I would like to enter in the VCO phase noise information of the VCO I want to use with the LMX2485e in PLLatinum SIM software. What is the file format?
If you check the ? for help it will tell you.
The format is:
Offset1, Noise1 + <CarriageReturn>
Offset2, Noise2 + <CarriageReturn>
For some reason the little ? Don't work for me.
Can you tell me why the online workbench simulator for the lmx2485 gives very different results when calculating loop filters than PLLatinum Sim does? I took the values work bench gave me for a 10kHz filter PLLatinum Sim said it was 3.5kHz?
Why doesn't PLLatinum SIM allow me to just enter 3 points for VCO phase noise like it does for the reference oscillator? The 'Metrics' values are grayed out and can't be changed like they can for the reference.
