• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » RF & Digital Radio » High Performance RF Modulators, PLL and VCO products » High Performance RF Modulators, PLL and VCO products Forum » LMX2541 Evaluation board won't lock
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 20 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
Eric Norum
Posted by Eric Norum
on Nov 23 2011 14:52 PM
Prodigy10 points
I'm using an LMX25412380 EBI board to generate a 2.41176 GHz ADC sampling clock based on the 500 MHz reference in our synchrotron light source storage ring.  I've modified the board to accept an external clock signal rather than using the on-board 100 MHz oscillator.  The LOCK indicator LED never lights and the output is stuck at 2.436 GHz (+5 dBm) even when the 500 MHz (0 dBm) reference is moved up and down a MHz or so.
Here's how I've configured the LMX2541.  The design tool seems happy with these numbers.
Suggestions welcomed.
 * Configure PLL
 * Fout = Fin * (PLL_N + PLL_NUM/PLL_DEN) / PLL_R / VCO_DIV = Fin * NUM / DEN
 * Choose PLL_R=5 (Fpd = 500 MHz / 5 = 100 MHz)
 *  * Use NUM=82, DEN=17 (Fout=2.41176 GHz, Fsamp=1.20588 GHz, Tsamp=829.26829 ps)
 * 13448 samples per revolution (41 samples per bucket * 328 buckets)
 * Equivalent Fsamp=20.5 GHz
 * Yields PLL_N=24  PLL_NUM=2  PLL_DEN=17  PLL_R=5  VCO_DIV=1
void
pllConfig(void)
      /* R7 -- Reset PL */
      pllConfigWrite(0x00000017);
      /* R13 -- VCO_DIV_OPT=0 (Since RFout Pin disabled) */
    pllConfigWrite(0x0000008D);
    /* R12, R9  -- As described in data sheet */
    pllConfigWrite(0x0000001C);
    pllConfigWrite(0x28001409);
    /* R8 -- AC_TEMP_COMP=24 -- optimum for fixed-frequency application */
    pllConfigWrite(0x0111CF88);
     /*R6 -- DIVGAIN, VCOGAIN, OUTTERM=12 (default), RFOUT=2 (Enabled) */
    pllConfigWrite(0x001F3326);
    /* R5 -- All values=0 (no fast lock) */
    pllConfigWrite(0xA0000005);
    /* R4 -- C4_LF=4 (40 pF), C3_LF=4 (10 pF), R4_LF=0 (200 ohms),
     *       R3_LF=0 (200 ohms), VCO_DIV=1, OSC_FREQ=255 (since Fin > 255 MHz)
     * With these values and the existing 2.2nF C1, 470 ohm R2 and 22 nF C2
     * on the board the design tool reports a phase margin of 39.3 degrees
     * and jitter at the RF output of 148 fs RMS.*/
    pllConfigWrite(0x44001FF4);
    /* R3 -- FSK=0, DLOCK=0, CPT=0, DITH=3 (disabled), ORDER=3, FDM=1,
     *       OSC2x=0, CPP=0, MUX=3 (Digital lock detect),
     *       CPG=31 (3.2 mA, gives lower jitter), XO=0,
     *       POWERDOWN=0, MODE=0
     pllConfigWrite(0x01B87F03);
    /*  R2 -- PLL_DEN=17 */
    pllConfigWrite(0x04000112);
    /* R1 -- PLL_NUM=2:[21:16]=0, PLL_N:24[17:12]=0, PLL_R=5 */
    pllConfigWrite(0x00000051);
    /* R0 -- PLL_NUM=2, PLL_N=24 */
     pllConfigWrite(0x00020180);
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Dean Banerjee
    Posted by Dean Banerjee
    on Jan 13 2012 18:36 PM
    Intellectual2860 points
    Sorry for the delayed response, but I was unaware of this forum.
    The VCO divides the range into 128 different bands.  SO if you load the part (R0 Register), then a calibration is run.  But if you sweep OSCin, you are stuck in a specific band.
    I don't see anything suspicious with your programming.  One thing is that for the LE pulse on your programming, you can't hold this high too long or it will interfere with the VCO digital calibraiton.  We mention this in the electrical specifications and give a time around 1 us.  Perhaps this is the issue.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
