Other Parts Discussed in Thread: OMAPL138
I have those uart codes, which i could build and debug in the processor, But after debugging when i try to run its not showing any results.
* \file uartEcho.c
* \brief This is a sample application file which invokes some APIs
* from the UART device abstraction library to perform configuration,
* transmission and reception operations.
* Copyright (C) 2012 Texas Instruments Incorporated -
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "hw_psc_OMAPL138.h"
#include "soc_OMAPL138.h"
#include "interrupt.h"
#include "lcdkOMAPL138.h"
#include "hw_types.h"
#include "uart.h"
#include "psc.h"
#include "stdio.h"
/* LOCAL FUNCTION PROTOTYPES */
static void ConfigureIntUART(void);
static void SetupInt(void);
static void UARTIsr(void);
/* GLOBAL VARIABLES */
char txArray[] = "StarterWare UART echo application\n\r";
/* LOCAL FUNCTION DEFINITIONS */
int main(void)
unsigned int intFlags = 0;
unsigned int config = 0;
/* Enabling the PSC for UART2.*/
PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_UART2, PSC_POWERDOMAIN_ALWAYS_ON,
PSC_MDCTL_NEXT_ENABLE);
/* Setup PINMUX */
UARTPinMuxSetup(2, FALSE);
/* Enabling the transmitter and receiver*/
UARTEnable(SOC_UART_2_REGS);
/* 1 stopbit, 8-bit character, no parity */
config = UART_WORDL_8BITS;
/* Configuring the UART parameters*/
UARTConfigSetExpClk(SOC_UART_2_REGS, SOC_UART_2_MODULE_FREQ,
BAUD_115200, config,
UART_OVER_SAMP_RATE_16);
/* Enabling the FIFO and flushing the Tx and Rx FIFOs.*/
UARTFIFOEnable(SOC_UART_2_REGS);
/* Setting the UART Receiver Trigger Level*/
UARTFIFOLevelSet(SOC_UART_2_REGS, UART_RX_TRIG_LEVEL_1);
** Enable AINTC to handle interrupts. Also enable IRQ interrupt in ARM
** processor.
SetupInt();
/* Configure AINTC to receive and handle UART interrupts. */
ConfigureIntUART();
/* Preparing the 'intFlags' variable to be passed as an argument.*/
intFlags |= (UART_INT_LINE_STAT | \
UART_INT_TX_EMPTY | \
UART_INT_RXDATA_CTI);
/* Enable the Interrupts in UART.*/
UARTIntEnable(SOC_UART_2_REGS, intFlags);
while(1);
** \brief Interrupt Service Routine(ISR) to be executed on UART interrupts.
** Depending on the source of interrupt, this
** 1> writes to the serial communication console, or
** 2> reads from the serial communication console, or
** 3> reads the byte in RBR if receiver line error has occured.
static void UARTIsr()
static unsigned int length = sizeof(txArray);
static unsigned int count = 0;
unsigned char rxData = 0;
unsigned int int_id = 0;
/* This determines the cause of UART2 interrupt.*/
int_id = UARTIntStatus(SOC_UART_2_REGS);
#ifdef _TMS320C6X
// Clear UART2 system interrupt in DSPINTC
IntEventClear(SYS_INT_UART2_INT);
#else
/* Clears the system interupt status of UART2 in AINTC. */
IntSystemStatusClear(SYS_INT_UARTINT2);
#endif
/* Checked if the cause is transmitter empty condition.*/
if(UART_INTID_TX_EMPTY == int_id)
if(0 < length)
/* Write a byte into the THR if THR is free. */
UARTCharPutNonBlocking(SOC_UART_2_REGS, txArray[count]);
length--;
count++;
if(0 == length)
/* Disable the Transmitter interrupt in UART.*/
UARTIntDisable(SOC_UART_2_REGS, UART_INT_TX_EMPTY);
/* Check if the cause is receiver data condition.*/
if(UART_INTID_RX_DATA == int_id)
rxData = UARTCharGetNonBlocking(SOC_UART_2_REGS);
UARTCharPutNonBlocking(SOC_UART_2_REGS, rxData);
/* Check if the cause is receiver line error condition.*/
if(UART_INTID_RX_LINE_STAT == int_id)
while(UARTRxErrorGet(SOC_UART_2_REGS))
/* Read a byte from the RBR if RBR has data.*/
return;
** \brief This function invokes necessary functions to configure the ARM
** processor and ARM Interrupt Controller(AINTC) to receive and
** handle interrupts.
#ifdef _TMS320C6X
// Initialize the DSP INTC
IntDSPINTCInit();
// Enable DSP interrupts globally
IntGlobalEnable();
#else
/* Initialize the ARM Interrupt Controller(AINTC). */
IntAINTCInit();
/* Enable IRQ in CPSR.*/
IntMasterIRQEnable();
/* Enable the interrupts in GER of AINTC.*/
IntGlobalEnable();
/* Enable the interrupts in HIER of AINTC.*/
IntIRQEnable();
#endif
** \brief This function confiugres the AINTC to receive UART interrupts.
#ifdef _TMS320C6X
IntRegister(C674X_MASK_INT4, UARTIsr);
IntEventMap(C674X_MASK_INT4, SYS_INT_UART2_INT);
IntEnable(C674X_MASK_INT4);
#else
/* Registers the UARTIsr in the Interrupt Vector Table of AINTC. */
IntRegister(SYS_INT_UARTINT2, UARTIsr);
/* Map the channel number 2 of AINTC to UART2 system interrupt. */
IntChannelSet(SYS_INT_UARTINT2, 2);
IntSystemEnable(SYS_INT_UARTINT2);
#endif
printf("h");
/****************************END OF FILE*************************************/
This is the program which i used.
Above is the build console.
