Part Number: EVMK2H
I am trying to update the UBOOT and Linux on an EVMK2HX module (stored in flash) to the pre-built files in the current version (06_00_00_07) and then upgrade the 2 GB EVMK2HX memory module to an 8 GB one. There appear to be a number of ways to do this, which seem to be somewhat inconsistent( to a newbie).
- The following steps for downloading the 06_00_00_07 SDK provided UBOOT image to NOR flash were gleaned from the documentation (mostly section 3.1.1.2.5). Are they correct?
- Setup a TFTP server on the local network, connect the EVMK2HX Ethernet and USB-to-Serial cables, set the boot switches to 0001, and boot the module.
- At the prompt on the serial connection, type:
- printenv (see EVs just to know what they are)
- env default –f –a
- saveenv
- setenv server_ip <TFTP Server IP address>
- setenv tftp_root <TFTP root directory where the UBI image is copied to>
- setenv name_uboot u-boot-spi.gph
- run get_uboot_net
- run burn_uboot_spi
2. Can the module be rebooted to see if the UBOOT load was successful, or should the Linux image be loaded prior to rebooting?
3. The 06_00_00_07 SDK Getting Started Guide section 1.1.4.2 indicates that the Linux image is written as a single ubi file(named tisdk-server-rootfs-image-k2h-evm.ubi), however a single tar.xz file is provided instead. How is that file converted into a ubi file that can be downloaded?
4. The following steps for downloading the 06_00_00_07 SDK provided Linux ubi file were gleaned from section 3.4 and section 3.3.6 question 3:
- Setup a TFTP server on the local network, connect the EVMK2HX Ethernet and USB-to-Serial cables, set the boot switches to 0001, and boot the module. (Skip this step if the answer to question 2 is to load Linux before rebooting)
- setenv name_ubi <the UBI image name>
- run get_ubi_net
- run burn_ubi
- setenv boot ubi
- saveenv
- boot
c. Test the changes by typing:
- bootmode #2
- reboot
5. If the EVMK2HX module does not boot after the above, what is the recovery mechanism? … Use the UART and BMC mechanism described by board-support/u-boot-2019 … /board/ti/ks2_evm/README
Just trying to make sure the steps are correct and a recovery path is known.
- bob g.
