We need to improve current design use TMS3705- TRANSPONDER BASE STATION IC
Two extension option (between the board with the TMS3705 and the antenna):
15 meter without any interference electronics (only cable) this is the preferred option, adding supported electronics nearby the TMS3705 (on same board) acceptable.
2 meter antenna extension and 15 meter TMS3705 digital communication extension
We found the SCBA031 application note and we will learn it
We like to ask:
Recommendation for this two options (1,2)
What kind of cable we need to use (Shielded twisted pair, Coax, Traix Cable)?
Do you familiar with of the shelf antenna board?
Application note/ instruction for design the antenna?
Relevant evaluation kits?\
Shlomi
