According to the data sheet the HDC1080 has a resolution of up to 14bits for temperature and moisture measurement. Unfortunately I only see 10bit resolution when trying out 14bit or 11bit - no more.
There is no hint given in the data sheet to this. The needed cap is there. The voltage supply is about 4.2V - bypassed by a small cap.
I am getting values. Some are the same, then this changes to another value - but not so near. The new value is about 0.1% away. Thats not at all a 14bit resolution.
Is this a known problem?
Is my part bad? Should I try getting another one?
Thank you very much for listening and any help with that!
