Hi All,
i couldnt find the output voltage value of the DRV5013 on datasheet, when its high or low. Normally there should be an info about output voltage when its high according to Vcc ,when its low according to ground.
thanks
ozi
Hi All,
thanks
ozi
Hi Ozi,
Thank you for posting on the E2E Forums.
The allowable range for the output pn is -0.5V to VCC, where the maximum value of VCC is 40V.
The actual output is open drain, with a switch resistance of 50Ohm and a maximum sink current of 30mA.
