Tool/software: Linux
Hello Team,
We use custom h/w and software based on DRA746 and VSDK 3.04.
We are facing one issue with HD video playback if video files framerate is 60fps, then if play in slow motion, if we convert that video from 60fps to 30fps then that file plays properly.
As per your previous inputs TI supports one IVA which can decode 1x1080@60 or 2x1080p@30.
In our full loaded system(navigation is running in parallel) when we play HD video @60 fps then playback is not smooth. But if we play just video playback by removing all other loads then it plays properly(through command line), but in between flicking is there.
Sharing you the original video and observation video through portal.
Ikshwaku
