• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » RF & Digital Radio » Digital Radio (GC Products) » Digital Radio (GC Products) Forum » Digital Repeater example design
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Radio-Joe
Posted by Radio-Joe
on Apr 06 2009 19:23 PM
Expert7235 points
Is there a Digital Down Converter, Digital Up Converter IF translator design
with an EVM example?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Radio-Joe
    Posted by Radio-Joe
    on Apr 06 2009 19:25 PM
    Verified Answer
    Verified by Radio-Joe
    Expert7235 points
    The TI TSW4100, has a hardware design with a clock solution, Data converter solution,
    power solution, DDC, DUC, FPGA connectivity, and design software for configuring 2 and 4 channel
    digital repeaters with a single antenna.  The TI webpage link for the TSW4100 is:
    http://focus.ti.com/docs/toolsw/folders/print/tsw4100evm.html
    Thanks for asking,
    RadioJoe
    Report Abuse
    • Reply
  • vandel
    Posted by vandel
    on Sep 07 2009 20:35 PM
    Prodigy50 points
    Hello:
    I have purchased the TSW4100 and am familiarizing myself with its operation.  I have been unable to find any documentation or source related to the program currently in the Cypress FPGA .... is this available, if so where can I get it and what format is it in.
    Thanks in advance for any input.
    LVDJ
    Report Abuse
    • Reply
  • Radio-Joe
    Posted by Radio-Joe
    on Sep 08 2009 12:19 PM
    Expert7235 points
    TSW4100 FPGA description.zip
    The EVM engineer has included the TSW4100 firmware files in the attached ZIP file.  Please reference the TSW4100 User Guide also.
    Radio Joe
    Report Abuse
    • Reply
  • vandel
    Posted by vandel
    on Sep 10 2009 15:24 PM
    Prodigy50 points
    Hi Joe:
    Thanks for the firmware I am digging into that.  I have a problem with the TSW4100 DAC5688 and CDCD7005 Control software.  I'm hoping that someone has seen it before and can suggest a solution.
    When I hit "Load Settings" from any one of the pages it typically just flashes and does bring up a File Select Dialog.  Once or twice it did and I was able to load the settings file and verifiy that I could get a PLL lock, but I have not yet been able to reproduce a situation where the File Select Dialog does open on a reliable basis.
    Thanks for any input.
    vandel
    Report Abuse
    • Reply
  • Radio-Joe
    Posted by Radio-Joe
    on Sep 10 2009 15:59 PM
    Expert7235 points
    Hello Vandel,
    The TSW4100 GUI software is a MATLAB GUI, that calls specific DOS-terminal programs.  There is a GUI panel, and a DOS terminal panel.  If you look at the DOS terminal panel, it may indicate
    a USB driver error, or other error message.  Check in the TSW4100 user guide, there are specific USB peripherals in the System->DeviceManager->USB that indicate if the proper driver is installed
    and running.  You can uninstall and reinstall the software, and/or send us a screen shot of the error messages.  It would help if you can do this Thurs or Fri, as I wll not be in the office/lab next week.
    Eric (Zhang, Eric [x-zhang1@ti.com]) can be contacted as well for software GUI specific questions.
    Radio Joe
    Report Abuse
    • Reply
  • vandel
    Posted by vandel
    on Sep 10 2009 16:39 PM
    Prodigy50 points
    Thanks Joe:
    This is not a TSW4100 GUI issue, it is a TSW4100 DAC5688 and CDM7005 Control program issue.  The USB drivers appear to be working fine.  I get status messages that say that there is successful DAC5688 register communication.
    On Further research it seems to be a problem with NI LVRT system.   Using Procmon I can see that ther are attempts to access registry keys in HKLM\SOFTWARE\Microsoft\CTF\KnownClasses and this key does not exist ....
    I'd be happy to communicate directly with whomever is responsible for the DAC/CDM control app.  Is this still x-zhang@ti.com
    vandel
    Report Abuse
    • Reply
  • vandel
    Posted by vandel
    on Sep 10 2009 16:40 PM
    Prodigy50 points
    Hi Joe:
    Also, I have uninstalled and reinstalled and the problem persists.  There is screen shot to send as the only symptom is that when you click Load Settings, nothing happens.
    vandel
    Report Abuse
    • Reply
  • Radio-Joe
    Posted by Radio-Joe
    on Sep 10 2009 17:17 PM
    Expert7235 points
    Eric or Ruben can help with the Labview Runtime LVRT issue.   Please contact Eric first.
    REgards,
    Radio Joe
    Report Abuse
    • Reply
  • Ashwani
    Posted by Ashwani
    on Jan 15 2010 03:20 AM
    Expert1365 points
    We are trying to design a Digital GSM Repeater operating at 900/1800 MHz bands. It would mainly comprise of a “Digital Down Converter” and “Digital Up Converter”. Please suggest, what kind of receiver and transmitter architecture is preferred between a Homodyne and Heterodyne architecture?
    Thanks in advance.
    Ashwani
    -Regards.
     Ashwani
    Report Abuse
    • Reply
  • Radio-Joe
    Posted by Radio-Joe
    on Jan 15 2010 09:54 AM
    Expert7235 points
    In repeater applications we can frequency translate a band, or we can isolate a small group or single carriers.  The repeater typically has one or two receive and transmit antennas.  The zero IF (homodyne) or low IF, standard IF(heterodyne) architectures are typically before the DDC and after the DUC.
    The DDC and DUC can be used for isolating small groups or single channels.   The frequency translation occurs on part of a band of channels.  If an entire block is translated, this can be done without the DDC and DUC, the ADCs sample the quadrature demodulator output, the DAC interpolates and translates the input to a new frequency.
    Homodyne approach
        no DDC homoodyne, and possible DAC tuning. ( TRF3711 quadrature demodulator -> dual ADC) TSW6011to (DAC5688 to TRF3703) TSW3003.
    Heterodyne approach
         a) RF -> IF (range of 61 to 90Mhz) integrated ADC+DDC (AFE8406) AFE8406 SEK -> multichannel format conversion to dual DAC -> (DAC5688 to TRF3703) TSW3003
         this would support a dual ADC, dual DAC indoor / outdoor version without diversity, and the transmit portion is low IF direct upconversion
        (b) a real IF only  single antenna input and output (ADC, GC5016, DAC) TSW4100.  This technology could be extended to two ADCs and
         two DAC by adding a second ADC and second DAC.
    Please contact  Roland Sperlich [r-sperlich@ti.com] about the EVMs and experiment data that his group has collected with these EVMs.
    Radio Joe
    Report Abuse
    • Reply
  • Ashwani
    Posted by Ashwani
    on Jan 18 2010 07:06 AM
    Expert1365 points
    Hi Radio Joe,
    Thanks for your detailed reply.
    From your reply I understand a couple of Architectural options are available for a GSM Digital Repeater design.
    Please let us know if it would be possible to meet the ETSI GSM Repeater specification by following the Homodyne approach as proposed by you. Such a solution would truly be a very low cost one.
    References of any TI based GSM digital repeater solution following the homodyne approach as proposed by you would be appreciated.
    Regds.
    Ashwani
    -Regards.
     Ashwani
    Report Abuse
    • Reply
  • Ashwani
    Posted by Ashwani
    on Jan 18 2010 09:26 AM
    Expert1365 points
    Hi Radio Joe,
    Our application is a band selective GSM 900/1800 MHz repeater that amplifies & re-transmits the signals to increase the coverage area. We are looking for a cost-effective solution with the basic specification given below:
    GSM 900
    • Band width (Full) : 25MHz
    • No. of Sub-bands: 3
    • Sub-band              : 0.8, 2.2, 4.2, 6.2, 10.2, 16.2, 20 MHz
    GSM 1800
    • Band width (Full) : 75MHz
    • Sub-band              : 0.8, 2.2, 4.2, 12.2, 25MHz
    The solution may use a Homodyne or Heterodyne Tx / Rx architecture, our basic concern is its compliance with ETSI standards as well as cost.
    Regds.
    Ashwani
    -Regards.
     Ashwani
    Report Abuse
    • Reply
  • Ashwani
    Posted by Ashwani
    on Jan 20 2010 03:46 AM
    Expert1365 points
    Hi Roland Sperlich,
    Please find below our requirements:
    1. As mentioned in the previous mail our application is a “Band Selective GSM 900/1800 MHz Repeater” and the number of carriers in a band depends on the selected sub-band width. We do not intend to amplify the carriers in these sub-bands individually instead we shall consider each of the sub-bands as a whole.
    GSM 900
    ·         No. of Sub-bands  : 3 at a time
    ·         Sub-band              : 0.8, 2.2, 4.2, 6.2, 10.2, 16.2, 20 MHz
    GSM 1800
    ·         Sub-band              : 0.8, 2.2, 4.2, 12.2, 25 MHz
    1. The indoor and outdoor repeaters must comply with the requirements of ETS 300 609-4.
    1. The requirements of output power level and adjustable gain for Indoor and Outdoor repeaters are given below
    Indoor Repeater
          Output power level
    UL:  16dBm (GSM 900 & 1800)
    DL:  19dBm (GSM 900 & 1800)
         Adjustable gain: 40-65 dB, in steps of 1 dB
    Outdoor Repeater
         Output power level
    +33.0 dBm DL & UL (GSM 900)
    +37.0 dBm UL & +40 dBm DL (GSM1800)
         Adjustable gain: 65-95 dB, in steps of 1 dB
    Please suggest a suitable time for telecon.
    -Regards.
     Ashwani
    Report Abuse
    • Reply
  • Ashwani
    Posted by Ashwani
    on Jan 22 2010 23:07 PM
    Expert1365 points
    Could we select band of interest from second or third nyquist zone.
    -Regards.
     Ashwani
    Report Abuse
    • Reply
  • Radio-Joe
    Posted by Radio-Joe
    on Jan 25 2010 11:10 AM
    Expert7235 points
    Hello Ashwani,
    The ADC can be used with either Nyquist zone 1,2,3,4,5.  A single (nyquist zone) range of IF frequencies is filtered and converted.  Zero IF or low IF architectures, the first nyquist zone is used.   If the IF is higher in frequency, there is a tradeoff in ADC performance, and sample clock quality for higher nyquist zones.
    An example:
    We have a low IF downconversion, 910Mhz input, 900Mhz LO, quadrature down converted to 12Mhz I and Q.  In this example we want to have a 20Mhz band.  We could use a ADC sampling at 50Mhz for both I and Q.  The ADC input is filtered from 1 to 24Mhz.  The DDC (GC6016) can provide the DC offset removal, and IQ imbalance correction, depending on the number of  channels.  The DDC processing is done between the Rx and DDUC blocks.  We translate the low IF to 0IF, filter, and decimate.  The DDUC output at a 25Mhz rate, has an 80% BW filter to pass the 20Mhz signal.
    We have a real mixer that translates the 910Mhz input, with a 840Mhz LO, the output is filtered for 70Mhz +/- 12Mhz.  The ADC sampling at 100Mhz, uses the 2nd nyquist zone to sample the real 70Mhz IF.  The DDC (GC6016) converts the real input to complex, and translates the complex input to 0IF.    The Rx and DDUC blocks, filter and decimate the 0IF translated signal.  The DDUC output is at a 25Mhz rate, has an 80% BW filter to pass the 20Mhz signal.
    The GC6016 can be used with both real and complex IF inputs.  You can discuss desired IF planning with Roland in your conference call.
    Radio Joe
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
