Other Parts Discussed in Thread: OMAP-L138, OMAPL138
Dear TI,
Hope you are fine.I am facing the issue when loading the starterware gpio code in TMS320C6748 DSP Processor.Following is the error which is mentioned below.
ICEPICK_C: Output: Target Connected.
ICEPICK_C: Output: ---------------------------------------------
ICEPICK_C: Output: Memory Map Cleared.
ICEPICK_C: Output: Memory Map Setup Complete.
ICEPICK_C: Trouble Reading Memory Block at 0x1c10800 on Page 0 of Length 0x4
ICEPICK_C: GEL: Error while executing OnTargetConnect(): Target failed to read 0x01C10800
at (*((unsigned int *) ((0x01C10000+0x800)+(4*LPSC_num)))&0x1F) [C6748_LCDK.gel:845]
at PSC0_LPSC_enable(0, 0) [C6748_LCDK.gel:488]
at PSC_All_On() [C6748_LCDK.gel:243]
at OnTargetConnect()
C674X_0: Error connecting to the target: (Error -6311) PRSC module failed to write to a register. (Emulation package 8.1.0.00007)
The error mentioned above is in gel file (C6748_LCDK.gel).Any solution for this problem?
With Regards,
Bilal.
