Hi, I was studying about balun.
I found that in RF tranceiver, narrow band balun is used for transmitter part and wide band balun is used for receiver part.
Why different bandwidth baluns are used in Tx and Rx?
Yunsik
Yunsik
Hi TER,
I am wondering about the balun in RRU system.
To be specific, in Tx, narrow band balun is used to convert differential signal from RFIC to single ended signal of antenna.
In Rx, wide band balun is used to convert single ended signal from antenna to differential signal of RFIC.
I cannot be specific on part number because of customer issue.
Yunsik
Sorry, I don't know what you are referring to as "RRU system". Please note that we have to handle a large number of E2E threads hence we require that it's easy to understand what the question is about. At the moment I'm not even sure that this question is related to Simplelink/ Connectivity
If you have some confidential information you can send it to me by mail or by private message on E2E
I don't give out my e-mail address on the forum. If you have moderator privilege you can find the e-mail address from E2E, if not, send me a friend request to enable private messaging on the forum.
