I would like to use DRV5053VA hall effect sensor as a linear position sensor in an area that will experience a wide fluctuation in temperature. Is this hall effect sensor temperature compensated over the full operating range? Basically, I want to know if I calibrate the sensor at ambient temp, will the readings change as the temperature changes or remain the same? If temperature does effect the readings, is there a good way to compensate for this?
Kevin Ellis
