Other Parts Discussed in Thread: PGA460
vision_sdk: PROCESSOR_SDK_VISION_03_08_00_00
board: XC5777X
compile: ~/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$ make linux
~/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$ make linux_install
boot system from sd card;
the fw:
log.txt:
U-Boot 2019.01-00016-gf3aaa9f (Feb 26 2020 - 22:54:02 -0800) CPU : DRA752-GP ES2.0 Model: TI DRA742 Board: DRA74x EVM REV H.0 DRAM: 4 GiB NAND: 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Loading Environment from MMC... *** Warning - No block device, using default environment invalid mmc device Net: Warning: ethernet@48484000 using MAC address from ROM eth0: ethernet@48484000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** 332 bytes read in 3 ms (107.4 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 3105280 bytes read in 139 ms (21.3 MiB/s) 97979 bytes read in 6 ms (15.6 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8ffe5000, end 8ffffeba ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.73+ (mingjian@ubuntu) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Wed Feb 26 23:27:37 PST 2020 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: TI DRA742 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node cmem@40300000, compatible id shared-dma-pool [ 0.000000] Reserved memory: regions without no-map are not yet supported [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB [ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: regions without no-map are not yet supported [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: regions without no-map are not yet supported [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node cmem@A9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node gpu-memory@c0000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000 [ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier [ 0.000000] On node 0 totalpages: 252928 [ 0.000000] DMA zone: 1728 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 188416 pages, LIFO batch:63 [ 0.000000] HighMem zone: 64512 pages, LIFO batch:15 [ 0.000000] DRA752 ES2.0 [ 0.000000] random: get_random_bytes called from 0xc0c00a1c with crng_init=0 [ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440 [ 0.000000] pcpu-alloc: s32396 r8192 d20852 u61440 alloc=15*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 251200 [ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=/dev/mmcblk2p2 rw rootfstype=ext4 rootwait ip=none mem=1024M cma=64M [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 283896K/1011712K available (8192K kernel code, 287K rwdata, 1212K rodata, 2048K init, 247K bss, 416520K reserved, 311296K cma-reserved, 126976K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (10208 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 288 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 248 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000018] Switching to timer-based delay loop, resolution 162ns [ 0.000299] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000309] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000768] Console: colour dummy device 80x30 [ 0.000787] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000796] This ensures that you still see kernel messages. Please [ 0.000804] update your kernel commandline. [ 0.000838] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000855] pid_max: default: 32768 minimum: 301 [ 0.000976] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000991] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001537] CPU: Testing write buffer coherency: ok [ 0.001576] CPU0: Spectre v2: using ICIALLU workaround [ 0.001790] /cpus/cpu@0 missing clock-frequency property [ 0.001810] /cpus/cpu@1 missing clock-frequency property [ 0.001822] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.059916] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.079928] rcu: Hierarchical SRCU implementation. [ 0.100125] EFI services will not be available. [ 0.119992] smp: Bringing up secondary CPUs ... [ 0.200387] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.200393] CPU1: Spectre v2: using ICIALLU workaround [ 0.200515] smp: Brought up 1 node, 2 CPUs [ 0.200528] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.200537] CPU: All CPU(s) started in HYP mode. [ 0.200545] CPU: Virtualization extensions available. [ 0.201030] devtmpfs: initialized [ 0.218833] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.219099] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.219117] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.223987] pinctrl core: initialized pinctrl subsystem [ 0.224351] DMI not present or invalid. [ 0.224598] NET: Registered protocol family 16 [ 0.225740] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.226536] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.331923] cpuidle: using governor ladder [ 0.331959] cpuidle: using governor menu [ 0.340629] platform 43300000.edma: Cannot lookup hwmod 'tpcc' [ 0.340867] platform 43400000.tptc: Cannot lookup hwmod 'tptc0' [ 0.341098] platform 43500000.tptc: Cannot lookup hwmod 'tptc1' [ 0.341789] OMAP GPIO hardware version 0.1 [ 0.367021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.367033] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.367578] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [ 0.367590] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [ 0.367903] OMAP DMA hardware revision 0.0 [ 0.376354] edma3-tptc 43400000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info [ 0.376416] edma3-tptc 43500000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info [ 0.376695] edma 43300000.edma: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info [ 0.376709] edma 43300000.edma: pm_runtime_get_sync() failed [ 0.383898] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 0.385322] evm_3v3: supplied by evm_12v0 [ 0.385546] evm_5v0: supplied by evm_12v0 [ 0.385774] evm_3v6: supplied by evm_5v0 [ 0.388407] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.388549] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.388607] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000 [ 0.388616] pgd = (ptrval) [ 0.388625] [00000000] *pgd=80000080004003, *pmd=00000000 [ 0.388646] Internal error: : 1211 [#1] PREEMPT SMP ARM [ 0.388655] Modules linked in: [ 0.388671] CPU: 0 PID: 23 Comm: kworker/0:1 Not tainted 4.19.73+ #1 [ 0.388681] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.388692] Workqueue: pm 0xc05e9f9c [ 0.388705] PC is at 0xc056835c [ 0.388712] LR is at 0xc0568670 [ 0.388721] pc : [<c056835c>] lr : [<c0568670>] psr: 60000093 [ 0.388729] sp : ef1fdde0 ip : ef1fde00 fp : ef1fddfc [ 0.388737] r10: ffffe000 r9 : c0e04c48 r8 : c05e6b64 [ 0.388746] r7 : c0e03d00 r6 : c0e12cf4 r5 : ef26a410 r4 : ef32e440 [ 0.388755] r3 : f087b000 r2 : 00000000 r1 : 00000000 r0 : ef32e440 [ 0.388764] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user [ 0.388773] Control: 30c5387d Table: 80003000 DAC: fffffffd [ 0.388782] Process kworker/0:1 (pid: 23, stack limit = 0x(ptrval)) [ 0.388792] Stack: (0xef1fdde0 to 0xef1fe000) [ 0.388803] dde0: ef26a410 00000000 ef26a488 c0e03d00 ef1fde0c ef1fde00 c05e6b98 c05685d8 [ 0.388815] de00: ef1fde44 ef1fde10 c05e96a4 c05e6b70 ef647200 c0e04e44 ef647180 ef26a410 [ 0.388826] de20: 00000000 c05e6b64 c0e03d00 00000008 c0e04c48 ffffe000 ef1fde64 ef1fde48 [ 0.388836] de40: c05e9870 c05e9674 ef26a410 00000000 c05e6b64 c0e03d00 ef1fdebc ef1fde68 [ 0.388847] de60: c05e88c8 c05e9854 c0274944 0000000a c0e03d00 00000000 ef1fdec4 ef26a410 [ 0.388857] de80: 00000000 00000002 00000000 f92a5a7d ef26a4c8 ef26a410 00000000 00000002 [ 0.388867] dea0: 00000000 ef26a4d4 ef26a4c8 00000000 ef1fdee4 ef1fdec0 c05e8e24 c05e878c [ 0.388878] dec0: ef26a4c4 ef26a488 ef646d80 ef64b200 00000000 ef26a4c8 ef1fdefc ef1fdee8 [ 0.388888] dee0: c05ea030 c05e8d68 ef26a4c4 ef1e5600 ef1fdf34 ef1fdf00 c0248ac8 c05e9fa8 [ 0.388898] df00: 00000008 ef646d98 c0e03d00 ef1e5600 ef1e5614 ef646d80 00000008 ef646d98 [ 0.388908] df20: c0e03d00 ef646d80 ef1fdf74 ef1fdf38 c0249888 c02488e0 ef1e46c0 c0a84a78 [ 0.388919] df40: c0e46591 ffffe000 c024e8a0 ef1da080 ef1e46c0 00000000 ef1fc000 ef1e5600 [ 0.388929] df60: c0249830 ef095e74 ef1fdfac ef1fdf78 c024ed68 c024983c ef1da09c ef1da09c [ 0.388939] df80: 00000000 ef1e46c0 c024ec08 00000000 00000000 00000000 00000000 00000000 [ 0.388949] dfa0: 00000000 ef1fdfb0 c02010d8 c024ec14 00000000 00000000 00000000 00000000 [ 0.388959] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.388969] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 0.388976] Backtrace: [ 0.388988] Function entered at [<c05685cc>] from [<c05e6b98>] [ 0.388999] r7:c0e03d00 r6:ef26a488 r5:00000000 r4:ef26a410 [ 0.389007] Function entered at [<c05e6b64>] from [<c05e96a4>] [ 0.389015] Function entered at [<c05e9668>] from [<c05e9870>] [ 0.389026] r10:ffffe000 r9:c0e04c48 r8:00000008 r7:c0e03d00 r6:c05e6b64 r5:00000000 [ 0.389034] r4:ef26a410 [ 0.389041] Function entered at [<c05e9848>] from [<c05e88c8>] [ 0.389051] r7:c0e03d00 r6:c05e6b64 r5:00000000 r4:ef26a410 [ 0.389058] Function entered at [<c05e8780>] from [<c05e8e24>] [ 0.389069] r10:00000000 r9:ef26a4c8 r8:ef26a4d4 r7:00000000 r6:00000002 r5:00000000 [ 0.389077] r4:ef26a410 [ 0.389084] Function entered at [<c05e8d5c>] from [<c05ea030>] [ 0.389095] r9:ef26a4c8 r8:00000000 r7:ef64b200 r6:ef646d80 r5:ef26a488 r4:ef26a4c4 [ 0.389103] Function entered at [<c05e9f9c>] from [<c0248ac8>] [ 0.389112] r5:ef1e5600 r4:ef26a4c4 [ 0.389119] Function entered at [<c02488d4>] from [<c0249888>] [ 0.389130] r10:ef646d80 r9:c0e03d00 r8:ef646d98 r7:00000008 r6:ef646d80 r5:ef1e5614 [ 0.389138] r4:ef1e5600 [ 0.389145] Function entered at [<c0249830>] from [<c024ed68>] [ 0.389156] r10:ef095e74 r9:c0249830 r8:ef1e5600 r7:ef1fc000 r6:00000000 r5:ef1e46c0 [ 0.389163] r4:ef1da080 [ 0.389171] Function entered at [<c024ec08>] from [<c02010d8>] [ 0.389179] Exception stack(0xef1fdfb0 to 0xef1fdff8) [ 0.389188] dfa0: 00000000 00000000 00000000 00000000 [ 0.389199] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.389208] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.389220] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024ec08 [ 0.389227] r4:ef1e46c0 [ 0.389238] Code: e34c10ab eb01c4a3 e3e00015 eaffffee (e1a0c00d) [ 0.389255] ---[ end trace 331e31d9ed26a06c ]--- [ 0.389274] ------------[ cut here ]------------ [ 0.389285] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 0xc04ca2cc [ 0.389295] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSP1_SDMA (Read Link): At Address: 0x00502044 : Data Access in User mode during Functional access [ 0.389302] Modules linked in: [ 0.389317] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G D 4.19.73+ #1 [ 0.389325] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.389335] Workqueue: pm 0xc05e9f9c [ 0.389346] Backtrace: [ 0.389358] Function entered at [<c020c974>] from [<c020cc9c>] [ 0.389368] r7:c0aa42bc r6:60000193 r5:00000000 r4:c0e45498 [ 0.389376] Function entered at [<c020cc84>] from [<c0825de0>] [ 0.389384] Function entered at [<c0825d50>] from [<c0230ab0>] [ 0.389395] r7:c0aa42bc r6:00000009 r5:00000000 r4:ef1fda0c [ 0.389402] Function entered at [<c02309d4>] from [<c02306f4>] [ 0.389413] r9:ef1e5e40 r8:f0880358 r7:c0aa41dc r6:c0aa4128 r5:c0aa428c r4:c0e04c48 [ 0.389421] Function entered at [<c02306a8>] from [<c04ca2cc>] [ 0.389430] r3:ef207d80 r2:c0aa428c [ 0.389438] r5:00000004 r4:80080001 [ 0.389445] Function entered at [<c04c9f9c>] from [<c028a7b0>] [ 0.389456] r10:c0e465f7 r9:ef209a00 r8:00000017 r7:ef1fdb38 r6:00000000 r5:ef209a68 [ 0.389464] r4:ef20d300 [ 0.389471] Function entered at [<c028a748>] from [<c028a8bc>] [ 0.389482] r10:ef0ba1c0 r9:ef1fc000 r8:ef00c000 r7:00000001 r6:ef209a00 r5:ef209a68 [ 0.389490] r4:c0e04c48 [ 0.389497] Function entered at [<c028a888>] from [<c028a950>] [ 0.389506] r6:c0e0a1fc r5:ef209a68 r4:ef209a00 [ 0.389514] Function entered at [<c028a910>] from [<c028e698>] [ 0.389524] r7:00000001 r6:c0e0a1fc r5:ef209a68 r4:ef209a00 [ 0.389531] Function entered at [<c028e5d8>] from [<c02899ac>] [ 0.389540] r7:00000001 r6:00000000 r5:00000000 r4:c0c5ccf8 [ 0.389548] Function entered at [<c0289980>] from [<c028a010>] [ 0.389556] Function entered at [<c0289fac>] from [<c04c8608>] [ 0.389566] r9:ef1fc000 r8:fa213000 r7:ef1fdc00 r6:fa212000 r5:fa21200c r4:c0e050f8 [ 0.389574] Function entered at [<c04c85c4>] from [<c02019f8>] [ 0.389582] Exception stack(0xef1fdc00 to 0xef1fdc48) [ 0.389594] dc00: ef0ba708 00000000 0000001a 0000001b ef0ba1c0 0000000b ef0ba708 ffffe000 [ 0.389604] dc20: bf000000 60000193 ef0ba1c0 ef1fdc5c ef1fdc60 ef1fdc50 c0234308 c0840230 [ 0.389613] dc40: 60000113 ffffffff [ 0.389623] r9:ef1fc000 r8:bf000000 r7:ef1fdc34 r6:ffffffff r5:60000113 r4:c0840230 [ 0.389631] Function entered at [<c0840208>] from [<c0234308>] [ 0.389639] Function entered at [<c02341e0>] from [<c020c044>] [ 0.389646] r7:0000000b [ 0.389654] Function entered at [<c020bcc8>] from [<c020c0a4>] [ 0.389665] r10:ffffe000 r9:00000007 r8:ef1fdd90 r7:c0e09afc r6:00000000 r5:00001211 [ 0.389672] r4:c0e04c48 [ 0.389680] Function entered at [<c020c050>] from [<c02145c4>] [ 0.389687] Function entered at [<c0214500>] from [<c0201970>] [ 0.389695] Exception stack(0xef1fdd90 to 0xef1fddd8) [ 0.389705] dd80: ef32e440 00000000 00000000 f087b000 [ 0.389715] dda0: ef32e440 ef26a410 c0e12cf4 c0e03d00 c05e6b64 c0e04c48 ffffe000 ef1fddfc [ 0.389725] ddc0: ef1fde00 ef1fdde0 c0568670 c056835c 60000093 ffffffff [ 0.389736] r9:ef1fc000 r8:c05e6b64 r7:ef1fddc4 r6:ffffffff r5:60000093 r4:c056835c [ 0.389744] Function entered at [<c05685cc>] from [<c05e6b98>] [ 0.389754] r7:c0e03d00 r6:ef26a488 r5:00000000 r4:ef26a410 [ 0.389761] Function entered at [<c05e6b64>] from [<c05e96a4>] [ 0.389769] Function entered at [<c05e9668>] from [<c05e9870>] [ 0.389779] r10:ffffe000 r9:c0e04c48 r8:00000008 r7:c0e03d00 r6:c05e6b64 r5:00000000 [ 0.389787] r4:ef26a410 [ 0.389794] Function entered at [<c05e9848>] from [<c05e88c8>] [ 0.389804] r7:c0e03d00 r6:c05e6b64 r5:00000000 r4:ef26a410 [ 0.389811] Function entered at [<c05e8780>] from [<c05e8e24>] [ 0.389821] r10:00000000 r9:ef26a4c8 r8:ef26a4d4 r7:00000000 r6:00000002 r5:00000000 [ 0.389829] r4:ef26a410 [ 0.389837] Function entered at [<c05e8d5c>] from [<c05ea030>] [ 0.389847] r9:ef26a4c8 r8:00000000 r7:ef64b200 r6:ef646d80 r5:ef26a488 r4:ef26a4c4 [ 0.389855] Function entered at [<c05e9f9c>] from [<c0248ac8>] [ 0.389863] r5:ef1e5600 r4:ef26a4c4 [ 0.389870] Function entered at [<c02488d4>] from [<c0249888>] [ 0.389880] r10:ef646d80 r9:c0e03d00 r8:ef646d98 r7:00000008 r6:ef646d80 r5:ef1e5614 [ 0.389888] r4:ef1e5600 [ 0.389895] Function entered at [<c0249830>] from [<c024ed68>] [ 0.389906] r10:ef095e74 r9:c0249830 r8:ef1e5600 r7:ef1fc000 r6:00000000 r5:ef1e46c0 [ 0.389913] r4:ef1da080 [ 0.389921] Function entered at [<c024ec08>] from [<c02010d8>] [ 0.389929] Exception stack(0xef1fdfb0 to 0xef1fdff8) [ 0.389938] dfa0: 00000000 00000000 00000000 00000000 [ 0.389948] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.389958] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.389968] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024ec08 [ 0.389976] r4:ef1e46c0 [ 0.389983] ---[ end trace 331e31d9ed26a06d ]--- [ 0.390224] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.390449] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.390768] omap-iommu 41501000.mmu: 41501000.mmu registered [ 0.390905] omap-iommu 41502000.mmu: 41502000.mmu registered [ 0.391074] ------------[ cut here ]------------ [ 0.391086] WARNING: CPU: 0 PID: 5 at drivers/bus/omap_l3_noc.c:147 0xc04ca2cc [ 0.391097] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET DSP2_SDMA (Read Link): At Address: 0x00502044 : Data Access in User mode during Functional access [ 0.391104] Modules linked in: [ 0.391121] CPU: 0 PID: 5 Comm: kworker/0:0 Tainted: G D W 4.19.73+ #1 [ 0.391130] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.391140] Workqueue: pm 0xc05e9f9c [ 0.391151] Backtrace: [ 0.391163] Function entered at [<c020c974>] from [<c020cc9c>] [ 0.391175] r7:c0aa42bc r6:60000193 r5:00000000 r4:c0e45498 [ 0.391183] Function entered at [<c020cc84>] from [<c0825de0>] [ 0.391191] Function entered at [<c0825d50>] from [<c0230ab0>] [ 0.391201] r7:c0aa42bc r6:00000009 r5:00000000 r4:ef095c94 [ 0.391209] Function entered at [<c02309d4>] from [<c02306f4>] [ 0.391219] r9:ef1e5e40 r8:f0880658 r7:c0aa41dc r6:c0aa4128 r5:c0aa428c r4:c0e04c48 [ 0.391227] Function entered at [<c02306a8>] from [<c04ca2cc>] [ 0.391236] r3:ef207d80 r2:c0aa428c [ 0.391244] r5:00000004 r4:80080001 [ 0.391252] Function entered at [<c04c9f9c>] from [<c028a7b0>] [ 0.391263] r10:c0e465f7 r9:ef209a00 r8:00000017 r7:ef095dc0 r6:00000000 r5:ef209a68 [ 0.391270] r4:ef20d300 [ 0.391278] Function entered at [<c028a748>] from [<c028a8bc>] [ 0.391289] r10:00000000 r9:ef094000 r8:ef00c000 r7:00000001 r6:ef209a00 r5:ef209a68 [ 0.391296] r4:c0e04c48 [ 0.391304] Function entered at [<c028a888>] from [<c028a950>] [ 0.391313] r6:c0e0a1fc r5:ef209a68 r4:ef209a00 [ 0.391320] Function entered at [<c028a910>] from [<c028e698>] [ 0.391329] r7:00000001 r6:c0e0a1fc r5:ef209a68 r4:ef209a00 [ 0.391337] Function entered at [<c028e5d8>] from [<c02899ac>] [ 0.391346] r7:00000001 r6:00000000 r5:00000000 r4:c0c5ccf8 [ 0.391354] Function entered at [<c0289980>] from [<c028a010>] [ 0.391362] Function entered at [<c0289fac>] from [<c04c8608>] [ 0.391372] r9:ef094000 r8:fa213000 r7:ef095e88 r6:fa212000 r5:fa21200c r4:c0e050f8 [ 0.391380] Function entered at [<c04c85c4>] from [<c02019f8>] [ 0.391388] Exception stack(0xef095e88 to 0xef095ed0) [ 0.391398] 5e80: ef284a88 20000193 f92a5a7d 0000000b ef284ac4 ef284a88 [ 0.391409] 5ea0: ef646d80 ef64b200 00000000 ef284ac8 00000000 ef095ee4 ef095ee8 ef095ed8 [ 0.391418] 5ec0: c05ea00c c0840230 60000113 ffffffff [ 0.391429] r9:ef094000 r8:00000000 r7:ef095ebc r6:ffffffff r5:60000113 r4:c0840230 [ 0.391436] Function entered at [<c0840208>] from [<c05ea00c>] [ 0.391444] Function entered at [<c05e9f9c>] from [<c0248ac8>] [ 0.391452] r5:ef055b80 r4:ef284ac4 [ 0.391460] Function entered at [<c02488d4>] from [<c0249888>] [ 0.391470] r10:ef646d80 r9:c0e03d00 r8:ef646d98 r7:00000008 r6:ef646d80 r5:ef055b94 [ 0.391478] r4:ef055b80 [ 0.391485] Function entered at [<c0249830>] from [<c024ed68>] [ 0.391496] r10:ef081e64 r9:c0249830 r8:ef055b80 r7:ef094000 r6:00000000 r5:ef088040 [ 0.391504] r4:ef088080 [ 0.391511] Function entered at [<c024ec08>] from [<c02010d8>] [ 0.391519] Exception stack(0xef095fb0 to 0xef095ff8) [ 0.391528] 5fa0: 00000000 00000000 00000000 00000000 [ 0.391538] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.391548] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.391559] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024ec08 [ 0.391566] r4:ef088040 [ 0.391574] ---[ end trace 331e31d9ed26a06e ]--- [ 0.391839] iommu: Adding device 58820000.ipu to group 1 [ 0.391917] iommu: Adding device 55020000.ipu to group 2 [ 0.392040] iommu: Adding device 40800000.dsp to group 0 [ 0.392273] iommu: Adding device 41000000.dsp to group 3 [ 0.394238] palmas 0-0058: IRQ missing: skipping irq request [ 0.420784] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0 [ 0.422470] SMPS123: supplied by regulator-dummy [ 0.424313] SMPS45: supplied by regulator-dummy [ 0.426149] SMPS6: supplied by regulator-dummy [ 0.427832] SMPS7: supplied by regulator-dummy [ 0.429671] SMPS8: supplied by regulator-dummy [ 0.431379] SMPS9: supplied by regulator-dummy [ 0.432309] LDO1: supplied by regulator-dummy [ 0.441246] LDO2: supplied by regulator-dummy [ 0.451106] LDO3: supplied by regulator-dummy [ 0.461127] LDO4: supplied by regulator-dummy [ 0.461283] random: fast init done [ 0.461799] LDO5: supplied by regulator-dummy [ 0.462466] LDO6: supplied by regulator-dummy [ 0.463131] LDO7: supplied by regulator-dummy [ 0.463799] LDO8: supplied by regulator-dummy [ 0.464475] LDO9: supplied by regulator-dummy [ 0.471159] LDOLN: supplied by regulator-dummy [ 0.481170] LDOUSB: supplied by regulator-dummy [ 0.493761] pcf857x 0-0020: probed [ 0.494322] pcf857x 0-0021: probed [ 0.494493] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.494918] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [ 0.495138] media: Linux media interface: v0.10 [ 0.495183] videodev: Linux video capture interface: v2.00 [ 0.495249] pps_core: LinuxPPS API ver. 1 registered [ 0.495258] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.495278] PTP clock support registered [ 0.495307] EDAC MC: Ver: 3.0.0 [ 0.496043] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.496284] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.497316] clocksource: Switched to clocksource arch_sys_counter [ 0.505460] NET: Registered protocol family 2 [ 0.506037] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.506067] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.506130] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.506256] TCP: Hash tables configured (established 8192 bind 8192) [ 0.506326] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.506361] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.506487] NET: Registered protocol family 1 [ 0.507559] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.507748] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.508699] Initialise system trusted keyrings [ 0.508826] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 0.513523] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.513537] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.514912] Key type asymmetric registered [ 0.514924] Asymmetric key parser 'x509' registered [ 0.514974] bounce: pool size: 64 pages [ 0.515008] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.515018] io scheduler noop registered [ 0.515028] io scheduler deadline registered [ 0.515130] io scheduler cfq registered (default) [ 0.515141] io scheduler mq-deadline registered [ 0.515151] io scheduler kyber registered [ 0.520826] pinctrl-single 4a003400.pinmux: 282 pins, size 1128 [ 0.526549] evm_1v8: supplied by smps9 [ 0.526772] evm_3v3_sw: supplied by sysen1 [ 0.526962] aic_dvdd: supplied by evm_3v3_sw [ 0.527006] vtt_fixed: supplied by sysen2 [ 0.571294] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.574707] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250 [ 2.909439] console [ttyS0] enabled [ 2.913832] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250 [ 2.923450] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250 [ 2.934503] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 2.934843] random: crng init done [ 2.947810] vmemexp device MAJOR num = 244 [ 2.951938] vmemexp class registered [ 2.955656] /dev/vmemexp device registered [ 2.959799] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120 [ 2.966757] libphy: Fixed MDIO Bus: probed [ 2.973115] i2c /dev entries driver [ 2.981304] cpu cpu0: Linked as a consumer to regulator.10 [ 2.986858] cpu cpu0: Linked as a consumer to regulator.32 [ 2.993629] sdhci: Secure Digital Host Controller Interface driver [ 2.999929] sdhci: Copyright(c) Pierre Ossman [ 3.005672] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.012184] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 3.021039] sdhci-omap 4809c000.mmc: Got CD GPIO [ 3.025778] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31 [ 3.032803] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16 [ 3.039647] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16 [ 3.046402] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16 [ 3.053252] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16 [ 3.059845] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31 [ 3.066855] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2 [ 3.073618] sdhci-omap 480b4000.mmc: Dropping the link to regulator.2 [ 3.080139] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2 [ 3.111231] mmc0: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA [ 3.120000] ledtrig-cpu: registered to indicate activity on CPUs [ 3.129439] NET: Registered protocol family 10 [ 3.134809] Segment Routing with IPv6 [ 3.138810] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.145880] NET: Registered protocol family 17 [ 3.150465] Registering SWP/SWPB emulation handler [ 3.155293] omap_voltage_late_init: Voltage driver support not added [ 3.161721] Power Management for TI OMAP4+ devices. [ 3.167045] Loading compiled-in X.509 certificates [ 3.172324] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.178986] [drm] No driver support for vblank timestamp query. [ 3.185112] [drm] Initialized vdrm 1.0.0 20191105 for 44000000.ocp:vdrm@0 on minor 0 [ 3.249980] ti-iodelay 4844a000.padconf: Set reg 0x190 Delay(a: 274 g: 0), Elements(C=0 F=6)0x29006 [ 3.249991] ti-iodelay 4844a000.padconf: Set reg 0x194 Delay(a: 162 g: 0), Elements(C=0 F=4)0x29004 [ 3.250001] ti-iodelay 4844a000.padconf: Set reg 0x1a8 Delay(a: 401 g: 0), Elements(C=0 F=10)0x2900a [ 3.250011] ti-iodelay 4844a000.padconf: Set reg 0x1ac Delay(a: 73 g: 0), Elements(C=0 F=1)0x29001 [ 3.250021] ti-iodelay 4844a000.padconf: Set reg 0x1b4 Delay(a: 465 g: 0), Elements(C=0 F=11)0x2900b [ 3.250030] ti-iodelay 4844a000.padconf: Set reg 0x1b8 Delay(a: 115 g: 0), Elements(C=0 F=2)0x29002 [ 3.250039] ti-iodelay 4844a000.padconf: Set reg 0x1c0 Delay(a: 633 g: 0), Elements(C=1 F=2)0x29022 [ 3.250048] ti-iodelay 4844a000.padconf: Set reg 0x1c4 Delay(a: 47 g: 0), Elements(C=0 F=1)0x29001 [ 3.250058] ti-iodelay 4844a000.padconf: Set reg 0x1d0 Delay(a: 935 g: 280), Elements(C=1 F=14)0x2902e [ 3.250066] ti-iodelay 4844a000.padconf: Set reg 0x1d8 Delay(a: 621 g: 0), Elements(C=1 F=2)0x29022 [ 3.250075] ti-iodelay 4844a000.padconf: Set reg 0x1dc Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000 [ 3.250084] ti-iodelay 4844a000.padconf: Set reg 0x1e4 Delay(a: 183 g: 0), Elements(C=0 F=4)0x29004 [ 3.250093] ti-iodelay 4844a000.padconf: Set reg 0x1e8 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000 [ 3.250101] ti-iodelay 4844a000.padconf: Set reg 0x1f0 Delay(a: 467 g: 0), Elements(C=0 F=11)0x2900b [ 3.250110] ti-iodelay 4844a000.padconf: Set reg 0x1f4 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000 [ 3.250119] ti-iodelay 4844a000.padconf: Set reg 0x1fc Delay(a: 262 g: 0), Elements(C=0 F=6)0x29006 [ 3.250128] ti-iodelay 4844a000.padconf: Set reg 0x200 Delay(a: 46 g: 0), Elements(C=0 F=1)0x29001 [ 3.250137] ti-iodelay 4844a000.padconf: Set reg 0x364 Delay(a: 684 g: 0), Elements(C=1 F=3)0x29023 [ 3.250145] ti-iodelay 4844a000.padconf: Set reg 0x368 Delay(a: 76 g: 0), Elements(C=0 F=1)0x29001 [ 3.253124] mmc0: new HS200 MMC card at address 0001 [ 3.263849] mmcblk0: mmc0:0001 MMC08G 7.25 GiB [ 3.264291] mmcblk0boot0: mmc0:0001 MMC08G partition 1 8.00 MiB [ 3.264731] mmcblk0boot1: mmc0:0001 MMC08G partition 2 8.00 MiB [ 3.264878] mmcblk0rpmb: mmc0:0001 MMC08G partition 3 128 KiB, chardev (242:0) [ 3.286722] Console: switching to colour frame buffer device 240x67 [ 3.509408] vdrm 44000000.ocp:vdrm@0: fb0: DRM emulated frame buffer device [ 3.516796] dmm 4e000000.dmm: workaround for errata i878 in use [ 3.524109] dmm 4e000000.dmm: initialized all PAT entries [ 3.530007] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 1 [ 3.538156] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 3.546990] sdhci-omap 4809c000.mmc: Got CD GPIO [ 3.551768] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31 [ 3.558818] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16 [ 3.565649] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16 [ 3.572267] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.36 [ 3.579262] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16 [ 3.586168] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode [ 3.592837] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode [ 3.599489] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode [ 3.632981] mmc1: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA [ 3.641326] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [ 3.648790] hctosys: unable to open rtc device (rtc0) [ 3.654810] aic_dvdd: disabling [ 3.658032] vmmcwl_fixed: disabling [ 3.662102] ldousb: disabling [ 3.666798] Waiting for root device /dev/mmcblk2p2... [ 3.785656] mmc1: host does not support reading read-only switch, assuming write-enable [ 3.795729] mmc1: new high speed SDHC card at address 1234 [ 3.802572] mmcblk1: mmc1:1234 SA08G 7.21 GiB [ 3.808116] mmcblk1: p1 p2
thank you,
cesar.
