Can a HDC1010 humidity and temperature sensor can be used to measure the moisture levels in the soil ?
Yes, the HDC1080 can be used in soil moisture detection: the only precaution could be to avoid direct contact of the sensing element with the ground.
In any case, depending from your specific application and setup, probably the best solution for detecting the soil moisture is the use of the capacitive sensing (FDC):
www.ti.com/.../capacitive-sensing-overview.page
Carmine Iascone
