Other Parts Discussed in Thread: HDC2080
Hi Sirs,
Sorry to bother you.
We have some questions between HDC2010/2080, could you help check it?
Thanks!!
- What is difference between HDC2010 and HDC2080?
- HDC2010/2080 is the most power saving temp/humidity sensor TI has?
- Any special operation modes to support power saving for battery-powered sensors?
- What is the response time for each measurement?
can we cut off power of HDC2010/2080 between measurements for power saving? - This sensor will be used for temp/humidity measurement under -30~50’C.
any issues will happen on sensor measurement if the water/moisture is frozen on sensor? Any solution to prevent this?
Thanks!!
