Entering custom setting in PLLatinum Sim
Under the Select Device tab you have the option to select Custom for your device.  What setting does this selection allow me to control and how do I enter the data?
On a similar note under the Phase noise tab there is the option to load data for the PLL noise.  What format that data file in do I enter offset and noise values like the VCO and reference data or enter the desired FOM values?
Tom
  • Tom,
    You can change the charge pump gain and VCO gain.
    You can also upload phase noise. On the phase noise tab, click the ? and it tells you what format the data can be.
    In the next two weeks, I'll be releasing an upgrade that also allows you to modify the PLL figure of merit.
    Dean
