Hi Processors Team:
I am using PSDKRA j7 06.00.00.00 to run ldc on emulation mode and target mode.
input and output image format is VX_DF_IMAGE_U8 , 256*128 luma pic.
I use a full remap table, size is 256*128, the mesh_img format is VX_DF_IMAGE_U32 256*128.
input pic and input mesh_img are same.
source code of graph is one file.
however, result are different.
below is emulation mode result:
below is target mode result:
below is part of my code:
obj->ldc_params.luma_interpolation_type = 1; //BILINEAR
obj->ldc_params.init_x = 0;
obj->ldc_params.init_y = 0;
obj->ldc_params.yc_mode= 0;
obj->ldc_region_params.enable = 1;
obj->ldc_region_params.out_block_width = 8;
obj->ldc_region_params.out_block_height = 8;
obj->ldc_region_params.pixel_pad = 0;
obj->ldc_mesh_params.mesh_frame_width = 256;
obj->ldc_mesh_params.mesh_frame_height = 128;
obj->ldc_mesh_params.subsample_factor = 0;
obj->ldc_mesh_image = vxCreateImage(obj->context,
obj->ldc_mesh_params.mesh_frame_width,
obj->ldc_mesh_params.mesh_frame_height,
VX_DF_IMAGE_U32);
obj->affine_matrix = vxCreateMatrix(obj->context, VX_TYPE_INT16,2,3);
APP_ASSERT_VALID_REF(obj->affine_matrix);
obj->matrix[0] = 4096;
obj->matrix[1] = 0;
obj->matrix[4] = 0;
obj->matrix[2] = 0;
obj->matrix[3] =4096 ;
obj->matrix[5] = 0;
obj->node_ldc = tivxVpacLdcNode(obj->graph,
obj->ldc_config,
obj->affine_matrix,
obj->ldc_region,
obj->ldc_mesh,
obj->ldc_mesh_image,
NULL, // dcc_db,
obj->input_img,
obj->ldc_img,
NULL //out1_img
Q1 Whether there is something of ldc config should different between emulation and target mode?
Q2 Is there something wrong in my code?
Thanks!
