• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » RF & Digital Radio » Digital Radio (GC Products) » Digital Radio (GC Products) Forum » GC 5330 Configuration
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
ilke ALTIN
Posted by ilke ALTIN
on Apr 06 2012 07:32 AM
Intellectual355 points
I am trying to configure the GC 5330 chip to work with the SCBP board + TSW 3725 configuration. However I could not understand how to activate GC 5330, although Azcom has supported me some example scripts for LTE. Can anyone guide me on this subject?
ilke
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Radio-Joe
    Posted by Radio-Joe
    on Apr 06 2012 08:47 AM
    Expert7205 points
    The GC5330 configuration is based on what air interface standard is being transmitted, the mode of operation of the BB interface for the GC5330, and the TSW 3725.  The configuation of the GC5330 is based on having a prebuilt GC5330 configuration with these specifications, and following the sequence:
       a) apply power, force JTAG reset, force RESET active
       b) when power is OK, release RESET
       c) apply DPDClock, SyncA, Baseband Clock Tx, Baseband Frame Tx, Baseband data can be zero
       d) using the API load the TGTCFG register programming
       e) as part of this API, there is a DSP synchronization sequence, and small register test
       f) other configuration APIs are needed for the DSP to know the intended DPD mode of operation and antenna configuration GCNUMMAP, SPCONFIG
       g) other configuration changes TxBBgain, TxDDUCNCO, TxSumChainControl, SumchainGain / PreCFRGain / PostCFRGain, CFR Filter Control, are needed to setup the Tx carriers, and Gain, any user calibration is computed and loaded
       h) the DPD Controls are setup for the complex and real signal rates, the DPD mode and values
       i) there are Interval power meter, and Capture buffer setup APIs, the user sets up the Forward Tx Gain RF attenuation, and balances the feedback power DPDI, SFBI-EQ
          note some of the feedback attenuation adjustments are external to the DPD DSP
       j)  the time alignment is performed, if the delay is within range, DPD can be started
       k) you can monitor the DPD Status and error stack for information
    Note if the original question is how to modify the Azcom board configuration for a different BBset of data, and TGTCFG, please contact your support TI DSP engineer, and Azcom.  You can contact jshu@ti.com for the initially provided TGTCFG information.
    Radio Joe
    Report Abuse
    • Reply
  • ilke ALTIN
    on Apr 06 2012 09:40 AM
    Thanks for your quick response. Firstly I think I should further clarify my question a bit. I intend to initialize and configure GC 5330 and Azcom has supported me with a tar file named GC. It contains 5 files;
    dpdbios6.bin
    gc5330hostapp.dat
    HPM_2antx1x20LTE_v2.tgtcfg
    startupscript.dat
    x.json.
    I could not clearly understand what you have meant by "the API". Is there an available API for GC5330? I could provide you the files if you think it'd be more convenient. Thanks in advance.
    ilke
    Report Abuse
    • Reply
  • Jay Shu
    Posted by Jay Shu
    on Apr 06 2012 15:39 PM
    Prodigy670 points
    The startupscript.dat contains the calls that are necessary (i.e. APIs) that were referred to.  The gc5330hostapp.dat is the executable that is running on the ARM processor.  So you should only need to start the gc5330hostapp.dat and then "exec startupscript.dat" to have the gc5330 configured properly.
    You should contact Azcom directly since they are responsible to support on the SCBP boards.  If they cannot answer the question, then we will help them.
    Report Abuse
    • Reply
  • ilke ALTIN
    on Apr 07 2012 07:42 AM
    I have followed the steps that you have described, but I have encountered with an error. Azcom did not provide me with a sufficient answer yet, and if you could help me I would be grateful. I have given the error below. Thanks in advance.
    ilke
    Total errors for the command: 1
    _____________________________
    28.325: L1 E=37 at 16
    sDPD_TGTCFG_WR failed with status -1.
    Load GC configuration error!$summer_gainw 1 1 -6
    #cfr_gainw 1 1 2 -6
    $summer_mapw 1 0 0x1
    $summer_mapw 1 1 0
    Report Abuse
    • Reply
  • Jay Shu
    Posted by Jay Shu
    on Apr 07 2012 08:40 AM
    Verified Answer
    Verified by ilke ALTIN
    Prodigy670 points
    that specific error is a warm pll error.  This means that either the clocks to the GC are wrong or not present.  Please contact Azcom on how to properly start up the system with the TSW3725 and the FPGA that is onboard the SCBP.  All those have to be setup first before the GC software can be started.  I am not familiar enough with what they release so you should again contact Azcom.
    Report Abuse
    • Reply
  • ilke ALTIN
    on Apr 08 2012 09:34 AM
    Hey,
    Thanks for your support, I will contact Azcom as you have suggested from now. THanks for clarifying this problem for me.
    ilke
    Report Abuse
    • Reply
  • PPC
    Posted by PPC
    on May 14 2012 10:25 AM
    Prodigy195 points
    Dear ilke,
    Could you solve the issue? How? I am having exactly the same problem as you had.
    Guillermo.
    Report Abuse
    • Reply
  • ilke ALTIN
    on Jul 10 2012 09:18 AM
    Suggested Answer
    Dear Guillermo,
    I could not solve the issue, and since we couldn't afford spending any more time on this we implemented another solution that does not involve GC5330. I hope you have solved the issue.
    P.S: If you could please let me know, I am planning to work on that issue a few months later.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
