• TI Thinks Resolved
TMDSEVM5517: About audio-preprocessing demo
Expert 2945 points
Part Number: TMDSEVM5517
Hello.
I am evaluating audio-preprocessing demo following below document.
http://www.ti.com/lit/an/spracn7/spracn7.pdf
The demo works well with 4 mics on PCM1864CMBEVM.
Could you tell me how to run the demo with 6 mics on PCM1864CMBEVM?
I modified codec_pcm186x.h as below.
// #define NUM_OF_MICS 4
#define NUM_OF_MICS 6
But following build error exist.
...Initializing DRC
Not enough heap, exiting
Are there any additional modifications to run 6 mic audio-preprocessing demo?
U-SK
  • Expert 2945 points
    Do you have any updates?
    U-SK
  • In reply to U-SK:
    Sorry for the delay. I was OoO.
    Have you tried modifying the linker.cmd file in your project?
    See:
    http://processors.wiki.ti.com/index.php/Linker_CMD_Files_for_CCS
    or:
     http://software-dl.ti.com/ccs/esd/documents/sdto_cgt_Linker-Command-File-Primer.html
    Yordan
     Please make sure you read the forum guidelines first.
    In reply to Yordan Kovachev:
    Hi Yodan,
    Thank you for your reply.
    I'll try it.
    Could you tell me in detail how to modify linker cmd file ?
    How much do we need heap size?
    Where should I add heap size option?(--heap_size=0x???)
    U-SK
    In reply to U-SK:
    I changed heap size to some value (0x1000, 0x2000, 0x4000, etc), but below error appeared when program is executed.
    (Build error is nothing, sorry.)
    ...Initializing DRC
    Are there any additional configurations?
    It seems that memory allocation has failed in bf_men_alloc_align() function in bf_asnr_mss_vau.c.
    If I can be friend with you and send private message, I can send some current my files.(cmd file, map file etc)
    U-SK
    In reply to U-SK:
    Hi Yodan,
    U-SK
  • In reply to U-SK:
    Check this e2e:
    Yordan
    Hi Yordan,
    I've checked the post you sent.
    I don't know where to check the map file.
    Could you give me advice about it?
    Have you ever run the audio-preprocessing demo with 6 mics?
    U-SK
  • In reply to U-SK:
    You can find an answer here:
    http://software-dl.ti.com/ccs/esd/documents/ccs_files_in_projects.html#linker-map-file
    Yordan
    Hi Yordan,
    Did my problem(CCS error) reproduce on your setup?
    U-SK
    In reply to U-SK:
    Hi Yodan,
    U-SK
