governor ladder [ 0.331809] cpuidle: using governor menu [ 0.331916] No ATAGs? [ 0.331944] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.331954] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.373809] media: Linux media interface: v0.10 [ 0.373841] Linux video capture interface: v2.00 [ 0.373909] pps_core: LinuxPPS API ver. 1 registered [ 0.373917] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.373934] PTP clock support registered [ 0.373958] EDAC MC: Ver: 3.0.0 [ 0.380474] dmi: Firmware registration failed. [ 0.380585] Advanced Linux Sound Architecture Driver Initialized. [ 0.390560] clocksource: Switched to clocksource arch_sys_counter [ 0.396616] NET: Registered protocol family 2 [ 0.397029] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.397062] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.397120] TCP: Hash tables configured (established 4096 bind 4096) [ 0.397194] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.397215] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.397319] NET: Registered protocol family 1 [ 0.417704] RPC: Registered named UNIX socket transport module. [ 0.417713] RPC: Registered udp transport module. [ 0.417720] RPC: Registered tcp transport module. [ 0.417727] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.418087] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.418288] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.418868] platform alarmtimer: set dma_pfn_offset00780000 [ 0.419490] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 0.423193] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.433679] NFS: Registering the id_resolver key type [ 0.433700] Key type id_resolver registered [ 0.433707] Key type id_legacy registered [ 0.433741] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.435223] bounce: pool size: 64 pages [ 0.435263] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.435273] io scheduler noop registered [ 0.435281] io scheduler deadline registered [ 0.435362] io scheduler cfq registered (default) [ 0.435371] io scheduler mq-deadline registered [ 0.435379] io scheduler kyber registered [ 0.435599] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28 [ 0.436243] ti,keystone-serdes 232a000.phy: Direct firmware load for ks2_gbe_serdes.bin failed with error -2 [ 0.436256] ti,keystone-serdes 232a000.phy: can't get any serdes init fw [ 0.436266] ti,keystone-serdes 232a000.phy: serdes procider init failed -19 [ 0.451057] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192 [ 0.451194] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek e0fa0000, reg_status e0967000, reg_config e0969000, reg_region e096b000, reg_push e0fe0000, re g_pop e1020000 [ 0.451207] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 8192, number of queues 8192 [ 0.451333] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek e1060000, reg_status e096d400, reg_config e096f000, reg_region e0971000, reg_push e10a0000, reg_pop e10e0000 [ 0.451473] keystone-navigator-qmss soc:qmss@2a40000: failed to get firmware for pdsp [ 0.453013] keystone-navigator-qmss soc:qmss@2a40000: pdsp id 0 not started for range acc-low-0 [ 0.453765] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24 [ 0.490752] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.490812] platform serial8250: set dma_pfn_offset00780000 [ 0.492873] console [ttyS0] disabled [ 0.492921] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 12160000) is a TI DA8xx/66AK2x [ 1.326642] console [ttyS0] enabled [ 1.330856] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 27, base_baud = 12160000) is a TI DA8xx/66AK2x [ 1.363242] brd: module loaded [ 1.371829] loop: module loaded [ 1.376950] spi_davinci 21000400.spi: DMA is not supported (-19) [ 1.383728] m25p80 spi0.0: n25q128a11 (16384 Kbytes) [ 1.388729] 2 ofpart partitions found on MTD device spi0.0 [ 1.394279] Creating 2 MTD partitions on "spi0.0": [ 1.399088] 0x000000000000-0x000000080000 : "u-boot-spl" [ 1.405030] 0x000000080000-0x000001000000 : "misc" [ 1.410433] spi_davinci 21000400.spi: Controller at 0xe0f9e400 [ 1.416548] spi_davinci 21000600.spi: DMA is not supported (-19) [ 1.422866] spi_davinci 21000600.spi: Controller at 0xe0fdc600 [ 1.428946] spi_davinci 21000800.spi: DMA is not supported (-19) [ 1.435259] spi_davinci 21000800.spi: Controller at 0xe0fde800 [ 1.441492] platform Fixed MDIO bus.0: set dma_pfn_offset00780000 [ 1.447755] libphy: Fixed MDIO Bus: probed [ 1.510582] davinci_mdio 2090300.mdio: davinci mdio revision 1.5, bus freq 2500000 [ 1.518178] libphy: 2090300.mdio: probed [ 1.533611] davinci_mdio 2090300.mdio: phy[0]: device 2090300.mdio:00, driver Marvell 88E1111 [ 1.542209] davinci_mdio 2090300.mdio: phy[1]: device 2090300.mdio:01, driver Marvell 88E1111 [ 1.551356] ti,keystone-serdes 232a000.phy: Requested PHY is disabled [ 2.071579] ti,keystone-serdes 232a000.phy: Requested PHY is disabled [ 2.592352] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.3 [ 2.598816] netcp-1.0 2620110.netcp: ALE Table size 1024 [ 2.604182] netcp-1.0 2620110.netcp: cpts: overflow check period 350 (jiffies) [ 2.611447] netcp-1.0 2620110.netcp: CPTS: ref_clk_freq:583680000 calc_mult:3679214035 calc_shift:31 error:-1 nsec/sec [ 2.622925] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device [ 2.630091] i2c /dev entries driver [ 2.634284] IR NEC protocol handler initialized [ 2.638827] IR RC5(x/sz) protocol handler initialized [ 2.643909] IR RC6 protocol handler initialized [ 2.648452] IR JVC protocol handler initialized [ 2.653006] IR Sony protocol handler initialized [ 2.657636] IR SANYO protocol handler initialized [ 2.662364] IR Sharp protocol handler initialized [ 2.667081] IR MCE Keyboard/mouse protocol handler initialized [ 2.672942] IR XMP protocol handler initialized [ 2.678993] sdhci: Secure Digital Host Controller Interface driver [ 2.685209] sdhci: Copyright(c) Pierre Ossman [ 2.689793] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.696671] ledtrig-cpu: registered to indicate activity on CPUs [ 2.704256] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac [ 2.710650] nand: Micron MT29F4G08ABBDAHC [ 2.714671] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64 [ 2.722528] Bad block table found at page 262080, version 0x01 [ 2.728784] Bad block table found at page 262016, version 0x01 [ 2.734856] nand_read_bbt: bad block at 0x000000c80000 [ 2.740009] nand_read_bbt: bad block at 0x000000ca0000 [ 2.745245] 3 ofpart partitions found on MTD device 30000000.nand [ 2.751372] Creating 3 MTD partitions on "30000000.nand": [ 2.756789] 0x000000000000-0x000000100000 : "u-boot" [ 2.762401] 0x000000100000-0x000000180000 : "params" [ 2.767983] 0x000000180000-0x000020000000 : "ubifs" [ 2.777087] davinci_nand 30000000.nand: controller rev. 2.5 [ 2.783212] platform snd-soc-dummy: set dma_pfn_offset00780000 [ 2.790029] NET: Registered protocol family 10 [ 2.805305] Segment Routing with IPv6 [ 2.809020] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.815388] NET: Registered protocol family 17 [ 2.819975] Key type dns_resolver registered [ 2.824426] Registering SWP/SWPB emulation handler [ 2.833826] hctosys: unable to open rtc device (rtc0) [ 3.041078] netcp-1.0 2620110.netcp eth0: Link is Up - Unsupported (update phy-core.c)/Unsupported (update phy-core.c) - flow control off [ 3.055563] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 3.130567] (NULL net_device): Link is Down [ 3.134771] (NULL net_device): Link is Down [ 4.241648] netcp-1.0 2620110.netcp eth0: Link is Down [ 5.281876] netcp-1.0 2620110.netcp eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 5.310588] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 5.340629] IP-Config: Guessing netmask 255.255.255.0 [ 5.345696] IP-Config: Complete: [ 5.348935] device=eth0, hwaddr=20:c3:8f:48:2f:da, ipaddr=192.168.1.101, mask=255.255.255.0, gw=255.255.255.255 [ 5.359543] host=192.168.1.101, domain=, nis-domain=(none) [ 5.365516] bootserver=255.255.255.255, rootserver=192.168.1.100, rootpath= [ 5.383631] ALSA device list: [ 5.386605] No soundcards found. [ 5.418670] VFS: Mounted root (nfs filesystem) on device 0:14. [ 5.425121] devtmpfs: mounted [ 5.429173] Freeing unused kernel memory: 2048K [ 5.447437] random: fast init done [ 5.789216] systemd[1]: System time before build time, advancing clock. [ 5.838757] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid) [ 5.859954] systemd[1]: Detected architecture arm. Welcome to Arago 2018.10! [ 5.902144] systemd[1]: Set hostname to <k2hk-evm>. [ 6.481655] random: systemd: uninitialized urandom read (16 bytes read) [ 6.488559] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 6.520786] random: systemd: uninitialized urandom read (16 bytes read) [ 6.527516] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 6.606395] random: systemd: uninitialized urandom read (16 bytes read) [ 6.614776] systemd[1]: Created slice System Slice. [ OK ] Created slice System Slice. [ 6.651536] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 6.693077] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 6.731532] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 6.771528] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ OK ] Listening on Process Core Dump Socket. [ OK ] Reached target Swap. Mounting Temporary Directory (/tmp)... Mounting POSIX Message Queue File System... [ OK ] Listening on Journal Socket. Starting Create list of required st��…ce nodes for the current kernel... [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on Journal Socket (/dev/log). Starting Journal Service... [ OK ] Started Dispatch Password Requests to Console Directory Watch. Starting Load Kernel Modules... [ OK ] Created slice User and Session Slice. [ 7.213719] cmemk: loading out-of-tree module taints kernel. [ 7.220054] CMEMK module: reference Linux version 4.14.79 [ 7.229592] allocated heap buffer 0xc100000 of size 0x480000 [ OK 7.236044] cmemk initialized m] Reached target Slices. [ 7.260269] cryptodev: driver 1.9 loaded. Starting Remount Root and Kernel File Systems... [ 7.294165] NET: Registered protocol family 44 [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 7.312208] uio_module_drv soc:mpax: registered misc device mpax [ OK ] Reached target Paths. [ 7.336953] uio_module_drv soc:edma3: registered misc device edma3 [ 7.344063] uio_module_drv soc:secmgr: registered misc device secmgr [ 7.360141] uio_module_drv soc:qmss: registered misc device qmss [ OK ] Mounted Kernel Debug File System. [ 7.380126] uio_module_drv soc:hyperlink0: registered misc device hyperlink0 [ 7.389394] uio_module_drv soc:hyperlink1: registered misc device hyperlink1 [ 7.397654] uio_module_drv soc:srio: registered misc device srio [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Journal Service. [ OK ] Started Create list of required sta��…vice nodes for the current kernel. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Starting udev Coldplug all Devices... Starting Apply Kernel Variables... Mounting Kernel Configuration File System... Starting Create Static Device Nodes in /dev... Starting Flush Journal to Persistent Storage... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ 7.903356] systemd-journald[82]: Received request to flush runtime journal from PID 1 [ OK ] Reached target Local File Systems (Pre). Mounting /var/volatile... Mounting /media/ram... Starting udev Kernel Device Manager... [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. [ OK ] Started Flush Journal to Persistent Storage. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... [ OK ] Started Update UTMP about System Boot/Shutdow[ 8.624401] random: crng init done [ 8.629249] random: 7 urandom warning(s) missed due to ratelimiting n. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. [ 9.234340] keystone-rproc 10800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 9.311211] remoteproc remoteproc0: 10800000.dsp is available [ 9.355142] keystone-rproc 11800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 9.393079] remoteproc remoteproc1: 11800000.dsp is available [ OK ] Started udev Coldplug all Devices. [ 9.439127] keystone-rproc 12800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 9.480098] remoteproc remoteproc2: 12800000.dsp is available [ 9.519972] keystone-rproc 13800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ OK 9.563560] remoteproc remoteproc3: 13800000.dsp is available m] Reached target System Initialization. [ 9.594691] keystone-rproc 14800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ OK ] Started Daily Cleanup of Temp[ 9.635483] remoteproc remoteproc4: 14800000.dsp is available orary Directories. [ OK ] Started Daily rotation of log files. [ 9.661485] keystone-rproc 15800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 9.670541] remoteproc remoteproc5: 15800000.dsp is available [ OK ] Reached target Timers. [ 9.714657] keystone-rproc 16800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 9.766980] remoteproc remoteproc6: 16800000.dsp is available Starting Network Service... [ OK ] Listening on D-Bus System Message Bus Socket. [ 9.809255] keystone-rproc 17800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ OK ] Listening on RPCbind Server Activation Socket. [ 9.881001] remoteproc remoteproc7: 17800000.dsp is available [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ 9.994625] davinci-wdt 22f0080.wdt: heartbeat 60 sec [ OK ] Reached target Basic System. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Started D-Bus System Message Bus. [ 10.257212] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write [ 10.361526] keystone-usbphy 2620738.usb_phy: 2620738.usb_phy supply vcc not found, using dummy regulator [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. Starting run_srss_tc.service... Starting Ethernet Bridge Filtering Tables... Starting TI IPC Daemon... [ OK ] Started Periodic Command Scheduler. Starting telnetd.service... Starting softhsm-daemon.service... Starting Matrix GUI... Starting TI Multiproc Manager... [ OK ] Reached target Containers. Starting Login Service... [ OK ] Started Job spooling tools. Starting Print notice about GPLv3 packages... Starting System Logger Daemon... Starting RPC Bind Service... [ OK ] Started Network Service. [ OK ] Started run_srss_tc.service. [ OK ] Started Ethernet Bridge Filtering Tables. [ OK ] Started TI IPC Daemon. [ OK ] Started telnetd.service. [ OK ] Started Matrix GUI. [ OK ] Started RPC Bind Service. [ 11.890332] keystone-crypto soc:subsys@20c0000:crypto@0: crypto accelerator enabled [ 11.996663] registered dspmem misc device [ 12.050307] NET: Registered protocol family 15 [ OK ] Started softhsm-daemon.service. [ OK ] Found device /dev/ttyS0. [ OK ] Started TI Multiproc Manager. [ 13.135977] Initializing XFRM netlink socket [ OK ] Started System Logger Daemon. [ 14.982557] platform xhci-hcd.0.auto: set dma_pfn_offset00780000 [ 15.130350] usbcore: registered new interface driver usbfs [ 15.138922] usbcore: registered new interface driver hub [ 15.162703] usbcore: registered new device driver usb [ 15.212378] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 15.217904] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 15.232288] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x02010010 [ 15.245385] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000 [ 15.255642] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 15.264814] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.275352] usb usb1: Product: xHCI Host Controller [ 15.282169] usb usb1: Manufacturer: Linux 4.14.79-gbde58ab01e xhci-hcd [ 15.289363] usb usb1: SerialNumber: xhci-hcd.0.auto [ 15.305414] hub 1-0:1.0: USB hub found [ 15.310122] hub 1-0:1.0: 1 port detected [ 15.319161] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 15.328959] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 15.339103] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 15.347540] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 15.360120] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 15.378343] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.390996] usb usb2: Product: xHCI Host Controller [ 15.397305] usb usb2: Manufacturer: Linux 4.14.79-gbde58ab01e xhci-hcd [ 15.419043] usb usb2: SerialNumber: xhci-hcd.0.auto [ 15.434484] hub 2-0:1.0: USB hub found [ 15.438854] hub 2-0:1.0: 1 port detected *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash binutils-dev binutils bison-dev bison cifs-utils cpio cpp-symlinks cpp dosfstools elfutils-dev elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbc6x gdbserver gettext gstreamer1.0-libav gzip hidapi libasm1 libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm4 libgettextlib libgettextsrc libgmp10 libidn11 libmpc3 libmpfr4 libreadline-dev libreadline7 libunistring2 m4-dev m4 make nettle which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ OK ] Started Login Service. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. Starting TI MultiCore Tools Daemon... Starting thttpd.service... Starting bind.service... Starting syslog.service... [ OK ] Reached target Network. Starting Lightning Fast Webserver With Light System Requirements... [ OK ] Started Vsftpd ftp daemon. Starting Berkeley Internet Name Domain (DNS)... Starting Permit User Sessions... Starting Network Name Resolution... Starting Simple Network Management Protocol (SNMP) Daemon.... [ OK ] Started thttpd.service. [ OK ] Started Lightning Fast Webserver With Light System Requirements. [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS0. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started syslog.service. [ OK ] Started Network Name Resolution. [ OK ] Started bind.service. [FAILED] Failed to start Berkeley Internet Name Domain (DNS). See 'systemctl status named.service' for details. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting rng-tools.service... [ OK ] Started rng-tools.service. Starting gdbserverproxy.service... [ OK ] Started gdbserverproxy.service. Starting thermal-zone-init.service... Starting parse-ip.service... [ OK ] Started thermal-zone-init.service. [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ 21.423543] remoteproc remoteproc0: powering up 10800000.dsp [ 21.429230] remoteproc remoteproc0: Booting unspecified pre-loaded fw image [ 21.442392] remoteproc remoteproc0: registered virtio0 (type 7) [ 21.448335] remoteproc remoteproc0: remote processor 10800000.dsp is now up [ 21.465334] virtio_rpmsg_bus virtio0: rpmsg host is online [ 21.470895] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d [ 21.485092] remoteproc remoteproc1: powering up 11800000.dsp [ 21.494388] remoteproc remoteproc1: Booting unspecified pre-loaded fw image [ 21.508741] virtio_rpmsg_bus virtio1: rpmsg host is online [ 21.515187] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d [ 21.529658] remoteproc remoteproc1: registered virtio1 (type 7) [ 21.539966] remoteproc remoteproc1: remote processor 11800000.dsp is now up [ 21.574534] remoteproc remoteproc2: powering up 12800000.dsp [ 21.580220] remoteproc remoteproc2: Booting unspecified pre-loaded fw image [ 21.593283] virtio_rpmsg_bus virtio2: rpmsg host is online [ 21.598825] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d [ 21.612257] remoteproc remoteproc2: registered virtio2 (type 7) [ 21.618446] remoteproc remoteproc2: remote processor 12800000.dsp is now up [ 21.652924] remoteproc remoteproc3: powering up 13800000.dsp [ 21.658607] remoteproc remoteproc3: Booting unspecified pre-loaded fw image [ 21.670184] virtio_rpmsg_bus virtio3: rpmsg host is online [ 21.676637] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d [ 21.688342] remoteproc remoteproc3: registered virtio3 (type 7) [ 21.696337] remoteproc remoteproc3: remote processor 13800000.dsp is now up [ 21.727425] remoteproc remoteproc4: powering up 14800000.dsp [ 21.735340] remoteproc remoteproc4: Booting unspecified pre-loaded fw image [ 21.746435] virtio_rpmsg_bus virtio4: rpmsg host is online [ 21.752877] virtio_rpmsg_bus virtio4: creating channel rpmsg-proto addr 0x3d [ 21.764425] remoteproc remoteproc4: registered virtio4 (type 7) [ 21.773253] remoteproc remoteproc4: remote processor 14800000.dsp is now up [ 21.803165] remoteproc remoteproc5: powering up 15800000.dsp [ 21.808850] remoteproc remoteproc5: Booting unspecified pre-loaded fw image [ 21.822096] virtio_rpmsg_bus virtio5: rpmsg host is online [ 21.827640] virtio_rpmsg_bus virtio5: creating channel rpmsg-proto addr 0x3d [ 21.838831] remoteproc remoteproc5: registered virtio5 (type 7) [ 21.848560] remoteproc remoteproc5: remote processor 15800000.dsp is now up [ 21.878437] remoteproc remoteproc6: powering up 16800000.dsp [ 21.886220] remoteproc remoteproc6: Booting unspecified pre-loaded fw image [ 21.897562] virtio_rpmsg_bus virtio6: rpmsg host is online [ 21.904023] virtio_rpmsg_bus virtio6: creating channel rpmsg-proto addr 0x3d [ 21.915837] remoteproc remoteproc6: registered virtio6 (type 7) [ 21.924483] remoteproc remoteproc6: remote processor 16800000.dsp is now up [ 21.955259] remoteproc remoteproc7: powering up 17800000.dsp [ 21.963006] remoteproc remoteproc7: Booting unspecified pre-loaded fw image [ 21.974538] virtio_rpmsg_bus virtio7: rpmsg host is online [ 21.980088] virtio_rpmsg_bus virtio7: creating channel rpmsg-proto addr 0x3d [ 21.991582] remoteproc remoteproc7: registered virtio7 (type 7) [ 21.998413] remoteproc remoteproc7: remote processor 17800000.dsp is now up [ OK ] Started TI MultiCore Tools Daemon. #>>>>> LCD 12 IP Address: 192.168.1.101 [ OK ] Started parse-ip.service. [ OK ] Reached target Multi-User System. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org k2hk-evm ttyS0 Arago 2018.10 k2hk-evm ttyS0
