Hi i did some tests with HDC 2010. In my application HDC is uncovered. The sensor is very close to the 50W bulb so that the light is directed between the sensor and the pcb. When I turn on the bulb, the sensor freeze. Sensor is responding but the data doesn't change. When I turn off the light bulb, the sensor starts sending the correct data.
Have you experienced this problem?
best regards
