Hi
I am refering the tidl usecase so for that i wnt to create the tidl semantic segmentation usecase for that i need some guideline
Hi
Please refer chapter 4 in this document, vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_UserGuide_TI_DeepLearning.pdf
segmentation usecase is available in the below folder.
vision_sdk\apps\src\rtos\usecases\semSeg
Please refer chains_semSeg.txt file for all the links used in this usecase.
Can you be a bit more specific about information you want?
Gaviraju
Hi
Do you understand Vision sdk links and chain architecture?
Are you facing issue in understanding the usecase source code file available in below folder
Or you want to know how tidl algos are working and how road sign or vehicles are detected?
Gaviraju
No sir I am not able to understanding the links and chains architecture and when we creating the usecase how they are using the different links and so that's why I am getting
Please refer below document for understanding the link & chain architecture of VSDK.
vision_sdk/docs/Architecture/VisionSDK_SW_Architecture_Overview.pdf
vision_sdk/docs/Architecture/VisionSDK_SW_Architecture_Details.pdf
Auto Usecase Generation tool - Usage, tool enhancements to support new links refer to this: vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_UserGuide_UsecaseGen.pdf
vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_Overview_UsecaseGen.pdf
Build system – details of usage, fast builds, custom build configuration
vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_UserGuide_BuildSystem.pdf
VSDK development guide: vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_DevelopmentGuide.pdf
Gaviraju
For understanding the tidlpreproc and tidlpostproc algorithm please explain the this
Hi
In tidlpreproc, we are converting a video frame from YUV to BGR data format.
In tidlpostproc, we are creating overly of different objects
Gaviraju
Hi
For understanding "how road sign or vehicles are detected" using TIDL Algorithm.
First, you have to understand TI deep learning(TIDL) Algorithm & TIDL comes as a package in Vision SDK.
So I'm requesting to you create new query thread with component name as "TIDL", then our TIDL expert will help you
Gaviraju
