Dear Sirs,
could you please tell about any example of heater usage in real life?
After reading datasheet, I know that it helps to "recover" faster after high humidity conditions. But I don't really understand how it may help with such a little temperature increase.
I've done two tests with HDC1080 soldered on my PCB with heater disabled and enabled:
26.2 C -> 26.7 C (measuring once per second)
26.2 C -> 27.0 C (measuring 5 times per second)
Temperature values are obtained from HDC1080 of course.
So there are two questions:
1. Please validate if my test readings are possible (since I read nearby difference with heater on and off should be about 3-10 degrees).
2. Please give real life scenario when using heater makes a difference.
