• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » RF & Digital Radio » Digital Radio (GC Products) » Digital Radio (GC Products) Forum » Digital Pre-Distortion for linearization at frequencies 2.3GHz - 2.4GHz recommendations
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Naji Naufel
Posted by Naji Naufel
on Mar 29 2012 09:37 AM
Intellectual580 points
My customer wrote:
We are planning on using Doherty configuration in one of our design and this is going to induce non linearity.
 We need pre-distortion or linearizer built into our design so that it can make the output linear. Linearizer gets a feedback from the output signal and adjusts the input signal to make the output linear. Hope this helps.
I came to know that TI makes some of these devices. It would be nice to get a contact person at TI to discuss more about their products and see whether they suit our application
Here are the specifications of the linearizer we are interested in
 Frequency range: 2.3GHz- 2.4GHz
PAR: 7dB to 9dB
 I looked at TI website and found some for baseband(GC5325) but could not find anything for our frequency range.
Do you have any suggestions or recommendation?
Thank you
DPD CFR predistortion linearization
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Radio-Joe
    Posted by Radio-Joe
    on Mar 29 2012 10:54 AM
    Verified Answer
    Verified by Radio-Joe
    Expert7465 points
    In DPD applications using the GC5330 or GC5337, the suggestion is to use an Evaluation Module, and your target PA for a test.
    You can look at the EVM description under the GC5330 portion of the TI website.  The DPD system can accomodate a 3rd to 7th order correction, depending on the signal BW, and the DPD rate.  The DPD rate can be 153.6, or 307.2 for the GC5330.  The DPD rate can be 184.32 or 368.64 for the GC5337.  The support signal bandwidth would be (DPDrate * .9)/ correction_order [example 153.6Mhz DPD rate, 5th order correction, 27.65Mhz signal BW).  In practice people have used the 153.6 HPM rate for 40Mhz systems.
    The RF system utilizes a high IF approach, the IF is selected based on the feedback ADC topology.   Normally the feedback is centered over a Nyquist zone, Fs/4,3FS/4, or 5Fs/4; the most common is 3FsADC/4.
    The IF to RF conversion is handled by an IQ Modulator.  If you look at the TSWS3085 (IQ Modulator) and TSW1249 (IQ Demodulator for complex feedback) they can operate from 700Mhz to over 2.5Ghz.  In final systems, you need to filter out other clock harmonics and provide filtering and bias between the DAC and IQ Modulator.   Please contact Ken Chan (kenchan@ti.com), about the Data converter card specifications.
    I think the GC5330 EVM should work at the 2.3 to 2.4Ghz range.
    Radio Joe
    Report Abuse
    • Reply
  • Naji Naufel
    on Mar 29 2012 13:40 PM
    Hi Joe,
    I did not see and EVM specific to the GC5330. The TSWS3085 does not list the GC5330 as being used on it. Does the user have to get the GC6016EVM and swap IC's?
    Report Abuse
    • Reply
  • Radio-Joe
    Posted by Radio-Joe
    on Mar 29 2012 14:11 PM
    Verified Answer
    Expert7465 points
    Hello
    The older GC5330, GC5337 EVM had DAC 3283, IQ Modulator 3720 on the EVM board.  This worked in the frequency range you have specified.  The older EVM had an onboard real receiver architecture, mixer, common LO with Tx, filter, and ADC used for feedback.  Some different frequency ranges needed diffferent mixer components for feedback.
    The newer experiments used the older GC5337 EVM with a digital output for the DAC 3484, using the TRF3704 IQ modulator.   This worked in the frequency range you have specified.  A TSW1249 was built as a complex demodulator for feedback, this used an IQ demodulator, common Tx LO, and a dual ADC.
    The current GC6016 digital EVM has digital connectors only.  The TSW3085, and TSW1249 can be ordered with the digital EVM.  Please contact Ken Chan (kenchan@ti.com) to get more information on the components, schematics, layout, and ordering information.  The TSW3085 uses the DAC3482, with the TRF 3705 modulator.  The TSW1249 uses a Complex demodulator, and dual TI ADC.
    Using a 2.4Ghz RF example, with a 153.6Mhz DPD rate, 204.8Mhz feedback rate.  You would have a 153.6Mhz IF,   The LO is externally provided to the EVM, so within the range of the IQ Modulator, or IQ Demodulator, the digital portion has a specific DPD rate, ADC rate and IF.
    The GC6016 EVM is the title.  It is in the same family as the GC5330, GC5337.  http://www.ti.com/tool/gc6016evm
    The TSW3085 is listed here http://www.ti.com/tool/tsw3085evm
    The TSW1249 is not listed, you will need to get that information from Ken Chain.
    Radio Joe
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
