• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » RF & Digital Radio » High Performance RF Modulators, PLL and VCO products » High Performance RF Modulators, PLL and VCO products Forum » Using I/Q modulator in AM modulation application?
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 7 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is not answered
Alex Marcoux
Posted by Alex Marcoux
on Mar 29 2012 09:08 AM
Intellectual510 points
Got a question from a customer about using and I/Q modulator like the TRF370417 in an AM modulation type of setup. I'm not an RF guru, so your inputs are welcome. Here is the statement from my client:
I might have an application requiring I/Q vector modulator for my next project starting from 110MHz and to 340MHz (this application uses AM modulation for Air Traffic Guidance equipment), I think that I can use I/Q vector mixer to control phase of side band of AM and its amplitude (side bands are at 90Hz and 150Hz modulates RF carrier in between 110MHz to 340MHz under Amplitude Modulation mode, or you can see it as AM carrier that has side bands at +/-90Hz and +/-150Hz offset from carrier);  AM spectrum should as per plot below if you ignore intermodulation caused by a non-linearity of high power amplifier at 60Hz, 240Hz, 300Hz, and 180Hz; Design architect and approach is not designed yet and nothing has been started yet. I used I/Q vector modulator for QPSK type for direct conversion but not quite sure how well it works under AM.
Any feedback would be appreciated if this is a valuable option.
Alex
TRF370417
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Pearson
    Posted by Chris Pearson
    on Mar 29 2012 15:48 PM
    Intellectual1500 points
    Hello Alex,
    I believe the TRF370417 would probably work for an application like this.  Without knowing a lot of the specs or seeing the plot the customer discusses its a little difficult to say for sure.
    If the signals are in the 110M to 340M range than maybe this could be done with direct conversion, just using one of the following DACs -  DAC3482, DAC3484, or DAC34H84 w/o a I/Q modulator.
    EVMs are available online for these parts if the customer wants to experiment.
    Chris
    Report Abuse
    • Reply
  • Alex Marcoux
    on May 01 2012 10:18 AM
    Chris,
    I have new information on this.
    First, the DAC348x would work, but it would prove a more expensive solution than a DAC + TRF solution.
    New, questions are:
    • Can the TRF I/Q input support inputs down to 90Hz
    • Do we have better noise plot at low frequency? Datasheet plot stops at 800MHz (figure 20 & 21)
    • Can we support input with a DC component?
    Alex
    Report Abuse
    • Reply
  • Chris Pearson
    on May 02 2012 13:57 PM
    Alex,
    Interesting.
    The I/Q inputs do work down to DC.
    At DC there is the carrier suppresion  (LO) spur at RF out that is present in all modulators.  Depending on what the customer is trying to do they will most likely have to calibrate the carrier suppresion spur out before running DC there.  I'm not sure I understand the DC component question exactly, so if this doesn't answer the question let me know.
    For noise, in general the noise is better are equivalent at lower LO frequencies when compared to higher LO frequencies.
    Chris
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
