I am currently making a breakout board for the LDC1614. From the manual I gather that I should be applying an external clock signal of up to 40MHz for more accurate measurements. If so, is there a part number you recommend I should use for the clock? I have the LDC1614EVM but I cannot seem to make out what part number it is using for the clock.
Thank you
Manuel
