• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » RF & Digital Radio » /etc... RF » /etc... RF Forum » TRF7960 for battery and metals
Share
/etc... RF
  • Forum
Options
  • Subscribe via RSS
This question is not answered
Prithvi Gautham
Posted by Prithvi Gautham
on Aug 02 2011 00:12 AM
Prodigy40 points
Hi All,
I am working on project based on TRF7960 and the object to be tracked is lithium ion battery pack. I plan to use mifare or equivalent tag on the battery pack.
TRF7960 will be used to the read the tag. The read range should be about 3-5 cm when the tag is on battery and upto 8-10 cm when not on battery.
I should be able to read and write to the tag. The size of the tag will be either 24mm inlay or 40mmx25mm inlay that will be stuck on the battery pack.
Is this achievable with TRF7960?
Which protocol will suit this application - 14443A/B or 15693.
The Antenna for reader will be that used on TRF7960 eval kit - one to one copy.
Any help/feedback is greatly appreciated.
Prithvi
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Eddie LaCost
    Posted by Eddie LaCost
    on Aug 02 2011 17:06 PM
    Expert3355 points
    TRF796x EVM Read Ranges.pdf
    Hi Prithvi,
    If you mount the tag directly to the battery pack, it is unlikely that it will read at all depending on the metal composition of the battery.  The tag will suffer from detuning effects.  I would suggest providing at least a few mm's seperation of the tag from the metal.  You can also find special ferrite material that can be applied to the tag and help shield.
    With this in mind, I have attached the free space read range of the EVM and the different ISO 15693 tags that we offer.  This is assuming the tag and reader are in parallel orientation.  In order to acheive your range requirement, you may need to consider a larger reader antenna or larger tag antenna or higher Q antenna.
    ISO 15693 will allow for longer range due to the lower bandwidth, hence higher Q antennas are possible.  ISO 14443A/B can offer higher security though.  What is the goal for this application?  Do you require very high security?
    Eddie LaCost
    Please click the Verify Answer
    button on this post if it answers your question.
    Report Abuse
    • Reply
  • Prithvi Gautham
    on Aug 03 2011 01:08 AM
    Prodigy40 points
    Hi Eddie,
    Thankyou very much for the reply.
    The Battery packs would be that of lithium-ion. Application is to track the inventory/supply chain.
    I also read (on internet) that metal shielding is required to eliminate the effects of eddy currents that are induced which de-tunes the antenna.
    As of now, the goal is to read from tag on battery pack. I may be able to manage a 1 or 2 mm separation but not more than that.
    Security is not an issue since I can manage that by writing encrypted application data and reading that. My application should be able to handle that.
    I see that inlays from TI are about 0.4mm thick and this perfectly suits my application and so does the cost.
    So, now the question is how do I add this ferrite shield to TI inlays?
    Regarding the read range - from the document you sent I see that 3-4 cm is quite achievable in open air. But still need to test with battery pack.
    Second question is, it looks like reading and writing to tags is now a function of shielding the tag.
    So, can I go ahead and use the TRF7960 eval kit as reference design to build my reader? There is always an option to add external antenna.
    Thanks Eddie once again. Appreciate that.
    Prithvi
    Report Abuse
    • Reply
  • Eddie LaCost
    on Aug 03 2011 10:00 AM
    Expert3355 points
    Prithvi,
    The Ferrite Shield material should attach to the tag with adhesive.  You could assemble a few by hand for testing purposes and once you find something that works, have a label converter add the material using an automated process.  I have included a few manufacturers of thin ferrite material below.  You also may want to look at metalcraft who manufactures tags using our inlays with a foam type spacer.
    http://www.ferrishield.com/html/RFIDShielding/RFIDabsorbershielding.html
    http://www.delevan.com/seriesPDFs/FFAM.pdf
    http://www.tdk.co.jp/tebck01/flexield_e/e/future_1.html
    Metalcraft: http://www.idplate.com/
    I think the TRF7960EVM would be a great platform to use as a reference design and for range testing.  The kit also comes with a few sample tags.
    Eddie LaCost
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
